Dec 13, 2008 10:41:32 GMT
Hi as title. I'm in the process of fitting a 1.8 Nissan Slivia turbo engine (single over head cam version S12) in my Anglia estate ... problem is it's an auto as such I need the manual flywheel. I have gearbox etc. I'm also in need of a clutch slave cylinder although not as important. I'm based in West Yorkshire but can arrange courier if your happy to box up etc.. Thanks for looking
Last Edit: Mar 2, 2009 6:22:54 GMT by Oldbus
beany
Hmmmmm
Dec 13, 2008 17:18:51 GMT
Maximum signature image height = 80 pixels
Dec 13, 2008 17:50:50 GMT
have you got the plate thing that goes behind the flywheel too? check it has a spigot bush also.
Probably got a slave cyl somewhere if you get stuck
75 Range Rover 2 door 82 Range Rover 4 door 84 Range Rover 4 door 78 Datsun 120Y 2 door 78 Datsun 620 Pickup 81 Datsun Urvan E23 86 Datsun Vanette van 98 Electric Citroen Berlingo 00 Electric Peugeot Partner 02 Electric Citroen Berlingo 04 Berlingo Multispace petrol 07 Land Rover 130 15 Nissan E-NV200 15 Fiat Ducato
Dec 13, 2008 19:46:31 GMT
Yes tried there first - very helpful and sorted me with most of the bits I need. have you got the plate thing that goes behind the flywheel too? check it has a spigot bush also. Probably got a slave cyl somewhere if you get stuck The engine I have is out of an auto so i'm unsure exactly what i'll need. I have the clutch and gearbox. this is the picture of the engine 'as is' If you have a slave cylinder, cheers let me know
Thought i'd bump this thread up - I'm still after the above parts if anyone can help. I thought i'd sourced em via Nissan Silvia site but the chap never got back in touch with me having gone through what I have I also need a starter, Crankshaft pulley, Cambelt cover complete and a manual Transmisson ECU. I would consider buying a whole car - crashed / smashed/ rotten etc but must be manual transmission and can collect within say 100 miles of Wakefield West Yorkshire. Or does anyone know of one in a scrap yard in my area Any help greatly received as i'm nearly at the position to get this lot trial fitted..
