May 26, 2016 21:31:23 GMT
Quick update.
Today as it was holiday I had time to work on the car. Started making ground for the day by pulling and putting the Volvo in 2 stands so I could run her through the gears as my fathers 190d Merc. is, at the moment, a none runner due to a bad dif and other shanannigans. Started her and something that is becoming usual caught my eye and stop her. It was spilling fuel through the carburetors. I thought to my self ''I think I replaced the full bol carb thingie that blocks the fuel getting in.'' Took a look on my box of carbs spares and indeed I did, so next on the line will be to return the original ones as they were working great.
FIY and note to self.
In the old days things were getting made to last. Nowadays they built things on a profit base...
That will be a job for another day.
Re-started patching the missing doors and some random hole that were not needed like 5 holes for the rearview mirrors.!?!?!?!?
Welding done, some dents taken care of, some large holes filled, then grinding and now the're done. Next it will be the daunting task of sanding, rustproofing, priming and paint the inside of the doors...
No photos today but they will get here some time in the near future...
Need to buy some sheet metal to finish the back and finish welding on the car...
May 30, 2016 21:46:23 GMT
I've just checked the filler can that I bought some time (years???) ago and found that the lid was slightly open and all almost dry, almost.
Done some research to find that Acetone would make it wet again so I decided to try some nail polish remover with acetone to see if it was real... Just tried it and it's good again.
To make sure I tried some with the hardener to see if it was OK to be used on the car and I must say I was impressed with the result. It may take more time to dry but it hardenes really well. Some quid (Euros) spare here....
Jun 15, 2016 21:52:25 GMT
Another little update without pics... Just made a spare wheels rack so I can store them neatly almost like this one in the photo... Now I'll need to make 2 more for the other wheels and to find the wheels like in the pic for my other car...
Jun 20, 2016 21:50:30 GMT
Rack's done. Yes more than one and they're painted as well... Photos later...
Looking forward to this one 'finally' hitting the road!
I do like the 164, it just had more 'presence' than it's 4 pot sister.
Jun 22, 2016 20:44:12 GMT
Jun 26, 2016 17:23:15 GMT
Just sanded 2 doors on the inside and aplied some rust converter.
Maybe next week I'll do the other 2 and start painting them on the inside...
Today I went to change the ''full bowl stop'' thinggie on one carb to almost start a fire in the engine bay. Started the car as usual, things was looking like it was repaired and all of the suddendly fuel was comming out from almost all orifices of the carbs, yes both of them. Turn the switch of the engine to not cause a fire. I need to take them apart to inspect whats wrong with them... Put some jack stands on the rear to see if I can tackle the ehxaust during the week or the doors...
Damn 1 step forward 2 steps back... this will have to change...
fer4l
Testing
Club RR Member Number: 73
Glad you didn't torch her!
Cheers
Matt
Painted the inside with some primer on some off the worst parts of the 2 doors that were previosly rust protected. Next will be some rattle can paint to reach the hard spots and them some thick black paint on the inside. Slowly going further....
aws
Just smile and wave boys. Just smile and wave.
Vow. thats and hot update on your car then. Good that it didnt catch fire.
I've just received these today. They will look nice in the middle of the front bumper...
Jul 11, 2016 21:37:04 GMT
Done the drivers door, at least was sanded and done the other 2 doors a bit of red primer inside those hard to reach places. Tommorow will be rust proffing the drivers door, primer and maybe paint the inside of the 3 in black. Lets see where it goes... maybe some ehxaust or not... hehehehe
Jul 13, 2016 22:42:50 GMT
Done the drivers door, rust proffing and primer painting. Just one missing and tommorow it will be time for those carbs and ehxaust finishing. It's time to be done.........
Jul 14, 2016 22:10:01 GMT
Front section of exhaust replaced as it was dented and really thin metal. Some adjustments made to brackets and fittings. Missing 1 bracket and linnishing some kinks... Pics later...
Jul 15, 2016 12:25:24 GMT
aws
Nice. So it comes bit by bit.
Jul 19, 2016 12:41:17 GMT
Bracket found/made. Carbs off the car and to be inspected. Ehxaust off for the finnishing touches...
Jul 24, 2016 13:02:25 GMT
Carbs tested OK without any repair!?!?!?!?!? Tested the on the car without the air filter box and it seems to be working well-- Later to be fully revved and to see where is the fault...
Jul 31, 2016 20:49:35 GMT
Another micro update... Carbs repaired as I found out the culprit... It was the washer that wasn't sealing properly in the fuel flow stopper so fuel was entering any way... All fitted, AGAIN, and it has a minor ehxaust leak to be addressed... Bought miself a crankcase gasket set from Elring 112.284 for about 8,65€ that includes something like this... As I need to change the crank seal that as a little leak to the gearbox and for this price I had to say yes...
