craig1010cc
Club RR Member Number: 35
May 16, 2009 19:56:08 GMT
Had a productive couple of days at the lock up. Owen came over yesterday to lend a hand, cheers chap So the brace bar/ front end support is now welded up and bolted on and we started to make the lower rad mounts. 1/2 way through and the genny packed up :x This kind of hampered us, so we decided it was time to get the engine fired up again as it hadn't been run with the extra silencer and the airflow meter connected. Well i don't think i'll struggle with noise regs Took a bit of tweaking to get the airflow meter calibrated (and it's still not 100%), but it was a big boost to hear him running again So today i decided to make a start on sorting out the wiring and dials. So the old dash was removed and i could then play about with the positioning of the Tigra dials This i think is where they will end up as it in front of the driver, the speedo cable will want to go through the brake master cylinder I then set about replacing the stock 4 fuse set up with 2 lots of 8 blade fuse boxes. To make this easier, i also bolted in the nova GTE seats on the bodge brackets they came with. too far forward so some new ones will def be needed Then i decided to have a play with the bonnet pins. I think this is where they will end up being
Absolutely fantastic.
Now, it may be the whisky talking, but get that Mk1 Golf GTi grille on there.
craig1010cc
May 17, 2009 10:32:27 GMT
We have considered it (it's from a mk2, i think a mk1 would need to be narrowed less). I think though it will be a later project, once it is on the road.
We tried in it the widend front end of my mates semi spaceframed mini(the green and blue one in the background having a VVC lump fitted), and in that it needed to be stretched!
craig1010cc
May 18, 2009 19:12:11 GMT
Well, another couple of productive hours spent today The bonnet pins are now fitted, need a bit of adjustment (front is a bit far forward at the mo and i might wind the back down an inch) Then it was on to the rear number and numberplate lights. As the boot i got from Keith has been partly smoothed, i soured some LED numberplate light bolts which will do the job. Nearly drilled into the tank, but realised in time :shock: then got bored, so repainted the spare clubby grill in gloss black So a few more jobs ticked off the list
May 19, 2009 19:46:37 GMT
Great work, this thread is a pleasure to read as a whole. Have to confess that I always favour a round-nose over a clubman but needs must and the world NEEDS more crazy-engined Minis!
Can't help but notice the enormous supply of Minis knocking about your lock-up - what's the deal? I'm suddenly hankering after a ruined old Mini to play with...
1969 Land Rover Series IIa
1980 MG Midget (bro's)
1981 Land Rover Series III
1981 Mini 'Cooper'
1982 Mini HL
1983 Mini Sprite
1987 Mini Advantage
1994 Mini Sprite auto (oil leak left as standard)
2002 Alfa Romeo 147
craig1010cc
May 20, 2009 12:29:29 GMT
we have got a few up there, 2 in work that are mine (plus my cooper which is back on the road after its rebuild), garry has 2 in work, a 1293 clubby track toy + a Marcos project so plenty to keep us busy Plus there is a Mini specalist next door as well which is handy ;D I know what you mean about the clubby nose, i never used to be a fan. But i restored one a few years back which is now in Ireland and i fancied another. We could have got the 8v lump in the stock nose, but it would have been a lot more work and it scratches my clubby itch so to speak
craig1010cc
May 23, 2009 18:24:19 GMT
Bit of a mixed day today. Decided to do a bit on the cosmetics side. So, the boot was stripped and given a coat of satin black But i broke one of the wires for the numberplate lights inside it so i'll have to order another set :doh Then on with the front end. Spent a while trimming the remaining bits of the original mini it came off of and it now sits much better Then needed to trim the front arches to clear the tyres. Came up with a cunning plan as well which worked out really well Then time to attack the bonnet. 1st thing was to remove the inner skin as it was rusty and flapping about. With that gone it was then time to sort out a few dents and scratches. This turned into a mamoth filling and sanding session and this was where i left tonight. Hopefully no more to go on, just needs the final rubdown before the paint goes on
May 23, 2009 21:46:59 GMT
That looks great on the Cosmics!
