Davenger
It's only metal
Club RR Member Number: 140
Oct 10, 2012 18:12:49 GMT
Last Edit: Oct 10, 2012 18:13:51 GMT by Davenger
Davenger
It's only metal
Oct 18, 2012 18:10:40 GMT
OK Headlights now work again, dodgy earth wire. Cleaned out fuel filter and pump, still broke down. Replaced carburettor, still broke down, only further away this time. Think I need to flush the fuel tank and start from scratch
Oct 18, 2012 19:45:44 GMT
Maybe its suffering from Rootes fuel tank syndrome? If there's a load of the paint/coating they used floating around inside the tank it could be clogging the pick up though when mine did that there was always enough flow for it to idle but not run under load.
Also I would personally stick with traditional points ignition when trying to trace a fault like this.
Davenger
It's only metal
Oct 18, 2012 21:02:58 GMT
That's exactly what it's doing. The electronic ignition has made an amazing difference to the way it runs. I just need to start from scratch, flush the tank and make the git work properly
Davenger
It's only metal
Oct 23, 2012 20:46:15 GMT
Poor old thing still doesn't run right, not had a chance to flush the tank yet. But I did fit this, which pleased me greatly ;D
Davenger
It's only metal
Oct 25, 2012 18:25:39 GMT
Dropped the fuel tank out today. 2 bolts, 2 nuts, 2 pipes and a wire was all it took Rinsed the tank out and flushed the fuel lines out. Loads of gunk came out of the lines, and the fuel that came out of the tank had it's fair share of gunge too Cleaned the tank up, gave it some paint and popped it back in So. Took it for a drive round my usual test route. Didn't brake down once ;D
Oct 25, 2012 19:11:14 GMT
Good news!
That looks just like the Rootes 'black death' gunge I had. You've got a fuel filter somewhere haven't you? Keep an eye on it in case more of it loosens off and makes its way though.
Davenger
It's only metal
Oct 25, 2012 19:55:50 GMT
It's odd really The inside of the tank was completely bare metal. The fuel line was completely blocked up, the floor was covered in curse word after I blew it through
Davenger
It's only metal
Oct 26, 2012 18:52:19 GMT
I've come to the conclusion that it's rust from the filler neck that's been causing my problems. Have to see if new ones are available, as it's detatchable. Failing that, clean it up as best I can
Davenger
It's only metal
Had a low rev misfire, traced it to a loose sensor on the distributor. That's what happens when you do up screws with a pen knife. Since then, I've just been using any excuse to drive it ;D
Nov 10, 2012 10:25:25 GMT
It's probably wrong that I love the way this looks right now, takes me right back to being a little kid again.
Nov 10, 2012 20:27:54 GMT
It's probably wrong that I love the way this looks right now, takes me right back to being a little kid again. When I was a kid in the 80s I was always impressed by the fuel filler below the boot slam panel. Thought that was mega cool.
Davenger
It's only metal
Nov 10, 2012 22:17:00 GMT
It just needs to be a little lower at the front. There's loads of little details that make the avenger cool. the fuel filler, the rear lights, the strip speedo, that fact that it had a 4 lin rear end when ford were still using leaf springs etc etc I love it. Went for a little drive tonight, just because I can
Pleased to see you've got the running issues sorted Looks damned tasty in this pic
Davenger
It's only metal
Nov 11, 2012 11:53:40 GMT
Cheers dude
v8jim
Nov 11, 2012 15:10:01 GMT
I second that,damned tasty in fact I've just sat and read the whole story from the beginning
Max sig pic size: 80px
Davenger
It's only metal
Nov 11, 2012 18:19:11 GMT
Stripped the dash out, to get to the heater matrix because I thought it was leaking. When I first got the car, a pool of green fluid appeared in the drivers footwell. Got the flipping thing out, and there's nothing wrong with it Then it got too dark to put it all back together. BUMHATS!
Nov 13, 2012 13:47:25 GMT
If you still have the dash out, just check the wipewasher axle rubbers. It tends to crack and leak when raining hard. It has been leaking in mine since ever. Maybe you can put there some silicone sealing.
FJSigma
1989 Volkswagen VW1500 (The argentinian Avenger)
Davenger
It's only metal
Nov 13, 2012 18:56:21 GMT
Cheers for the tip dude. I'll have a look when I get some daylight
luckygti
I need to try harder!
Nov 14, 2012 21:29:13 GMT
Looking good Dave, glad its running ok. Know what you mean about just going for a drive, took the 205 out earlier, what a hoot
