purplevanman
Way too orangey for crows
We has a coilover got the nearside done today will get offside done the weekend After chopping springs we had a bump stop issue With a little modification we don't Which enables this with plenty in reserve I then reversed off the ramp and caught the inner tyre wall on the ramp and holed it Slight dampner on the afternoon but I do have some spares so not too serious
Welder, fabricator, general resto work
Tim
Good work - looks great!
Really wanted to buy this car a while back but couldnt find the money.
To be honest it would have broken my mojo and wallet as i cannae weld...but its still fab :-)
purplevanman
If you can't weld then this car would have certainly broke the bank
aar0sc
Wonderful car! I need to learn to weld; I swear every single time I do anything on my Triumph I find more rust... and all of it's hidden underneath! My battery tray's held together with quite a lot of hope and not a lot of metal :/
2001 HONDA CT110 (NOT RCV)
purplevanman
Right this is getting silly I can set it it very low and still have suspension driveability might be an issue I hope to try it tomorrow. I imagine the steering is gonna be heavy to say the least. I will need to fit a bigger diameter bore master cylinder as brake pedal does travel a long way Currently looking for a taper reamer as I reckon I can drill and bush the steering drop arms and redo the taper upside down, this will bring the track rods back towards their normal angle. I would like to find a method of sorting the lower arm angle too, ball joint is going to be close to it's maxed out angle
That is getting really low ;D nice work but is that the bottom of the rad l can see in line of fire now
purplevanman
errrr yep but it is an easy up shift to gain 2inches, just need to drill 4 holes
Ginge
I laughed at this word....such a child. Keep up the good work Ginge
Right this is getting silly I was going to say "Not at all" but actually, "Yes it is" ;D If you moved just the outer ends of the steering arms they'd end up not parallel to the lower wishbones and induce bump steer
purplevanman
Sept 11, 2011 19:29:02 GMT
just a side project for the old girl, been collecting slots for a while as a certain person loaned me some then took em back before i even got them on the car, didn't they Kev ;D ;D found 3 and then just before the Gathering a full set turned up so thanks Ryan Now to get cleaning first stop, blast the rears and get some paint on Wet flat the fronts, handy use for parts washer Then as telly is so 5hite get the polish out in comfort slow but quite rewarding
purplevanman
Sept 26, 2011 20:31:09 GMT
The Doctor
Club RR Member Number: 48
Sept 26, 2011 20:52:26 GMT
nice work!
purplevanman
Dec 13, 2011 22:17:26 GMT
Starting the work for MOT I had to replace the exhaust due to many cracks in joints. The rear mount had rusted so I have to weld a patch, this spread along the front edge of boot floor trying to find an edge I went into the inner wing and this has ended up in a large pile of filler dust as it appears the rear inner wings are held together by patches glued on with sealer and filled over Started with the shocker reinforcing plate.. Lets underseal it then put filler over the top and underseal it again!! And under that well attached around to seatbelt mount More filler And under more filler was the seam that runs over the center of the inner arch
craig1010cc
Club RR Member Number: 35
Dec 13, 2011 22:43:04 GMT
some top level bodging has gone on there But at least its in good hands to be put right properly
purplevanman
Dec 13, 2011 22:54:00 GMT
The hands might be ok but it's the head i am worried about, mojo is running low already without this
Jesus Holy Christ, that is some pretty awful bodgery of epic proportions. But if anyone can get it back on the road it is you . You weren't kidding about it going to the shed for a short while from the last time we spoke!
Last Edit: Dec 14, 2011 0:34:43 GMT by ChasR
rodney
this looks like such a cool car , the welding sucks but if you can put the time in it to fix it then brilliant as its what i would call a natural rat car , meant in the coolest of ways!!!! looks soo right in the pics above!,.
you can rebuild this.......
go grunty.... ;D
yep, hope this gets fixed. just sold my saab last week so i'm now on the hunt for a mk1 saloon. ......eyeing up your coilovers grunty.......