craig1010cc
May 27, 2009 21:26:43 GMT
Big progress this evening thanks to Gaz, Owen and James (Tinxy). The repaired caliper is on, the 1st attempt at bleeding the brakes (not very sucessfull sadly Keith is going to crack this on Monday with some new cooper S rear cylinders to replace the 8.4's). The front end has been bolt checked, the low pressure pump is now bolted in place, and the overflow from the swirl pot was re-routed to the tank breather. So it was time for the 1st drive :-D backing out of the lock-up, hmmm, what that smell................petrol! :shock: was leaking from the tank overflow. with the aid of a better hose clip and some gaffer round the outlet, it was fixed well enough for the test run. So fired back up, still running lumpy, after much head scratching Owen remebers when it did something similar when he had it "bet the plugs have fouled from when running without the airflow meter". Sure enough the plugs where black. New set in and purring nicely (well, once the leads where back on the right plugs :lol:) The 1st drive was pretty sort, party due to the lack of brakes, but also it was grounding out all over the place But a couple of squirts on the loud pedal and boy does it go And to celebrate when we put him away after wards, he dumped 1/2 ltr of coolant on the floor (new thermostat gasket needed) only one pic at the mo, but gaz got a couple of vids which should be up soon
craig1010cc
And here is the vid thanks to Gaz a small step backwards today, owen popped over to change the stat body so we could get the stat to seal (stripped thread) and i hadn't realised we would need and extra gasket and sadly hermatite wouldn't seal it so that will have to come off again But the coil is now mounted up on the brace bars so still progress made And when we bolted the front back on, i thought it was time that the grill went back on
Ya bonnet's open!
craig1010cc
May 29, 2009 22:11:58 GMT
Ya bonnet's open! will prob drop the back of the bonnet down an inch before it hits the road mind
craig1010cc
a productive few days up at the lock-up Keith has sorted the brakes so i now have a pedal (and not a bad one at that) and i have made some progress on the cosmetics too On Tuesday i cracked on with prepping the front end for paint , stone chipped the lower valance and got the red (with flake) on the tops of the wings A few bugs decided that they wanted to be apart of the paint job, but due to how hot is was and the speed at which the paint dried it was pretty hard when the landed and i was able to just brush them off ;D Then today it was time for the black went on well and i am pretty chuffed with it. then on with it and the grill and side light/indicators and on with the bonnet Then it was time to sort the water leak. Armed with a new seal, Owen set too it and it was soon leak proof again With it all warmed up, it was time for the road test Didn't go as planned the cam timing was out by 3 teeth so it died on any more than about 1/4 throttle. back to the lock up, cam re-timed and ready for test drive mk2. This time it went very well :-D The only torque steer was pulling off in 1st when the wheel span up, but as soon as it had traction, it pulled dead straight And it does go rather well ;D So now it is back in side and crack on with all the remaining job before it can hit the road properly. Gaz should have the vids loaded soon as well
craig1010cc
And the vid
craig1010cc
Jun 13, 2009 18:35:42 GMT
Well, a bit of progress over the last few days Managed to get my head round most of the Vaux dials wiring loom, no where near as easy to follow as a mini diagram. so I now have a set of tigra dials with working rev counter, fuel gauge (albeit backwards so need to reverse the plugs at the sender), temp gauge (but that did seem to warm up quick, will have to investigate further when on the road and a bit more clearance around the sender), main beam tell tail and no charge tell-tail (alternator). Just can't find the oil pressure wire from the engine loom and get the indicators or dash ilumination to work. but I have ways around those so that isn't a big prob. Also made up the mounts for the dash pod and drilled the hole for the speedo cable and drilled and screwed on the bonnet pins So a few more jobs ticked off the list hope to have the wiring finished soon and crack on with the jobs needed to get it finished for the road and track ;D
Jun 13, 2009 19:01:34 GMT
Tsk tsk, driving on the road with no mot........ what would the neighbours say ;D
craig1010cc
all on private property of course, just a very busy bit of private property But in all seriousness it does still have an MOT from when I took it off the road, but there isn't that long to run on it and before I start using it I like the reassurance that it has been checked over by some one else and they are happy that the work I have done is to a safe standard.
lae
Jun 14, 2009 13:18:34 GMT
Just read the whole thread, very cool work sir. Got me hankering after a Mini now (another car I can't afford. Gah)
Currently: Mk1 Focus blandmobile
Formerly: 1969 MG Midget 1972 Avenger GT 1981 Datsun Cherry 1989 Corolla 1979 Mercedes W123 200D 1995 Ford Falcon 1996 Ford Telstar (bet you had to google that one)
craig1010cc
Jun 14, 2009 18:48:20 GMT
Just read the whole thread, very cool work sir. Got me hankering after a Mini now (another car I can't afford. Gah) That must have taken a bit, but thanks They are quite addictive little things minis
craig1010cc
Jun 15, 2009 21:32:39 GMT
A most productive evening tonight Owen was up so we cracked on under the bonnet 1st up was the rad mounts. Some curved tube was cut to size, and then out with the MIG That sorted the bottom mounts out a treat. Then a flat plate was cut, bent and drilled to make a removable top mount All looked good, but would the front go back on........... YES So on with more fab'ing. This time the header tank mounts. Again more flat plate was bent, drilled and welded and we soon had this jobs a good'n. So we put him back together, a job well done
