May 12, 2020 16:30:56 GMT
Today was one of those days where it just seemed like progress was glacial. I spent most of the day grinding and drilling spot welds. Very dirty and not much fun. And I was struggling with locating all the welds. The edges are very wavy from where they put so many welds in, making it had to spot them. So in the end it was a case of using a old chisel to prise up the remaining metal and grinding of the spots. Also the old outer sill sits between the A and B posts and the inner sill. So trying to remove these bits is a right pain in the backside. The B post was also rust damaged at the bottom, from water getting in through where the trafficators in the top of the post. I will have to cut out and replace part of it. I still have to try and remove the bits left on the A post. And this looks like a harder job. At least the rest of the inner sill is sold. And after a going over with a wire brush in the grinder, it came up ok. Maybe tomorrow I can put the sill on.
1955 Austin A30 1981 Jawa Mustang 1990 Trabant 601 (Tommy) 1989 Trabant 601 2009 Jaguar XF 2012 Toyota AYGO 2018 Scomadi TL
May 13, 2020 16:51:05 GMT
Well another day of chipping away at long list of jobs on the Austin. First job was to sort out the scabby bit on the B post. A quick bit of surgery with the grinder. Followed by a zapping with the welder. The I had a fun time trying to remove the remaining bit of old sill that was still firmly attached to the A post. Once that was done I could finally trial fit the new sill. I used my cleco pins to temporarily hold it in place. It lines up along the top of the inner sill ok. But the bottom was sitting slightly lower than it should. Careful use of a bit of wood and a car jack, and I could get it fairly well lined up. The only bit that sill sitting low. Is the central part which has an internal brace for jacking up the car. So it looks like I will have to take a few mm out. And weld it back together. The gaps don’t look too bad, keeping in mind that the back doors are rusty and not in the best of shape. And that is the most complete the poor old Austin has looked for a while. So fingers crossed I might actually get the sill on permanently tomorrow.
May 14, 2020 19:18:44 GMT
One step forward two steps backwards. Started the day by waking up with a migraine. So took some painkillers and hid in a Dark room until it subsided. Then managed to muster up enough enthusiasm to venture into the garage. Yesterday when I checked for panel fit, it was all looking good. Except For one area. Something is not quite right towards the front bottom edge of door and sill. With the door open it’s clear that the new sill is narrow in comparison to the original. Some what annoying as it’s a £200 panel. But I can’t leave it as it is. So with an extra large dose of brave pills I sliced up my new panel. Then it was a case of opening it up till it looks right, and weld in some extra metal and flattened off the welds. And then offer it up and see how it looks now. A lot better then it was, the bottom of the door matches the sill and the A post fits better as well. And that’s all I managed to get done today. It did take a while to weld it up as I was trying not to distort the panel.
v8ian
May 14, 2020 20:57:12 GMT
Looks brill, I'm on the drivers door fit on my a35 van, different problem tho
samta22
Stuck in once more...
Club RR Member Number: 32
1955 Austin A30 samta22
@samta22
Club Retro Rides Member 32
May 14, 2020 21:07:05 GMT
I've the exact same issue on my A35, can't decide if it's a wing issue or sill replacement problem. For the price of the panels you do wonder sometimes.
May 14, 2020 21:39:09 GMT
Looks brill, I'm on the drivers door fit on my a35 van, different problem tho Thanks, getting there slowly. What’s the issue with the door?
May 14, 2020 21:48:10 GMT
I've the exact same issue on my A35, can't decide if it's a wing issue or sill replacement problem. For the price of the panels you do wonder sometimes. I had a look online today to see if anyone else had issues with the panels from the supplier. And found someone else who had the same problem. Also mine needs the reinforcement for the jacking point cut down. As at the moment the bottom of the sill doesn’t line up properly with the bottom of the inner sill.
May 14, 2020 22:14:30 GMT
Nicely done 👏
v8ian
May 14, 2020 22:18:00 GMT
Looks brill, I'm on the drivers door fit on my a35 van, different problem tho Thanks, getting there slowly. What’s the issue with the door? A Previous owner had started to remove the skin, had a change of plan and tacked the skin back on.... badly... I have spent a week welding ..grinding and a bit more welding and grinding, I almost have the door gaps about right, I may lead the edges to make the fit spot on..
May 14, 2020 22:31:51 GMT
May 14, 2020 22:36:57 GMT
Thanks, getting there slowly. What’s the issue with the door? A Previous owner had started to remove the skin, had a change of plan and tacked the skin back on.... badly... I have spent a week welding ..grinding and a bit more welding and grinding, I almost have the door gaps about right, I may lead the edges to make the fit spot on.. Nothing worse then trying to undo someone’s else’s previous bad work. I have to replace the bottom half of both my rear doors. Can’t say that I am looking forward to that job. Do love what you are doing to your van. It will be pretty special when it’s done.
May 18, 2020 17:32:53 GMT
Last updated I was cutting up my nice new panel, in an effort to make it actually fit the car. I had got one issue sorted and now for the next problem. The new sill was deeper than the original inner sill. After a quick check I found it was actually 11 mm too tall. I can compress the ends but not the middle. The reason being the reinforcement for jacking point. And then a bit of carful cutting with a grinder and a hacksaw, resulted in this. And then a bit of welding. Then a lot of clamping and plug welding resulted in a solid repair. Next step tomorrow will be the piece that goes from the sill to the rear wheel arch.
May 19, 2020 16:43:45 GMT
Another day of steady progress on the Austin. Today’s mission was to fill in the large gap between the wheel arch and the sill. I had brought a repair panel which is a lot bigger than the area that needs replacing. But you can’t get the small section that I need on its own. So it was a case of carefully cutting off the bit that I needed, and trimming the bodywork to fit. And surprise surprise the new panel didn’t fit. Just like the replacement sill it was going to require some surgery . The shape is not right so I had to use my hammer & dolly to reshape it. But it still would not line up. It seems that it was made too small, so I had to put a cut down the centre and tweak it a bit. Then steadily zapping it with the welder and hammering it as I closed up the gap. It just needed a slither of metal in end bit. And eventually we end up with this. After that it was a case of carefully grinding the welds down. All that is left to do now is put an end piece on the sill and grind all the welds down. Then the drivers side is all done. Then I just have the fun job of trying to free the front brakes off. Then push it out side and turn it around and push it back in. And repeating all that again on the passenger side.
May 19, 2020 19:21:55 GMT
Cracking progress, it's looking very good.
May 19, 2020 19:54:15 GMT
Cracking progress, it's looking very good. Thanks, I have probably made more progress in the last ten days than I have in the last ten years. Back to work next week so progress will probably slow down a bit.
May 19, 2020 19:58:24 GMT
Nice
May 19, 2020 20:16:29 GMT
Don't stop now, you are on a roll.
May 19, 2020 20:49:38 GMT
What size holes do you drill for cleco pins lovely work
samta22
@samta22
May 19, 2020 20:58:27 GMT
What size holes do you drill for cleco pins lovely work Depends on the size pins you are using, I usually drill 3mm holes for the copper coloured ones
May 19, 2020 21:00:05 GMT
Cheers I was given a box off them haven t tryed them yet
