Sept 29, 2024 16:09:59 GMT
I was thinking that hiding an Apple Airtag in the car would be a decent tracking option. I have used airtags to track luggage. They are small, decent battery life and don't need any kind of contract or airtime.
Has anyone tried this? I have heard folks say its not reliable as a method of tracking. it seems to work well enough with my suitcases.
A decent third party version would be fine but I guess they will all be subject to the same limitations?
Thoughts?
1941 Wolseley Not Rod - 1956 Humber Hawk - 1957 Daimler Conquest - 1966 Buick LeSabre - 1968 Plymouth Sport Fury - 1968 Ford Galaxie - 1969 Ford Country Squire - 1969 Mercury Marquis - 1970 Morris Minor - 1970 Buick Skylark - 1970 Ford Galaxie - 1971 Ford Galaxie - 1976 Continental Mark IV - 1976 Ford Capri - 1994 Ford Fiesta
b18lou
Sept 29, 2024 16:54:57 GMT
I have used them as car trackers before, theres just 1 weakness and thats if the theif happens to have a iphone they will be alerted to it's presense in the car.
Still however a very cheap way of having a tracker.
Sept 29, 2024 23:45:18 GMT
I have them buried in a few of my cars and also on my car trailer. Maybe the warning that an AirTag is traveling with the thief will cause them to dump it before parting it out? Or at least I hope so.
Sept 30, 2024 9:32:54 GMT
I am a little unclear about how AirTags work, that thing about them being visible to a theif is a possible downside, but doesn't that only happen when you put them into "lost" mode? You can track them otherwise just fine without the lost mode. Or could a thief be "scanning" the car to see if there were tags in it?
For £25 each with no airtime charges they seem like a good buy...
maf260
I use airtags for luggage when travelling - peace of mind to know the bags have been loaded onto the plane!
I also have one stashed deeply in a car with the speaker removed so that even if a thief can discover it's in there they can't use the audible alert to easily find it.
LowStandards
Club Retro Rides Member 231
Airtags will alert a phone that they are travelling with them as a safety measure to stop you being a drity stalker
I kinda think this is a good thing in this instance, as ChandlerGti says, it would make them dumnp the car
You'd also want to mod it to remove the speaker as it will alert them to it's location that way as well, but it's easy to do and loads of info online
I'm curious. If the tags alert you to travelling with them, then why doesn't alert anyone I travel with as I have an airtag on my house keys? Surely then every iPhone user I go anywhere with should get a warning? Nobody ever mentioned it and I would have thought that it would cause comment.
Do you have to go into "find my" to see if there is a tag travelling with you or should there be a popup?
I feel this is a cause for some investigation
Good call on the speaker removal.
jimi
I kinda think this is a good thing in this instance, as ChandlerGti says, it would make them dump the car More likely, dump the car and set fire to it
Last Edit: Oct 1, 2024 16:11:11 GMT by jimi
LowStandards
Not seen a burnt out car in years
I quite miss it
maf260
I'm curious. If the tags alert you to travelling with them, then why doesn't alert anyone I travel with as I have an airtag on my house keys? Surely then every iPhone user I go anywhere with should get a warning? Nobody ever mentioned it and I would have thought that it would cause comment. Do you have to go into "find my" to see if there is a tag travelling with you or should there be a popup? I feel this is a cause for some investigation Good call on the speaker removal. My understanding is that they would only get an alert for an 'unattended' air tag moving with them. If you're nearby it knows it's yours and so won't alert others.
I'm curious. If the tags alert you to travelling with them, then why doesn't alert anyone I travel with as I have an airtag on my house keys? Surely then every iPhone user I go anywhere with should get a warning? Nobody ever mentioned it and I would have thought that it would cause comment. Do you have to go into "find my" to see if there is a tag travelling with you or should there be a popup? I feel this is a cause for some investigation Good call on the speaker removal. My understanding is that they would only get an alert for an 'unattended' air tag moving with them. If you're nearby it knows it's yours and so won't alert others. Now that makes sense. I still feel the need to test this.
frag
When I considered putting one on the dog,Incase he went ‘awol’ I was under the impression,AirTags piggyback off other nearby apple devices for location info.So if there’s no nearby other apple device,they can’t be located.
No good for the dog scenario if in the countryside…..
So depending where you live,and where the car was stashed or dumped,would you still be able to locate it like a tracker ?
'69 Holdsworth bay '88 T25 Panel van ‘72 beetle ‘78 vw champagne T2
maf260
So depending where you live,and where the car was stashed or dumped,would you still be able to locate it like a tracker ? Yes
Tile trackers don’t alert other iPhone users when one is nearby, as an AirTag will.
frag
So depending where you live,and where the car was stashed or dumped,would you still be able to locate it like a tracker ? Yes I Even if it’s not close to/within range of any other apple device ?
The alerting feature of airtags can be handy. Quite a few motorbike thieves were using them to track bikes to a person's address so as to steal them later. I have heard similar deals happen on cars, but I've yet to hear a report of this being the case.
As a budget way of tracking the car, it's worth a go. Whether the police will acknowledge it as a means of recovering the car is another matter.
maf260
I Even if it’s not close to/within range of any other apple device ? I believe it needs to operate within the Apple Find my Device network, so not like GPS, but with so many Apple devices in use there must be very few black spots.
frag
They seem to rely on blue tooth, to the nearest apple device (and that has to be connected to the internet) Range isn’t brilliant,I think you’d be in with a chance in a city or town due to all the other apple deivices But in a rural or countryside location,if there’s no other apple internet connected device,within Bluetooth range (10 metres indoors / 30 metres outdoors) It will only show the last location it was within range of such a device beepings.com/airtag-vs-tracker/#:~:text=This%20means%20that%20its%20range,range%2C%20it%20cannot%20be%20located.
Last Edit: Oct 8, 2024 9:56:55 GMT by frag
glenanderson
Club RR Member Number: 64
Oct 14, 2024 18:22:45 GMT
We have an AirTag on our cat’s collar. It’s a reasonable way of keeping track of her, but we do live in an urban environment and there’s plenty of other devices around.
