lund
Aug 26, 2009 12:47:34 GMT
Hi Finlay if you look back through the thread there are some pics of how I did the arches, they are rivetted and then fibreglassed to the body and then blended in. Cheers mate, getting there, don't know how it drives yet as all the little bits and pieces are still getting done (electrics, plumbing etc..) I'm fairly certain its going to be an absolute animal though!! Glad yours is getting there dude! Yeah, in my case its 1 step forwards and 2 steps back, it suddenly dawned on me that I forgot to oil the crankshaft oil seal, so had to re-split the engine and gearbox which is abit of a curse word to do as its so heavy! I'm more than sure that this will be an animal! Best of luck with it, catch up soon.
Aug 28, 2009 11:35:20 GMT
Ok, so rad in, intercooler in, all the front panel modded to take the new intake pipes, ECU bolted up and igniter all bolted in and wired up. Probably 60% wiring done.. Slow but sure! Bonnet now shuts as I modded the inner frame so its nice and snug! Matrix pipes sorted, fuel tank back in.... My internet is bust so cant upload new pic just yet. Cheers! (and thanks to Roy and Tim for help with electrics!)
Sept 13, 2009 10:28:16 GMT
'86 Capri Turbo BenzBoy
@benzboy
Club Retro Rides Member 7
Sept 13, 2009 15:08:24 GMT
Just read the whole thread - absolutely fantastic work! This car is really cool, and the Nissan lump just makes it that little bit cooler still. I see you're doing most of the work outside too - I feel your pain! I have a similar situation! ;D Looking forward to a video of it firing up!
Sept 13, 2009 15:41:02 GMT
Cheers dude! Yeah, having to work outside for the most of it, the nights drawing in are a worry! Hoping it'll be done soon, I'm looking forward to a video of it firing up too!!
Sept 14, 2009 14:19:37 GMT
Just sorted my fuel lines, they'll be with me tomorro, insurers are very reasonable too, just got off the phone, very relieved - I was having palpatations when I was on hold that I'd never be able to drive it again due to some silly insurance premium - but all good Tonights work - hopefully have pump and filter bolted in place and the fuse box under dash secured and wiring hidden away.... I shall update as to my success
Steve
Sept 14, 2009 17:34:53 GMT
Quality motor! Very much liking the choice of engine
Sept 17, 2009 7:57:40 GMT
Hooked battery up this morning just to see how I'd done elcetrically, I was somewhat apprehensive (read cacking myself) and kept checking for smoke and hot things - all seemed well, SX clock on! Warning lights came on, flicked the key and she turned over!! Yeah baby.... Hopefully sort out fuel pump wires tonight and see if I can get her running...
@benzboy
Sept 17, 2009 10:06:56 GMT
Excellent! Can't be far off running now!
Potter
'E who dares wins,eh Rodders??!
Sept 17, 2009 17:20:53 GMT
It keeps getting better mate!! Don't forget a starting vid and more importantly a number 11 vid!! ;D
More cars than sense or money!🙄
nizzer
Sept 17, 2009 19:16:26 GMT
do yourself a massive favour and ditch the dumpvalve, will give you loads of running problems. the turbo chatter is enough to make you wet yourself anyway
Sept 18, 2009 7:43:21 GMT
sparko
Sept 18, 2009 8:16:17 GMT
ha ha love it! looking good chap, now get some sideways vids
Sept 18, 2009 14:05:44 GMT
Absolutely brilliant! Loving the smile and thumbs up to the camera.
Sept 18, 2009 18:17:44 GMT
Just got the anti roll bar back on with my new TCA poly bushes, moved it over on the drive so I can get in the drivers footwell and put the pedal box back in. All systems go! don't know what to do about an exhaust at the moment though! I think I can butcher my cherry bomb into a side exit which - obviously - would be very cool, but I think it might be too loud for using it every day. I might wait till I havesorted everything else, tow it to my welding mates house, give him my ashely middle and back box and get him to link them all up..
Sept 18, 2009 18:19:13 GMT
Alright Nizzer, what will the dump valve cause in terms of bad running? Oh and how long are these bad boys supposed to rev at 2000rpm from cold as it doesnt seem to want to drop but I only had it running 5 minutes due to the noise
nizzer
Sept 18, 2009 21:51:23 GMT
because it runs an afm there is a metered amount of air in the interooler and piping, when you back off the d/v releases the air but the ecu still fuels for that amount of air that has just been released. so when you get back on the throttle theres loads of fuel and no air leaving you with a massive flat spot and then a big pop and flame and off you go again. Very annoying if your trying to get through the gears a bit quick while embarrasing a poncy porsche A lot also boost leak and generally cause bad running like idling high mine always idles around 1700rpm for quite a while its normal to be on choke for a long time but just make sure you have no leaks in your i/c piping or vacuum lines.
@benzboy
Sept 18, 2009 23:09:43 GMT
Absolutely brilliant mate, love it! Plans for the Cherry Bomb sound cool, but like you say, might be a bit impractical every day.
Last Edit: Sept 18, 2009 23:11:56 GMT by BenzBoy
Sept 19, 2009 20:07:26 GMT
Managed to get the pedal box and steering column back on today, finished the electrics, fitted the clutch master cylinder and made a copper hydraulic pipe bled the system etc.. I have a clutch!! The Capri officially moved under the power of Nissan today! Unfortunately not sorted the accelerator pedal yet so it only moved a bit but it still moved!
Sept 21, 2009 9:21:06 GMT
Well done Dave! finish it up get out and enjoy!
