engine..? gearbox...? that's exciting hintiness!
I'm all fizzy with excitement reading through build threads tonight, it's great! I'm bouyed up with enthusiasm for my own build.
hairymel
avatar by volksangyl
Club RR Member Number: 207
Hey Angyl engine and g/b are this (pic from ebay) from a 35k mile sunbeam only a 1.3 but will mean a lot quicker return to the road, driving fast can wait not added to build cost yet as I am pretending its not hidden in the yard under a tarp. must get it shifted ;D glad to see that you are still progressing with the polo, I like your idea with the grill
Last Edit: Jan 11, 2012 1:57:53 GMT by hairymel
whats that burning smell?
oh curse word :-(
hairymel
last couple of nights i have managed to steal a few hours on the car. stripped the rest of the clutter from the engine bay and a fair bit of the cabin making a small pile of bits bit rotten and damaged battery tray (hacked ) out bit of damaged caused by chiseling the spotwelded flanges off. not great access for a grinder and my home made spot weld drill did not seem to be effective this time, so brute force was used. there are tears in the inner wing on the top corners and the bottom left of the above pic. nothing a bit of bash bash weld weld can't fix interestingly the paint on outside of the wing has flaked off at the trauma site. on closer investigation the epoxy has flaked in chunks but its actually the oem paint and dip coat that has lifted off leaving bare metal. too late tonight to contemplate the ramifications of this, i will have a think later although its a bit late now if i decide its a bad thing the hole i poked through when repairing the valence bottom is now more exposed. the chassis rail top and the top of the inkwell (below rad) panel are toast I cant see a easy way of accessing the area for a tidy repair as the d/s rad support is in the way. it looks to be needing the valance removing - this will not be happening i foresee an ugly grinding incident causing some of the rad support to relocate itself off the car unless i can come up with something a bit less drastic total time spent ( spanner spanner, chisel chisel ) 306 hours total spend £1712 ( newly discovered box of latex gloves bought in the long distant past so not included, have also found mig neck spring lost misplaced a while ago and some sanding belts that have only been missing for a month engine/box not included yet, still under a tarp )
oh curse word :-(
bstardchild
Club RR Member Number: 71
Jan 11, 2012 18:28:46 GMT
Blimey an engine appears the car is up the right way and you're fussing about a bit of flaky paint - you aren't going all concours on us are you hairymel?
Jan 11, 2012 23:26:06 GMT
I'm glad I haven't clocked the hours on the escort
"No............I think I'll stick with the Maxi"
Arther Daley
hairymel
Jan 11, 2012 23:58:34 GMT
bstardchild - i am a little concerned that the oil rig paint may sway a few judges at pebble beach to drop a point or two the jotun epoxymastic is a bit rubbery when left to set in the paint pot, but seems to be quite hard and brittle on the panel. it certainly sticks like **** as where the metal has torn and bent the paint has come off in 6-8mm chunks but all the paint layers have lifted in one leaving bare metal. the engine doesn't have matching numbers either, but is so far away from the engine bay, i think i may get away with it thetattoostudio - its not the hours or the money that gets me its the fact i thought i would be finished by the rr gathering in august 2010
oh curse word :-(
Jan 27, 2012 19:34:07 GMT
horizon is a completely different car.
theres more to life than mpg & to much power is just enough.
hairymel
wow - dragged back up from page 16 been very busy since jan 11th, but not with the sunbeam usual seasonal rush at work and my partners mondeo needing a fair amount of remedial work (most of the front suspension, inner+outer rear of sill, complete washer system refurb and a good service) took up most of my time. then my bosses sons matiz filled its engine to the top of its rocker cover with water and expired. i foolishly put it in my unit to repair in works time. it was still there outside of office hours - so no space to work on the sunbeam until it was finished my boss was so impressed that i could fix his boys matiz he bought a pink(!) matiz with mashed valves to keep me busy this one has been refused entry, so its being repaired in the yard not so comfy in the day but i get to claim my unit back ;D as usual inertia is a killer so i have made a concerted effort to get something done this week. i have not been very successful, but its a start using my new but still broken mig i filled in the holes left by my less than sympathetic removal of the battery tray where i bashed flat the inner wing the epoxy has lifted again. it seems to be very stiff so when the metal moves the paint stays where it is until the underlying paint lifts off the metal still not sure what to make of it as predicted the rad support panel succumbed to a tickle from the angry grinder, allowing further rotary mayhem in the area of the chassis leg/inkwell panel. inkwell panel filled in top of chassis leg filled in the d/s strut top had the telltale pimple showing a eruption of rust between the wingtop and the cup. cutty cutty the right hand lump is the chunk of rust. corrosion seems to start at the spot welds and then eat upwards. doused in weld through primer weldy weld (twang curse word) got the puddle weld very wrong and i was treated to a solid twang noise as it cooled and pulled away thats why the above pic has a hole drilled in the puddle grindy grindy sploshy jollop and that's where i'm at. mon, tue wed 2 hrs a night thursday pub friday bit ill ;D tomorrow is another day total time spent (.)titting about(.) 312 hours total spend £1712 ( newly discovered box of latex gloves bought in the long distant past so not included latex gloves all used on the matiz , have not included new mig, 0.6+0.8 mig wire ,tips etc . loads of cutting discs not included yet. new boc contract+bottle not included yet. loads of stuff i haven't thought about not added yet. i must have a chat to my accountant! engine/box not included yet, still under a tarp but now outside the roller shutter ;D )
oh curse word :-(
^What he said! You have PM, btw.
