May 16, 2023 20:46:03 GMT
So I've got two rusty CVH engines sitting around for an upcoming project and they need cleaning... A lot of cleaning. So I'm building a vapour blasting cabinet. For anyone that doesn't know what that is; it's a sand blaster with water added into the mix and give a much nicer surface finish. Seriously, these things make parts so shiny and clean, they look lovely. I've been planning this one for a long time and to me, the number one option as a base for it is a Switzler enclosed parts washer, which is basically an already water tight sand blasting cabinet. Other people have used sand basters and a load of silicone but this comes with more of the parts you need. They look like this: However they're £400+ and I'm a cheepskate so I bided my time and recently I found one second hand for £100. It arrived last week (thank you Shipley). It's an utter dirtbox so fist job is cleaning. A couple of hours on the outside had it looking like this: So, once the cleaning is done I need to strip out some bits, get a suitable container for the water and sand mix, a pump and some parts to make a gun. But for now, I'm dead chuffed with my latest toy, even if it is filthy fecking dirty!
brachunky
Scotland
Club RR Member Number: 72
Building a vapour blasterbrachunky
@brachunky
Club Retro Rides Member 72
May 17, 2023 17:21:59 GMT
Good luck with the project, will be proper handy once completed
May 17, 2023 21:15:30 GMT
Good luck with the project, will be proper handy once completed Cheers, Yeah can't wait!
May 17, 2023 21:23:36 GMT
Did a little more on this tonight, made a new screen for it on the laser cutter, with a little health and safety warning: Then got down 'n' dirty, there are little upside down u channel sections around the outside that hold the grate in place. They're a really rubbish design, and have trapped grime and water for years so it's gone a bit rusty under there. It looked like this before I scraped it all out: Next up I'll finish cleaning it all up, grind out the rusty bits and slather every joint in seam sealer.
Last Edit: May 17, 2023 21:26:05 GMT by raceyrover
slater
Club RR Member Number: 78
Building a vapour blasterslater
@slater
Club Retro Rides Member 78
So what will you use for a pump? I remember a freind of mine making his own years ago but can't remember what pump he had.
Nath
Looking for a Retro
May 19, 2023 15:02:10 GMT
OOoh I like the look of this.
May 19, 2023 20:42:46 GMT
So what will you use for a pump? I remember a freind of mine making his own years ago but can't remember what pump he had. It'll be a dirty water sump pump, there'll be a big water container under the machine and the pump will have two outlets. One to feed the gun and another to agitate the water / glass beed mix.
Jul 27, 2023 17:21:31 GMT
Little update on this, found a bit of time to strip the paint off the lid with one of those carborundum wheels, worked a treat!
at200
Aug 19, 2023 14:10:27 GMT
Any progress with this project? Just been looking at a self built vapour blaster on You Tube.
Last Edit: Aug 19, 2023 14:25:08 GMT by at200
Any progress with this project? Just been looking at a self built vapour blaster on You Tube. Yes! I've bought loads of bits! But nothing to photograph as yet...
Sept 1, 2023 11:34:25 GMT
You've had 4 hrs...... Unacceptable in this day n age. Ahem
Sept 1, 2023 22:18:01 GMT
You've had 4 hrs...... Unacceptable in this day n age. Ahem Sorry, must try harder 😂
This is kinda vapor blaster adjacent... When vapor blasting you need to start with a clean oil free part, so I bought a parts washer. Never used one before and I LOVE it! Gonna be so nice for working in the car! Got this vice for the mill the other day and gave it the spa treatment. Came up really nicely, so gonna give it a lick'o'paint in the next few days.
PS if anyone has any recommendations for water based parts washer fluid, let me know I'm just using a screwfix no nonsense de greaser at the mo and it works but I have no idea if it could be better.
braaap
Interesting project. What kind of compressor is necessary for this kind of blasting? Pressure, tank volume, ...?
melle
South West
It'll come out in the wash.
Sept 6, 2023 10:36:37 GMT
PS if anyone has any recommendations for water based parts washer fluid [...] I use Kroon Cleansol Bio in my parts washer.
Last Edit: Sept 6, 2023 10:37:43 GMT by melle
Well that came up OK!
Sept 15, 2023 16:06:41 GMT
So to compliment the vapor blaster, and because I can't say not to rusty old toot... I bought a sand blaster.... Looked like this: It's had a bit of a hard life in a commercial garage. Someone had badly pop riveted a bit of chequer plate over the original arm holes. Guessing this was because they couldn't find gloves with big enough sleeves to fit the holes. Neither could I, so I designed some new sleeves in solidwroks, cut them on the laser and sewed them together with an over locker. Then sewed the nice new sleeves to the skanky old gloves that came with the sand blaster. Now I can use the sand blaster to clean the vapor blasting cabinet parts and finally get around to assembling it.
Sept 22, 2023 15:51:38 GMT
Been making progress with both the vapor and the sand blaster! Turns out I forgot to take a pic of the vapor blaster thought will try and remember to get one tomorrow... Sand blaster is now fully working and already have mods in mind!
