Apr 17, 2010 21:04:13 GMT
crashtestmatt
don't worry I crash better than anyone I know
Apr 18, 2010 19:16:20 GMT
Hell of a lot of impressive work there mate, I've just had a very interesting 42 page read ;D As someone who can just about hold their own welding bodywork, but has no idea how to START doing this kind of work on a water-cooled motor, I find this kind of thing mind blowing Just a quick question (sorry if it's been asked before), how does all the work on the underside of the body stand with the new rules on modifying a monocoque? It appears you did the bulk of the work before this point, but I wondered if you knew. Anyway, I can't wait for the next installment.........
"Modern cars, they all look like electric shavers."
cheers I'm happy with this rather then a 24v at mo tbh , I'm a little unsure what u mean regards monocoque?if u can explain a little more in detail ill let u know , unless u mean regards mot, insurance etc ? or wheather its something to do with strengh ?
Apr 22, 2010 13:15:50 GMT
Hi, i think crashtestmatt may be referring to the rules on modifying and registering of substantially modified or rebuilt vehicles, I apologies for jumping in if hes not, but its still worth being aware. DVLA give points for 'unmodified' and retained parts, 5 - body shell/chassis 2 - suspension 2 - axles 2 - transmission 2 - steering 1 - engine to retain the original Id and reg number you have to achieve at least 8. so in your case even if you discount altering the shell the max would be 5, so in the eyes of dvla your vehicle may not be considered the same vehicle as originally registered, Its substantially altered. It may also be required to under go an SVA test to register it. However, i take it its already registered in UK, its not an import so I'm not sure how the regulations apply, as you obviously don't need to 're register' it, or do you??. Unless DVLA are informed of major changes how do they know. You are I believe legally required to inform them if you change for instance the colour, engine size and fuel type to up date your V5. Again if you don't, which I'm obviously not suggesting, how will they know, but it may also affect insurance etc. One point is changing from Diesel to Petrol will obviously change the data input during an MOT and emissions test. With all the computerization are the VOSA and DVLA systems linked, Ive no idea. Its an issue I think just to be aware of and probably applies to lots of vehicles on this site,
Some one else may know and be able to advise.
In the mean time keep up the good work. will it be done for this summer!
crashtestmatt
Apr 27, 2010 18:08:47 GMT
Yeah, that's what I meant. Cheers Voyager for putting it into plain English for me ;D I'm not wanting to demean your Caddy in any way Adaptorman. As I've said, I think it's awesome, just curious as I have this vision in my head of a rear wheel drive Golf
Apr 27, 2010 19:38:19 GMT
hi pal right heres what ive done sent the log book off as a 2.8 turbo 4wd turbo had a engineers port , ( and have the paper work) regards sva , the chassi hasnt been removed just modifyed too , main bit witch is legal is the side pipe ........, had to remove it for the mot, i also went to vosa to ask about my car they stated , theys nothing they would do , long as the vechical is tax tested and insured correctly , ive emailed the insurance a full list of every modification of the car , hope this helps engines runing very well at 15psi at mo , oil temps, oil pressure, afr, timing, fueling map best its been so far ,, so thought id treat the caddy to another homemade header tank , made from alloy , as ebay prices are a dam rip off think ill make a quick water bottle 2moz too ,, fills a hole lol
Apr 28, 2010 20:25:48 GMT
also made a quick water bottle too , got a bit carryed away after making a header :laughing:
crashtestmatt
Apr 28, 2010 23:51:13 GMT
I love the look of those tanks ;D and cheers for the info
Stone the crows, Christ on a bike and some other suprised sayings - .....this is frickin AWESOME!!!!! Truly in awe of your skills there dude - massive win factor! I like the thought of this thread being watched in the states as well - this is pro modification done by one dude in a shed - makes me proud to be part of the vehicle modding crowd. Keep it up!
Apr 29, 2010 17:08:15 GMT
cheers well i jst have go , seems to work and saves a few quid not mutch to add so made another for the brake fluid , I'm in two minds wheather i like it thow , then decided to skim some alloy down and make a start on the new engine mounts,
Apr 30, 2010 18:09:01 GMT
had a thought today ,(yes another lol) about a post eailer in the therd , about wheel banding , so i tryed one , prob is i really need 17inch 7.5j rims hard to find , so i tryed one on 6.5j rims 15inch heres how it looks standard ones fit sound as stock on the front heres a quick pic and no rim cutting needed evern made a jig to re line the rims ,, unsure what to do , asi like how they fit on the fronts, as the tyes wount catch the archers when i slam it
Apr 30, 2010 19:45:54 GMT
standard fronts and altered rears? works for me! still in awe of your skills AM - very inspirational
wanted, 25th hour. Required daily, cash waiting
yearh not a hard job , simple remove the inner welds turn rim , refit and aline with either a homemade jig , ..i.e wheel hub, lump of steel and a vice to pull the alinment in shape etc then tack weld unitl wheel centres leval,then either mig weld up or tig , long as its correct and a decent weld is replaced its spot on ............if ur unsure then pay 450 quid ,,,,,for 4 wheels banning to ur needs, i thought , might as well do mine myself ,, hour a wheel tops
427
Praise The Lowered
Every time i look at the updates you have for this build i still get dumb struck at how good you fabrication skills are. I'd be running the staggered wheels, dished on the back and stock on the front. I think the steel wheels suit the ute more then mags.
hi 427 carnt really do it on the fronts due to hub and arch clearance , prob is also i have to keep same size tyres all theway around for the 4wd ratio,so though keep stand rims , but just change rear rims so i don't need 40mm spaces and still have a dish , going to thow a 205 50 16 on see how it looks , i do fancy 215 45 16 which should fill the archers nicely ,,
thew a couple of tyres on to see how they look , still in 2minds wheather i should keep alloys or run these had to fit 205 50 16 couple of pics as it gives me a idea now ,that i need to pull the offset of the rear rims in a bit more to miss the inner archers
well went for a little tunie yesterday and up at 20psi with no probs so i reckon she needs a bit more , as I'm chuffed with the home custom piston skiming working a dam treat
Nice work again. I love the steels, just wrap them on some R888's ;D
kee
like the steels. you at the meadowhall retail park meet tonight?
cheers guys ill get to the next meet ,, been a tad bisy right mamaged to fit 225 40 16 on the fronts and rears , extra bit of rubber , and finish the rears off, should be wide enoegh check front wing clearance everything clears tempory rear fit
