Jan 12, 2023 19:05:01 GMT
I currently use NGK BPR6FS plugs in the Pop, never missed a beat and runs well but they are always a little sooty/oily when taken out.
I used these as they were recommended as a nice short (ceramic) plug and were 'about right' to start with.
I think I need to go a heat range hotter so a NGK BPR5FS - so far so good - except there are 3 versions of it!!
NGK BPR5FS (standard) part No 2423 NGK BPR5FS-15 (standard) part No 3124 NGK BPR5FS-11 (standard) part No 2924
All appear to be physically the same so does anyone know the difference and which is better?
93fxdl
Enter your message here...
Jan 12, 2023 19:26:55 GMT
Jan 12, 2023 19:46:58 GMT
Ah! cheers Glen. I set mine at 50 thou anyway for the MSD ign.
I have found the -11 is a fixed terminal and the -15 and the std one are both 4mm ends (I assume with the screw on adaptors?).
Odd though as there is a wide price difference between them?
Jan 12, 2023 20:09:02 GMT
Loads of plugs these days are not intended to be re-gapped, NGK rep said certainly to check them but due to they way they package them and their QC they should be good to go out of the box.
Can't answer the pricing, I use BCpr7es or 8es in my citroen which are under a tenner a set, standard were bkr6ek.
Jan 12, 2023 20:11:43 GMT
I've ordered the -11 versions, 44thou so not much to open them up by. Just paid under £20 for 8 of them
v8ian
Jan 12, 2023 20:25:31 GMT
Just for a point of interest, NGK UK are based in Hemel Hempsted only a call away and were always very helpful
Last Edit: Jan 12, 2023 20:25:57 GMT by v8ian
Jan 30, 2023 21:38:30 GMT
I've ordered the -11 versions, 44thou so not much to open them up by. Just paid under £20 for 8 of them £2.50 each? Geez, that's cheap! Mine are around that each.
jimi
Jan 30, 2023 23:25:10 GMT
I like NGK plugs, cheap, pre-gapped and reliable. My MR2 runs on BCPR6EY11, I get them for under £2 each from eBay (free delivery). At that price I just bin them and fit a new set every service.
