Feb 25, 2009 19:17:34 GMT
na just a bit of cut chop and weld ,,,cost me 50 for the bits and about 15quid in elecy/wire and gas lol just made a start on the gearbox mount ,, bit fiddley but found a way around it ,useing the oringal place of the mk1 mounting bolts roughly how the standard mount modifyed to it ,,(ill also be adding a bit more metal to mount ,,which ill sort 2moz,,,
Last Edit: Feb 25, 2009 19:20:19 GMT by adaptorman
Feb 26, 2009 19:38:01 GMT
had to change the mount it wouldnt fit lol sorted then the dam bolts sheared off so time to tap a bigger one in there then ,its tight but it fits lol carnt see that shifting anyway soon decided to make a wiper arm ,,works fine too
sparko
Feb 26, 2009 21:43:16 GMT
you are an inspiration and a LEGEND!!!!
Speedle
Feb 27, 2009 11:00:01 GMT
as above your metalwork and welding skills are of the highest degree of awesome!
Feb 28, 2009 19:16:33 GMT
cheers speedle ,it ill do ,,lol ,,
small update ,,i had a problem with the engine which tuck most of the dam day to solove as my injectors stuck open ,after a changing some wireing and settings on the standalone ecu ,i got the chuff to idiol and rev ,at last ,still in the early stages but its all progress i reckon ,,videos a bit dark and horried alti belt makeing a noise but u can hear the buggar lol tinypic.com/player.php?v=30vd81z&s=5
ghetto
you my man r a true legend what a amazing truck u have their i cant wait to see this finished
well i wil keep getting a few bits done here and there lol,what may happern will be another story ,i know it wont be a problem gettinga 400bhp from it ,and some more but i think the tyres will start to burn lmao
looking great. a real different idea. can't wait to see it done.
had a few hours spare so decided to get some bits sorted first bit of inner wing welding then had to make a differnert bottom inner sill ,due to my exhaust has to run under it then added some heat wrap to keep the heat temps down a bit had to order some more ,,,too ,as it soon runs out lol then added some front brake flexis and made some new copper brake pipes then just had time to make a new door bottom and repair door
Love your style Adaptorman, you work at 100mph, and nothing is a problem, only another challenge
Great work I will follow this thread to the end
Tony
cheer tony ,,,i try ,,, and adapt ,,,no point in sat there scrating my nut lol ,ps nice bm restro youve got going on there too.....
thought id rip the other side out and bob a plate in and thow some brake pipes in and as I'm awaiting a few parts ,i decieded to solider a few joints
just looking at that birds nest of colours makes me feel ill....
fair play on hearing her run, love the vr6 sound...
wonder how one would sound under the bonnet of the sceptre sometimes...
it should sound better once all the squicks and leaks are sorted ,, and all ull hear is a turbo whistle ,dumpvalve /nice induction roar ,, and a humble side pipe sound ,,all in one ,,lol
done the downpipe and started on abit of wireing
are you running the original servo and MC? Caddy's and Mk1's are renowned for their vagueness in terms of pedal feel; I'm going to run a big B3 get passat servo and 22mm t4 transporter 4 outlet m/c; and alternative to the late mk2 GTI servo and m/c (comes with 4 outlets from GSF)....
Last Edit: Mar 6, 2009 20:58:06 GMT by blzeedub
The standard master cylinder and servo will not cope with the bigger brakes you've fitted.
Matt
cheers for the replys guys ,due to wanting to get more welding and strengh into it ,,id sooner be aiming for a old airfield ,,to give it a few blasts,,
Continues to be an amazing and inspiring build this.
