Jul 12, 2013 12:44:22 GMT
Long time no updates... Soon I'll get the Lancer over here for you to see the progress made on it since this one is parked... but just for awhile...
Finnally an update...
Today started to mask the car up to make an entry on the sanding part...
Need to create a booth to do the painting and to protect it from dust and other junk...
Photos tommorow...
aws
Just smile and wave boys. Just smile and wave.
Finnally an update... Today started to mask the car up to make an entry on the sanding part... Need to create a booth to do the painting and to protect it from dust and other junk... Photos tommorow... good. good. Will wait for photos.
aws
Nice work mate. good and keep going.
Aug 18, 2013 19:38:37 GMT
I'm making some progress on the sanding i/e paint stripping but I can't sand more than 2 hours straight on the weekends even with a mask do to my Health and the amount of paint coming off... I took some pics of whats been done so far but will upload them later...
aws
Aug 19, 2013 21:26:40 GMT
Good. Due to my extensive traveling those few weeks, I havent been able also to sneek into garage for some fiddling on mine engine. Also bodywork is left on idle. Thumbs up for You my friend and keep moving.
Aug 20, 2013 11:22:11 GMT
Aug 20, 2013 11:32:41 GMT
Aug 20, 2013 19:04:02 GMT
You don't need to remove paint that is sound, or that you are happy is sound underneath, normally I would just strip to bare metal any areas that you know need attention, then spot prime these and sand the existing paint smooth
Aug 20, 2013 19:36:43 GMT
You don't need to remove paint that is sound, or that you are happy is sound underneath, normally I would just strip to bare metal any areas that you know need attention, then spot prime these and sand the existing paint smooth Yeah... but I find some surface rust on the celling and other places, so since the car has 50 shades of paint on it I'll strip all the paint and give a new paint all around... Special brown primer for the first hand then 2k primer for filling and then 2/3 hands of 2k paint... I think that will do just fine for the next 20 years or so...
Aug 23, 2013 21:11:05 GMT
Well done! Keep up the good work! Just to increase your motivation, here are some clips of my friend Tom, driving his historic Volvo 164 Rally Car on maximum attack. Hope you like it! Best regards from Sweden! /Bjorn
Project - Opel Manta 400R
Well done! Keep up the good work! Just to increase your motivation, here are some clips of my friend Tom, driving his historic Volvo 164 Rally Car on maximum attack. Hope you like it! Best regards from Sweden! /Bjorn Thanks for the support... I've seen all the videos from Tom and also from Jerry AK. Very serious driving with an old girl... Do you or can you find out the forum build of that car?!?! Would love to know more specs of it...
Aug 26, 2013 11:52:20 GMT
Ohyes, i'm really impressed by their driving! I don't think there's so much info about Tom's 164 on the web, but I've got a magazine from last year with some specs etc. Engine: B30 2996cc, 270-280 hp (even more this year), close to 300 Nm. Built by Jonas Banck (JB-engine). Transmission: Standard 4-speed M400 with close-ratio gearset, 4,88 final drive. Suspension: Öhlins-dampers. Brakes: Standard ventilated discs, Brembo 4-pot calipers. Well, that's about it Best regards Bjorn
Aug 26, 2013 12:23:58 GMT
Ohyes, I'm really impressed by their driving! I don't think there's so much info about Tom's 164 on the web, but I've got a magazine from last year with some specs etc. Engine: B30 2996cc, 270-280 hp (even more this year), close to 300 Nm. Built by Jonas Banck (JB-engine). Transmission: Standard 4-speed M400 with close-ratio gearset, 4,88 final drive. Suspension: Öhlins-dampers. Brakes: Standard ventilated discs, Brembo 4-pot calipers. Well, that's about it Best regards Bjorn Thanks Do you know anything on the spcs of the engine?!?! Cam, carb or efi... THOSE ARE A VERY MOTIVATING DUO FOR ME... Best regards
Aug 26, 2013 13:47:17 GMT
No problem at all, I'm happy to help. Found some more info about the engine: It's built mainly for drivability, with a special camshaft from KG Trimning (www.kgtrimning.com), forged pistons, radius valve seats, 46/38,5 valves and triple Weber 48's. I know they had some issues with torsional vibration, but that is now sorted.
Best regards Bjorn
Aug 26, 2013 22:20:11 GMT
No problem at all, I'm happy to help. Found some more info about the engine: It's built mainly for drivability, with a special camshaft from KG Trimning (www.kgtrimning.com), forged pistons, radius valve seats, 46/38,5 valves and triple Weber 48's. I know they had some issues with torsional vibration, but that is now sorted. Best regards Bjorn Thanks for that info... That was what I was looking for... Some engine dampers would work great or some solid mounts...
Aug 28, 2013 12:29:11 GMT
Can 2 of these: Allied with 2 of these: Be any good for a 3.0 straight six?!?!
Tazzy
Aug 29, 2013 15:17:20 GMT
have you checked with turbobricks.org?
