r820
Kinda New
Aug 28, 2024 21:45:33 GMT
Hi, I've recently bought a 1994 Rover 820 2.0 T16 SLi Auto, and unfortunately, the SRS is illuminating on the dash upon startup. What would be the best way of resolving this? So far, we've tried unplugging and reconnecting the connectors under both front seats and drained the ECU (left the battery disconnected overnight). Additionally, we've found two service ports, one to left-hand side of the driver, under the radio/ blower system, and another under the bonnet. However, we cannot find any tool to access these ports. It's really quite frustrating aha Any help would be greatly appreciated. Thank you
Last Edit: Aug 28, 2024 21:46:02 GMT by r820
ToolsnTrack
Homebrew Raconteur
Club RR Member Number: 134
It could be something as unexpected as a faulty SRS component.
If there is no way to fault diagnose with a reader to determine which component is at fault, ut could be worth determining the resistance each item provides, bypassing with a resistor each item to see which "resets" the fault with a resistor in to allow you to pinpoint the fault.
820
Once the SRS system sees a fault or anything is disconnected with the ignition switched on, the light will stay on till the fault is fixed and cleared using a Rover Microcheck or Test Book for your 1994 car.
The diagnostic connector is down by the pedals on the tunnel behind the triangular clipped on carpet panel
Most likely something was unplugged with ignition on or the steering wheel clock spring/rotary coupler has an open circuit.
dog
Aug 30, 2024 10:03:25 GMT
Generally unplugging/replugging the wiring under the seats (if this is the issue, code reader helps) will not cure it, they will need cutting off and hard wiring together, or remove existing connectors and fit better quality.
820
Aug 30, 2024 10:08:34 GMT
There is no SRS wiring under the seats on these
Aug 31, 2024 18:19:29 GMT
My 820 did this when I first had it - turned out to be a loose battery terminal...
Never confuse morals with standards!
1998 Rover 820 - Maggie
Previous rides..... Seat Ibiza 1.8 GTi Focus ST170 Mercedes C200 Sport Saloon Volvo 850R estate (manual) 1979 Mk2 Granada 1990 Sierra Gl Mitsubishi Legnum VR-4 Alfa Romeo 156 Selespeed 1980 mk2 Granada estate - Pre-facelift 1998 Rover 800 x2
Sept 5, 2024 16:04:25 GMT
Have you checked the continuity of the 'clockspring' behind the steering wheel airbag ? They can be fragile
Once the SRS system sees a fault or anything is disconnected with the ignition switched on, the light will stay on till the fault is fixed and cleared using a Rover Microcheck or Test Book for your 1994 car. The diagnostic connector is down by the pedals on the tunnel behind the triangular clipped on carpet panel Most likely something was unplugged with ignition on or the steering wheel clock spring/rotary coupler has an open circuit. If this is correct, just fixing the fault alone won't fix it. It needs someone with the correct diagnostics to clear it. BMWs are the same. If there is an airbag fault, disconnecting and reconnecting the battery after fixing the issue won't clear the problem. For the OP, it may be worth seeing if there is a person who can clear your codes for you or read them at the very least. At least you can then know where to go looking.
