ozzy
been sortin my lock up out. carter carb. I got this to get me to a show and it worked ok on my 308 v8 in my old 2nd gen camaro needs cleaning up. £25ono ( possibly sold ) ford 2L carb not used for a long time £10 S/steel back box. it was for a golf mk3 twin exit. could be good for putting 2 pipes on your car. £10 v8 air filter. has some rust. £5 ( sold ) facet fuel pump. works ok make me a offer micro dynamics rev limiter. no wires just the box. make me a offer ( possibly sold ) thats it for now. I am sortin my shed out tomorow so will add more parts.
Last Edit: Apr 21, 2009 11:07:59 GMT by HoTWire
1985 GMC camper family wagon 1989 nissan sunny 1994 fiat cinq my boys car
kee
ford inlet and carb looks like a pre-crossflow to me
ozzy
thanks I have updated the add
sowen
Club RR Member Number: 24
You have a pm
ozzy
thanks.
the boost gauge and the ford inlet with carb are possibly sold
hi i will take the ford 2lt carb £15 posted send me address for money ;D
life is to short to worry about money live long die skint
rs2kpete
Old FORDs Never die they just get faster
pre cross flow one looks like a 1500 GT mk1 cortina weber 28/36 DCD
Apr 10, 2009 13:51:13 GMT
any idea which model the Carter carb is? Should have some numbers on it somewhere? I'm provisionally interested, subject to it being somethign I can use!
Apr 10, 2009 16:13:50 GMT
do you know if the carter carb would work on a 350? also is it an electric choke?
ozzy
Apr 10, 2009 18:57:09 GMT
the carter carb is still at my lock up so will have a look on sunday and let you know what the number is.
also it is a electric choke but I don't know if it works as I did not wire it up. I only needed it to go 8 miles from my old mans place to billing to a show. it woked ok on my 308 that had some work done to it so it could well work on a 350. remeber tho it will need a clean out now as it has not been used for 2 years.
ozzy
Apr 10, 2009 20:52:19 GMT
c90 chop frame. it had a kmx off road front end. never been on the road so no v5 £20 ford crossflow inlet £10 vauxhall victor fb airfilter ( no air filter in it) sanded down for re-paint £10 holly 600cmf parts job lot £10 ( possibly sold )
Last Edit: Apr 11, 2009 10:28:21 GMT by ozzy
burns
Apr 10, 2009 22:27:49 GMT
I'll take those holley parts if there's a usable base plate in there. You have PM.
ozzy
Apr 10, 2009 23:16:25 GMT
thanks pm back both of them should be ok
ozzy
Apr 11, 2009 21:41:13 GMT
last bits to go on here for now. piper fast road oil pump. to fit a ford cross flow. brand new in box never fitted. cost alot when I got it. make me a offer. full set of 4 corsa alloys. tyres ok £40 full set of 4 ford 14" usa 4 stud wheels. will look cool with chrome hub caps. I think they fit uk fords aswell. tyres are no good £40 2 x rage 5" back boxes. 1 used for about a year. 1 used for 6 months £50 the pair.
ozzy
Apr 12, 2009 23:37:49 GMT
I have the carter carb in the boot of me car and will post up the part numbers tomorow if I get the time.
ozzy
Apr 13, 2009 23:31:54 GMT
right ok for the people that wanted to know the part numbers for the carter carb.
I have it here in fron of me and on the top it has the number 2312 this is next to the auto choke.
on front side it says carter AFB and made in the usa.
on the other side it has the number j7 9625 a
and on the side it has the number O- 1882
I can not see any other numbers on it so I hope this helps
Apr 14, 2009 14:35:23 GMT
Is a carter carb the same base pattern as a holley?
I'm looking for a 465 holley but if that ran a 305 it must be about the same flow rate, any ideas?
Edit to say a quick google search showed me that the numbers you got show the flow.
J7 9625 a means 625CFM Too big for me... Thanks anyhow
Last Edit: Apr 14, 2009 14:41:04 GMT by MightyMork
ozzy
Apr 14, 2009 17:26:53 GMT
thanks for the info mate. and also it will fit the same as a holly
Apr 15, 2009 21:13:50 GMT
you have PM
ozzy
Apr 15, 2009 22:54:07 GMT
thanks mate sorry you mist it. but I will let you know if it don't sell.
