Hi all
Got a another hour or so in after tea, couldn't face plumbing so I fitted the volt meter and usb socket to the kitchen unit, all wired in and working plus I connected the electronic ignition on the hob.
Rum time now
Cheers Mike
Hi all,
made an early start today, its much cooler thank god.
Have finished wiring/plumbing the kitchen so we now have running water and a working hob.
I wasn't happy with the set up for the split feed into the controller so have added a voltage sensing relay to ensure that the starter battery is fully isolated when the engine is not running.
That's it for today, shower and water heater to fit tomorrow and ceiling panels on monday and she will be done.
Cheers - mike
is this a keeper or a flip?
is the furniture prebuilt or are you making it ?
fantastic build so far 👍
Hi there,
This is a customer build. All the units are scratch built to suit.
Cheers Mike
Hi all
another steady day today.
Not a lot achieved and a bit fed up. The water heater, shower head and bathroom plumbing are in.I fired up the water heater and it took around 30 mins to get up to a decent shower temperature. The system is a low pressure system with a pressure switch used to control the pump and deliver hot water on demand, however, the pressure switch lasted about and hour before it split and leaked, top quality chinese curse word strikes again. On checking it was a well known british brand but the packaging now states "made in china". Its getting harder to find quality parts.I have another on the way. One of the reasons for trialling the water heater was to assess the power consumption, battery voltage started at 13.5 volts and dropped to 12.6 when the heater was on and once the heater was up to temp recovered to 13.5 volts in around 30 mins which is not too bad for an overcast showery day.
I have connected the fridge and its currently coming down to temp. It's a bit of an upgrade from the standard one as it's got a decent sized freezer box.
Jobs for tomorrow are to tidy up the wiring in the wardrobe,seal the bathroom with white silicone and make and fit the remaining ceiling panels.
Cheers - mike
Hi all, Have spent most of the day today making closing and ceiling panels. The centre one is done and fitted, I have added four led lights with remote control and a led strip light above the kitchen so just the front one to finish and then the bathroom one. Had to go to A&E as I think I've had a pvd in my left eye. Got to go to the eye clinic tomorrow as there's a tear in my retina which may need surgery. Cheers - mike
Hi all, Have just about finished this one, just waiting for a new pressure switch to arrive. There's a bit of sealing to do in the shower and a shelf to make and fit in the wardrobe. Cheers Mike
hopeso
That certainly looks the part. Excellent work as usual.
Aug 11, 2024 12:39:53 GMT
electric water heater, from battery? I can't see how that would ever make enough heat. Nice build tho.
75 Range Rover 2 door 82 Range Rover 4 door 84 Range Rover 4 door 78 Datsun 120Y 2 door 78 Datsun 620 Pickup 81 Datsun Urvan E23 86 Datsun Vanette van 98 Electric Citroen Berlingo 00 Electric Peugeot Partner 02 Electric Citroen Berlingo 04 Berlingo Multispace petrol 07 Land Rover 130 15 Nissan E-NV200 15 Fiat Ducato
Aug 11, 2024 20:28:54 GMT
electric water heater, from battery? I can't see how that would ever make enough heat. Nice build tho. hi there the 12v water heater brings the temperature up to 38 degrees in around 25mins. Its best to use the water heater when the engine is running. Cheers - mike
Aug 12, 2024 18:23:56 GMT
A heat exchanger that uses engine heat from the heater circuit to heat water in a tank might be a cool way to get free hot shower.
