The steering rack on the Mini is looking a bit dry on the inside, one of the gaitors was a bit loose and all the lube has gone.
What should I re-lubricate it with? The workshop manual states that I should use S.A.E 90 oil but I was just going to use normal LM grease.
There is a little play in the rack and I thought that LM grease would take up a little of the slack until I replace the it.
