Frankenhealey
Club RR Member Number: 15
Jun 18, 2018 13:56:15 GMT
Are you sure the oil leak isn't caused by sheep or indeed rodent damage given it has started with no mechanical activity? Lack of use is the most likely culprit, no sheep could squeeze inside the bellhousing and as the seal is in a top hat structure so no rat either. The shade tree mechanics society is getting together tonight to brainstorm a solution. The first ten minutes will involve the use of large dirigibles or a 7.5 tonne rotisserie and be discounted and then we'll come up with a solution before it's my turn for a round. It's like Countdown but there's serious money involved and sadly none of the barmaids look like Rachel Riley.
Jun 18, 2018 14:48:07 GMT
Industrial seesaw using RSJ's and the Fergie? unless the local farmer has something more heroic? Good luck and don't forget the pictures
Jun 18, 2018 15:10:19 GMT
Lack of use would indicate a hose split? as such an easy (ish) repair?
Frankenhealey
Jun 18, 2018 17:25:00 GMT
Lack of use would indicate a hose split? as such an easy (ish) repair? No hose on this box. It's dripping from the clutch housing. It's EP80 and unless the casing is cracked (and we won't go there) then it's the input shaft seal. We've got one ordered so it's fingers crossed.
Jun 18, 2018 21:36:04 GMT
so what we talking here, a couple sheets of OSB board slid under and some brave pills ? or borrow some of those road plates they stick over holes in the ground at street road works.
Last Edit: Jun 18, 2018 21:37:21 GMT by darrenh
Jun 18, 2018 21:40:54 GMT
Surely you need a big tree, a couple of strops , a snatch block, some cable and a suitable tow vehicle.
Last Edit: Jun 18, 2018 21:43:41 GMT by dadstaxi
Frankenhealey
Jun 18, 2018 21:46:26 GMT
so what we talking here, a couple sheets of OSB board slid under and some brave pills ? or borrow some of those road plates they stick over holes in the ground at street road works. You, my dear sir, are prescient. 3 x 15mm sheets of OSB board stacked on top of each other have been accurately calculated to take the load. The meeting of the Purbeck Society of Shade Tree and Bush Mechanics is now in recess until the next problem. We are still go(ish) for MOT.
bstardchild
Club RR Member Number: 71
Jun 18, 2018 22:31:19 GMT
@frankenhealy - please don't use that 'Bell Bottom' font! It's suitable only for DVD boxes for 'The Goodies' If you have some specific ideas about Hare and Tortoise vinyls - do PM me... Huw, thanks for the offer and I may take you up on it some time in the future but the more sensible peeps here have persuaded me to keep your inimitable design on the truck. Cheers, Ian Good - because it looks ace
Frankenhealey
Surely you need a big tree, a couple of strops , a snatch block, some cable and a suitable tow vehicle. The tow vehicle is the one being worked on. We tried to get our heads round that problem last night but the beer won
Phil H
Club RR Member Number: 133
Jun 19, 2018 11:37:39 GMT
Surely you need a big tree, a couple of strops , a snatch block, some cable and a suitable tow vehicle. The tow vehicle is the one being worked on. We tried to get our heads round that problem last night but the beer won Haven’t you still got a PTO? Ah - needs engine and gearbox to run...
Frankenhealey
Jun 19, 2018 13:00:47 GMT
And in Sheep News today, the headlines : Mad Vegan Woman Banished with Foul Language (we think) Revered Shearer Suffers Major Heart Attack Substitute Shearer Drives the Girls Wild Mad Mary is for the Chop (maybe) More on this below from our rural correspondent Sadly Dave, our beloved old-skool, semi-retired shearer had a massive heart attack in the week before shearing. He's OK now but won't be wrestling 130kg Mule rams for a while. Glenda, our neighbour and local queen of sheep, rang round and managed to snag Dave's son on the following Wednesday but I would be at work Never mind, SWMBO and Glenda and a few helpers rallied together, no doubt helped by the vision of Dave's son in his singlet. He's a proper shearer by trade and our combined 60+ sheep to him would be a light workout as he can do 400 plus in an eight hour stretch. Many local ladies took the opportunity to exercise their rats on strings (I mean small dogs) during the manly singlet-wearing, bicep-flexing tour-de-force. With small numbers it's almost not worth setting up the equipment, especially at £2.50 a sheep but Glenda can call in the favours. Pro shearers can lose 2 kilos of weight a week in the height of the season so have to eat like horses. Mad Mary and the Vegan Woman are inextricably intertwined (we think). Have a video clip of the shorn sheep with confused lambs as their mums don't look like their mums any more and they've just got to meet their grannies. The grannies are probably telling the lambs 'stranger danger' as they don't recognise their daughters either. We had to get the four original Shetlands back t'top field so we could spend a leisurely couple of hours vaccinating and flystriking the lambs and arguing over who's stabbed who with the syringe and whether the flystrike treatment will kill us fast or slow. To do this we needed to separate the two groups (easy) and get the Shetlands into the horsebox (not at all easy). Well blow me down as Mad Mary, the most skittish and wild of the Shetlands, just jumped in the the horsebox and we then spent the next 20 minutes coxing the other three in for a non-fatal, non-chops-on-plate road trip. Just as we are closing the door Mary jumped out and then we spent the next 50 minutes coaxing, baiting, chasing, herding and finally failing to get her back. During the denouement I thought I saw Mad Vegan Woman out of the corner of my eye but at this time I was in full John Cleese - Monty Python rant about the sheep, her antecedents, her decendents and various mutton recipes. Not seen Mad Vegan Woman again. RESULT. Decided to take just three sheep, only to see as I pulled away, Mary moping at the fence because the other sheep were getting a free ride. She is still not caught and I am trying to get a tranquiliser gun off-ticket!
