teaboy
Make tea, not war.
Jan 19, 2011 20:57:09 GMT |
I have had my 911 for about ten years I think Been all over in it. Le Mans, Nurburgring, Barnsley etc. Done a few jobs on it. Rear anti roll bar bracket broke off  The bit where it is welded to was rusty so I had to fix that. I cut it out, this part is infact a triple skin.  Made a bit to repair it.  And a bit for the outer skin  All welded together.  Then fitted Wevo steel ARB mounts.  and painted with poly bushes and ARB powder coated.  The clutch cable went, or so I thought. Turned out the pedal crank had worn out and the clevis pulled through.  I was just going to weld it up and re drill it but I got carried away and re did the pedal box  Whilst it was up on the stands in the drive some plonker dropped a scaffold pole on the wing   Luckily he was insured so I got a new wing. On 3.2 Carreras there are indicator repeaters on the wing. They look just tacked on and frankly rubbish. I could have just left them off but that would have been too easy. What they really need is to be recessed into the wing. On my travels I noticed that the 944 has the same indicators and they are recessed, so I got some bits from the scrappy.  I'll show you what I did with them later. Thanks for looking.
Last Edit: Jan 3, 2022 23:36:19 GMT by teaboy
Lawsy
Jan 19, 2011 21:05:11 GMT |
very nice - a friend of mine had one for several years, very similar and an 86 too, sadly he sold it on a couple of years ago
luckygti
I need to try harder!
Jan 19, 2011 21:18:05 GMT |
Welcome  That's a nice looking car. I would love a 911 of this vintage. So much better looking than the newer versions. Looks like you've done some nice mods on it too.
Felix
Jan 19, 2011 21:35:15 GMT |
I love all the black trim against the white paint on these!
teaboy
Make tea, not war.
Jan 19, 2011 21:39:21 GMT |
My indicator mod, fit this bit on.  So, what would you do with six hundred quids worth of new wing? Cut a hole in it of course.  Then trim & shape the bit 'till it fits  And weld it in  Look at that, hardly worth the bother, but I like it.  As the car was off the road I took the engine/box out to rebuild the gearbox. Whilst doing that I noticed that the engine tin was in a bad way.  Now this stuff costs an absolute fortune  Luckily for me this bit was not available, so I had to fix it.  There was a heat shield to protect the crank sensors  I decided to modify the design to fit better around my SSI heat exchangers. This is it half way through  Then welded onto the repaired tinwork   Repaired another bit of the tin    More in a bit
Last Edit: Oct 13, 2011 21:04:25 GMT by teaboy
Jan 19, 2011 21:51:03 GMT |
I've always wanted a 70's or early 80's 911 and white always seems to suit them. Seeing owners actually work on their own cars makes me want one all the more! It's just the stories about the early gearboxes that still put me off.
Good work mate.
BMW 320d E46 Wagonista BMW Z3 - 'Project Friseur'
75nut
Jan 19, 2011 21:51:41 GMT |
Nice work, neat welding, what equipment do you use? Love these older 911's especially in the white and black!
90 Alfa 75 3.0 V6 Cloverleaf 79 MGB Roadster 88 Saab 900i Convertible 94 MK1 MX5 1.6 05 Volvo V70
MrSpeedy
East Midlands
www.vintagediesels.co.uk
Jan 19, 2011 21:56:04 GMT |
Ah, a propa porshe before they got fat. Lol I'll take mine with a pair of bright red braces please.
Love it
teaboy
Make tea, not war.
Jan 19, 2011 22:14:46 GMT |
Nice work, neat welding, what equipment do you use? I have this mig, an Erfi  and this tig, or wig as it says on it. Should be ok for when all my hair falls out. (it has started)  It's just the stories about the early gearboxes that still put me off. There is a lot of BS written and spoken about the 915 'box. A worn out one is truly awful but a good one is a joy to use. Mine has a Wevo shifter with a longer stick, which though expensive improves the shift 100%. Infact, best thing I have fitted to the car.
BenzBoy
Club RR Member Number: 7
Jan 19, 2011 22:30:00 GMT |
Great build thread! I like that you're getting stuck in to a 911.
Jan 19, 2011 23:52:53 GMT |
Beautiful Porsche. That shape is the one I prefer. And some very cool workmanship going on there too.
teaboy
Make tea, not war.
For a while I was thinking about how I would like my 911 to be. What i really wanted was a semi lightweight hot rod. I wanted my 911 to be a sports car, not a luxury car. I want to be subtle about the things I do to it, so that if you didn't know then you would not notice. If you knew a bit about them you might think that there is something different here, but what is it? Time to loose some of the fat. Off the car at least, I think the belly is here to stay. I managed to get hold of a set of windey windows, RS leather door straps and Wevo door handle. Lost the doorbins and heavy door furniture.  Door card will get recovered, this is prototype. So, tried my new winder and I rattled my fingers on the dash   It turns out that for '86 and on you need shorter winders. These have a 959 part number and cost me a ton for the pair   I lost the heavy electic mirrors  and welded up the holes  lost the headlight washers and welded up the holes on the bumper   Who needs electrically adjusted seats in a sports car? They weigh loads so have to go. Got some of these instead.  Recaro SPGs which need trimming to suit. After a bit of a search I found some proper retro Porsche cloth. It is called Pascha and it is bad for the eyes.  Just having the cushions done in this. I fancy another set done in tartan for when I want a change. lost the centre console  It is loads better without it, much more space. The hazzard switch was in the console, found a space for it here.  Have you ever tried to find a RHD 3.2 Carrera with no sunroof? Let me give you some advice.........don't bother looking. It came as standard and you had to ask them not to fit it if you did not want one. Obviously the red braces types wanted every extra there was.... Elecric sunroofs are heavy and not only that the weight is right up at the top where you do not want it. It had to go. I'll tell you how I got rid later, but it involved taking a grinder to the roof.
I love the Paul Stephens modified cars. I want an orange lightweight built up as you seem to be doing yours.
teaboy
Make tea, not war.
I want an orange lightweight built up as you seem to be doing yours.  I like orange too, but a friend of mine has an orange. loving the lime look at the moment
Ray Singh
More German exotica in my garage now
Teaboy -> Your car looks great and I love your style. Getting stuck in and modifying. I had a 1989 Carrera 3.2 not long ago, pic to prove:  I joined the PCGB and they told me to treat the car with kid gloves. In one year it moved about 5k miles and cost a small fortune to keep on the road. I needed new wings and kidney bowl replacements....... Happy to loose the car and buy a 944 turbo instead :-). Nice to see you tinkering with what is a £15k car...... ETA: Can you get rid of the sunroof on my 944?
Last Edit: Jan 20, 2011 8:17:43 GMT by Ray Singh
Wonderful work mate!! I dig the 'mod it do you can't tell its been modded' direction.
Looking forward to seeing future updates!
g40jon
i love these sort of threads! great inspiration
It's great to see someone doing the work on one of these themselves and modifying it too. I always imagine that it's the sort of car you'd have to take to a Specialist.
Brilliant.
rob0r
East of England
Club RR Member Number: 104
Great work, I admire your bravery with the roof!
E30 320i 3.5 - E23 730 - E3 3.0si - E21 316 M42 - E32 750i ETC
Jan 20, 2011 11:18:50 GMT |
I love the what looks like slow but sure development of this. Plans sound really good too.