did the shell come with V5, reg number etc?
drdick
Read most of this thread mate, you are making my 10 year efforts to not restore a Mustang look even worse than they already are. I'll have to come and have a look at this beast some time. Whats that rather sad looking welder? You can borrow my Murex if you want, guaranteed to weld everything to everything even on low setting!
More updates!
Mel this an amazing thread! Keep up the progress, every update you make is edging this collection tatty metal scraps towards something car shaped!
I tip my Hat to you, sir!
hairymel
sorry nothing to report, except i have spent the last 4 months covered in grease and have touched the beam for a total of 6hrs. taken 3 days of work this week to get some quality time in and have spent it all pi$$ing about with my megane welcome to RR drdick even though you only joined up cos i was ignoring your phone calls ps its bad form to try to slag off my tools when you want to ponce borrow my plasma cutter
oh curse word :-(
drdick
I've come to this a bit late for whatever reason (all that London living and what have you) but I did find this sad little snippet from June 2010: funnily enough I paid 1040 for my recently rebuilt ti back in 1992 and sold it in 97 ish for 60 to a mate just to get some driveway back
he took the carbs off and left it in a field until it got fragged, really regret it now I'm afraid it was me that did that but I guess it didn't seem important at the time, after all can't be hard to find a Sunbeam can it.....................? Maybe I can make it up to you by finding a ti engine? Either way I can't wait to actually have a look at this beast next week (yes, when I come to ponce a loan of your plasma cutter!).
Speedle
Awesome really gald to see some action again in this thread! Nice to see it back on page 1 where it belongs Keep up the good work chap!
hairymel
because i am hacked off with meganes due to public demand i decided that i would take a much needed break from my holiday car repairs and hide in the unit i have had a massive tidy up , spread over the last week, which means i can actually get in the door and walk around the beam, and even managed to put my tools away in my newtome topbox/rollcab (acquired 2 months ago ) last month i was here this brand of rust converter also converts fresh metal to rust! bottom 2" of the rad support panel i chopped out was very thin and i had cut off the return flange at the bottom to remove it repair section provided by mercedes light freight with a bit of grinder and hammer action i managed to fettle a repair piece that was almost but not quite something like it you may notice that i ballsed up left a nice air gap here to aid penetration ;D giant lump of copper buss bar from a previous life was recently found, so pressed into use here a wizz over with the powerfile to remove rust and paint the local area got a dose of drill+wire brush and powerfile to clean off as much paint and rust as possible. then a coat of screwfix no nonsense galvanizing spray. same treatment for the repaired section i was fairly pleased with this (apart from the non standard half moon hole, but not too worried about tonybmws concours judges ) welded back in as you can see the repair that i was so pleased with has been compromised by the shoddy welding in hopefully it will look a little better when i go back to it for titivating ' til next time its got a coat of paint though thats all for now, i had hoped for more pics to pad the post out but i seem to have misplaced them. you all know what a sprinter wing and some hammers looks like though ;D total time spent not fixing matiz's or failing to fix meganes 316 hours total spend £1712 . this is now wildly out of date/innacurate and i need to spend an evening just playing catchup
oh curse word :-(
hairymel
deano - chassis tags only, but a very nice man hpi'ed the chassis no. and i now have the reg to apply for a v5 rich - not to worry - many a car has passed through my hands never to roll again, i miss the rapide coupe as well speedle - thanks , I hope to keep on keeping on
oh curse word :-(
Good to see this progressing again Mel,I have the chammy all painted in the garage awaiting completion but life just keeps getting in the way so I know what you mean! ;D ;D
