speedy88
"Nice Cortina mate"
Club RR Member Number: 118
Been busy on the car, but a lot of the jobs are just small important things that aren't worthy of pictures. Re-drilling holes, adjusting seats, making hoses and brackets etc etc. However, this is what I have taken pictures of: The ARB doesn't line up since I moved the subframe but some other thicker ARB that came with car lines up perfectly. Bad picture, I'll try and get a picture of the car on a ramp soon: I fitted a NB MX5 radiator as it's one of the only cars that shares the 2-and-8 o'clock orientation for the hoses. It fits pretty good! I made a couple of brackets: My temporary spring setup ended up being really curse word and bouncy so I splashed out on some Swift springs for an AE86: Converted accelerator pedal from rod to cable. The unfortunate thing was that the pedal pulls up rather than down, so rather than make something new, I just made the cable do a loop de loop mounting it facing up from the lower firewall/transmission area. I drilled and tapped the old rod end into the cable end. Weird angles but there be method to my madness I also had to splash out on the very specific Toyota manual rack spline. It was going to be a similar price to track down a 2nd hand shaft so I ordered a new aftermarket one from Techno Toy Tuning. I then immediately cut it into pieces and welded it onto some Tacoma pieces I already had. Then I welded it directly to the rag joint. In this picture you can see the shaft installed with a universal support bearing as the steering box column does not have one and it flops around. You can also see here the throttle cable mounted to the left which I forgot to take any more pictures of: The car drives forwards and backwards now so I did some sticker engineering:
speedy88
"Nice Cortina mate"
You don't need a pickup truck. New rack is to move things like scooters and engines. Getting ready for summer. Lowered and stuck a load of stickers on the fast scooter that's probably stolen. (I'm autistic, don't @ me)
speedy88
"Nice Cortina mate"
A drift event was announced at the newly refurbished Agassiz Speedway so I pushed hard to get the car ready in time Up on the lift for underneath bits I took some reference pictures to show it's AE86-ness: Did some exhausting work: Replaced some things: Pulled some things. Welded some things: Adjusted some things: Now back on the ground I tackled some other issues: I had some issues with my shaft bearing support so I opted for a nylon bearing and an exhaust clamp at the firewall instead. Works surprisingly well and has room for adjustment: (Heating and stretching the nylon to fit over the shaft) Finished my throttle cable setup: Safety and comfort: Sadly despite being quite short I still had to remove the headliner to fit myself inside wearing a helmet with a seat bolted directly to the floor. The day before the event, the final hurdle was a sticky caliper. It took us a while to bleed the brakes because something I can only describe as mud came out of the lines. We had to empty the reservoir with rags. It came out in chunks! I only had one rebuild kit so one caliper rebuild it was.
speedy88
"Nice Cortina mate"
Last Edit: Jun 3, 2024 17:07:11 GMT by speedy88
speedy88
"Nice Cortina mate"
Jul 31, 2024 23:41:07 GMT
speedy88
"Nice Cortina mate"
Here's the (sort of) official video of the event
speedy88
"Nice Cortina mate"
thebaron
Oooh, that would make too tempting a target for me to go after. 999kg, here we come
speedy88
"Nice Cortina mate"
Installed heavy duty gas and oil dampers (marketed "for towing") So I could do this: A friend took an arty photo: I installed the missing trim and weather strip from the desert car
speedy88
"Nice Cortina mate"
speedy88
"Nice Cortina mate"
Pop quiz. Who can name this "rare but no-one cares" based on this sticker only? I see this vehicle being used all the time as a daily.
Last Edit: Aug 2, 2024 22:44:21 GMT by speedy88
Club RR Member Number: 160
Pop quiz. Who can name this "rare but no-one cares" based on this sticker only? I see this vehicle being used all the time as a daily. Toyota RAV4 EV (can’t remember the exactly correct name)
speedy88
"Nice Cortina mate"
Aug 14, 2024 17:04:19 GMT
Ding ding! Interneto cookie for you
speedy88
"Nice Cortina mate"
Aug 14, 2024 17:29:23 GMT
speedy88
"Nice Cortina mate"
Aug 14, 2024 22:40:53 GMT
Since I moved to Vancouver Island in 2020, I've been eyeing up local events. A lot are on the mainland but still seem worth the ferry trip. One of these events I've had my eye on was the Kaido racer scene, which just seems to be getting bigger each year. I swore to myself back in 2021 that I'd go to one of these things, but here I was in summer 2024 having still not attended or even attempted to build something for it. I just got back from a drift event with a broken alternator with absolutely no desire to get on another boat for a while An old RR regular thousands of miles away tagged me on socials on the Tuesday while I was at work with the message "you going to this?" Do I *really* have to do this? By Tuesday night I've decided that I can bash it out in 3 evenings after work without completely destroying myself. The event is a *tiny* bit exclusive due to trash modern cars turning up in the past, so I messaged the organisers. I get a reply: "Sure! Very welcome to bring the Celica, just make it cool" with these inspirations attached: First of all, let's mention tyre sizes in Western Canada. At the moment it's very difficult to get affordable 14 inch tyres that aren't 185/60/14. Sidewall too girthy for the lows. A kind friend donated me some crusty Japanese tyres that came in on a kei van. The size was perfect! The only issue was that I'd already destroyed one of them trying to get it on an old drift wheel. Like I say, crusty. The chances of finding anything close, even 1 was slim. So I opted to use a tube. At this short notice all I could find in the right size was this punctured one which I'd patched but has a slow leak. It works fine other than the leak, so I made sure to pack the pump for the weekend. I sadly had to use springs. I tried removing them altogether but I get clearance issues on the center prop bearing and the UJ slamming into each other. Easy enough to clearance but absolutely no time. So I installed some choppies: The front is coilovers so I just wound them down to the maximum
Last Edit: Aug 14, 2024 23:02:23 GMT by speedy88
speedy88
"Nice Cortina mate"
Aug 14, 2024 23:10:05 GMT
Last Edit: Aug 14, 2024 23:13:01 GMT by speedy88
speedy88
"Nice Cortina mate"
Aug 14, 2024 23:21:49 GMT
I'll upload the pictures from the event HERE
Last Edit: Aug 14, 2024 23:22:17 GMT by speedy88
speedy88
"Nice Cortina mate"
Last Edit: Nov 8, 2024 23:23:06 GMT by speedy88
speedy88
"Nice Cortina mate"
Last scoot ride of the year More wheels! These rally tyres were a right PITA to get on Rally spec now? What's going on?
Last Edit: Nov 8, 2024 23:11:12 GMT by speedy88
speedy88
"Nice Cortina mate"