glenanderson
Club RR Member Number: 64
Jun 19, 2018 15:37:23 GMT
My dad used to shear sheep. It’s bloody hard work.
Frankenhealey
Jun 19, 2018 15:53:24 GMT
My dad used to shear sheep. It’s bloody hard work. I know two people who have been on proper training courses, passed, got the certificate and decided never to shear a sheep again.
Jun 19, 2018 16:18:41 GMT
I've sheared a few sheep in my time. I decided I wasn't going to ever do it again after a large and unruly tup got agitated and caused me to slice a very large chunk out of his balzacs... Which sent him rocketing forwards, and actually up the drystone wall on which I'd placed a large pot of blue dye, which then covered him, me and about four other sheep.
I still shudder at the sight of his kernackles getting chewed up in the electric shears.
*shudders*
glenanderson
Jun 19, 2018 17:06:36 GMT
My dad used to shear sheep. It’s bloody hard work. I know two people who have been on proper training courses, passed, got the certificate and decided never to shear a sheep again. In the late 1950s, my dad was working for a company called Cooper-Stewart that made agricultural machinery. A chap called Godfrey Bowen, from New Zealand, had developed a technique to use modern mechanical clippers to shear sheep in record time. He embarked on a world tour to demonstrate his revolutionary new method and, when he came to the UK he was sponsored by the main machinery suppliers over here, of which my dad was the representative for his firm. Now, Godfrey was notoriously difficult to get on with and so was my dad. Oddly enough, on that first tour in 1958, they both got on very well, and when Godfrey returned in 1959 he refused to work with anyone except my dad. As a result, dad was the British Wool Board’s first registered sheep shearing instructor, and toured the country with Godfrey almost every year until the early 1970s. Watching a skilled bloke shear a sheep in under a minute is pretty impressive.
Jun 19, 2018 21:59:53 GMT
An old pal of mine used to do it for a living, flitting between the UK, Australia and New Zealand.
He were a big lad!
Frankenhealey
Jun 20, 2018 13:37:53 GMT
Another day, another mode of transport fails on me My beloved old-skool Timberlands have become flappy soled clown shoes. The are not the modern Timberland fashion boot cr4p but are 22 year-old work boots and were made before the marketing guys and venture capitalists ever got at the company. They would be like an old but trusty pickup that never failed to start and would carry anything if they were automotive. They have been up mountains, down caves, skiing, walking, dirt biking and to 22 countries and it's about time they had some TLC (i'm a really bad owner). Comfiest boots ever. The problem The cleaning solution : abrasive block One boot done and right hand reduced to an arthritic claw but a particularly fine Marlborough Sauv Blanc will cure that or I won't just care about the pain Onwards with the other boot and then resoling at a specialist and then my old friends will prolly last long enough for me to be buried in them
melle
South West
It'll come out in the wash.
Jun 20, 2018 14:16:52 GMT
I just got back from a holiday in Iceland, where I saw no less than 4 Goddesses. All stationary/ on display, but I suppose they would do pretty well on the bumpy Icelandic "F"-roads (potholes with some rocks/ lava/ gravel in between).
Frankenhealey
Jun 20, 2018 14:42:04 GMT
I just got back from a holiday in Iceland, where I saw no less than 4 Goddesses. All stationary/ on display, but I suppose they would do pretty well on the bumpy Icelandic "F"-roads (potholes with some rocks/ lava/ gravel in between). They can make great expedition vehicles like this. I'm pretty sure one is used in Iceland for glacier tours.
Frankenhealey
Jun 21, 2018 21:40:47 GMT
After a judicious application of the disappearing pen trick we got Mad Mary in the horsebox. She followed the others into a large pen made from hurdles and we just kept making it smaller. The new mums and lambs went into the horsebox but Mary hung on until the inevitable happened. In the end we had to lift her in and I was lucky that she did not try the old 'dirty protest' trick as I definitely had the wrong end.
Once oop t'top field nature took hold and the 3 first gen sheep, who had already established their pecking order, had to sort out Mary who had returned expecting her place at the top of the heap as usual. Much beating up took place while Bob the Dog and the second gen sheep and lambs just ignored the silly beggars.
Have some sheep-on-sheep non-cage fighting
