PaintWhen it came to the bodywork, we left it to the pro's.
We entrusted in friend and master bodywork guru Lee, who runs Crash Care Centre in Hitchin, Herts.
With the idea of Ford Imperial Blue in contrast with the Carbon parts, we knew we were onto a winner.
The pictures show it all, so enjoy.
Primer
Painting
Buffed
BrakesWhen you've got 200+bhp under your right foot, you need something substantial under your left foot. We looked at a lot of the billet conversions that are offered, but had heard mixed reviews on them. We also looked into rear disc conversions, but decided against it for the amount of braking the rear brakes do.
So in the end we decided to go for a Wilwood Dual Master Cylinder / Pedal assembly, along with fully refurbished Metro Turbo 4 Pot Callipers and discs up front with a standard set up in the rear. There is a bias valve installed to aid in distributing the braking power where you want/need it most. The handbrake was also moved back 8 inches due to the gear lever moving back. The car will be getting 'used' more this year so we'll see how the set up holds up under a bit more strain.
The Carbon Fibre....I've been lucky enough to previously own some nice cars. TVR Chimera, TVR Tuscan and a Porsche 996 Turbo. The Porsche was clad with every piece of optional Carbon Fibre that could be purchased, and when you put the Porsche name on anything things aren't cheap! But the Carbon bug had bitten me!
Luckily for me, Rich works for an Aerospace company that uses lots of different materials including Carbon Fibre & Kevlar, and although he's not officially on the tools anymore, he tells me it’s like riding a bike. So after some persuading we decided it would be good to have some custom pieces on the car, little did he know that it would grow as much as it did.
DashThis started life as an off the shelf item, but its had so many hours spent on it Rich tells me we should have just started from scratch and made our own. It might aswell have been made for a Mk1 escort for how good it fitted. The problem was we wanted it to be functional with the heater, but with the heater hidden, and minimal switches visible.
So again, after a lot of cutting and trimming we had the basic shape fitted.
But this was just the start of things to come...
We then decided to fit Corsa power steering, which meant a bit more of the dash needed trimming to fit snugly.
And then I decided I wanted a 6 point rollcage, which sadly for Rich went straight through the freshly fitted dashboard. Again we have seen rollcages through dashboards, but there always crude holes that either don't fit properly or that you can see through to the wiring under the dash. We wouldn't have been happy with this so Rich got to work, making Carbon tubes that were 1" larger diameter than the rollcage giving a 1/2" gap all the way around the rollcage once fitted. These tubes were made on a 3" x 24" aluminium tube fixture that the carbon cloth was wrapped around. Once the resin was cured the inner aluminium tube was removed leaving carbon fibre tube. The dashboard was then cut to receive the tubes. These were then bonded into the dashboard with more Carbon fibre & Resin.
Whilst Rich was making the tubes he also made some Carbon 'L' shape filler strips to fill i the gaps between the dash and A pillar.
Digi Dash Binnacle/Switch HolderWe wanted a modern Digi Dash to give us all the modern accurate readings we needed, plus we still needed switches to activate the electrics, so the ETB digi Dash was chosen, it’s got so much on it you wouldn't believe! From this the carbon binnacle was purchase, it came about twice the size that you see in the pics! We spent a few hours then shrinking it down to size to get it as small as possible, and the key here was to keep it at the same angle as the steering wheel, which we did which worked out perfectly. Again Rich insisted on hidden fixings to keep that modern look.
We then mounted the 7 new style mini hoops that separate the 6 switches that operated the Ignition/Horn/Hazzards/Heater/Side Lights/Main Beam. The wipers, Full Beam and indicators were via the TVR stalks on the column as Vauxhall intended.
Carbon Gear Lever Surround & Linkage CoverFor those of you that know a little about mini XE conversions you'll know that the Vauxhall gear linkage would normally be visible and bolted to the floor with the shortened linkage joining the gearbox and gear lever just floating in mid air.
We knew we wouldn't be happy with this, so Rich got to work and started knocking up some more 1 off Carbon parts.
The cover for the gear lever assembly had to fit between the seats, accept the original gear lever gaiter, be a location for the power steering adjuster and have hidden fixings, so this was made from scratch. And the tube that went from this cover to the bulkhead had to sit in mid air with hidden fixings, so Rich used a 80mm pipe as a mould to wrap. Once the resin had cured the pipe was removed. We came up with these.
Carbon Steering Column CoverAs we were using Vauxhall Corsa C power steering, it was obvious to start life using the Corsa steering column shroud, but it didn't fit too good.
So again, rich had to get creative. So after numerous hours of playing and inventing, he came up with this.
But for us to be able to keep it useable, it had to be able to be removed, so we kept the original fixings and how it splits.
Then the area around the column had to be shrunk down do to the removable steering wheel, and also the addition of the push button start that replaced the key had to be blanked off.
Then the Carbon made another appearance and hey presto.
Carbon Heater CoverWith the newly positioned heater, as much as we tried to get it right up under the dash, you could just see the bottom of it, this wasn't acceptable. Also to keep the clutch cable with a smooth operation it looped around in front of the heater, so all this needed hiding. Rich knocked up a cover to sort this out, again out of carbon.
After making a 90deg jig with a radius corner.
This was then wrapped in Carbon.
And once cured some sides were made it was then trimmed down, resulting in this.
You can just see it under the dash in this picture.
Carbon SeatsWith the obvious Carbon theme developing both outside & inside the car, it was only right we tried to source some Carbon seats. This isn't that easy when you look at the size of the car and the space you have to squeeze 2 front seats in. There was never going to be rear seats so the task was on to find 2 front seats.
We came across the chosen seats originally in fibreglass. We loved the style, the size was right, but the finish wasn't. Luckily for Rich, the seats were sourced before the rest of the Carbon work had started so he got away with this particular project! We spoke to people who made the seats if they could do them in Carbon, they said they never had before but they'd be up for giving it a go. The result was stunning.
Now the fun was to start to how we'd get them to fit. We bought a set of seat frame supports and a pair of universal runners to get the ball rolling. After 3 of us trying out different seating positions with the new steering and gear lever position and to give rollcage and gear lever cover clearance, we agreed on where they should be. Before we could mount the frames to the seats we needed to make up some small spacers to keep the frames square although the seat tapered off at the back, so Rich done this on a lathe.
Now these were made we got the frames mounted to the seats, the runners mounted to the frames and then decided the final positions to where they would mount to the floor. Once mounted we noticed they were a little wobbly so made up some seat stiffeners to fix the frames to the inner sills. We then mounted the runner adjusters at the back of the seats to keep them tucked away from sight.
The original thought was to have the seats with no padding on to show off the carbon, but after Lee @ Crash Care Centre had spent a lot of time lacquering both the front and backs of the seats, we decided it was a sensible idea to use the pads provided mainly to stop scratches from clothing but also for comfort. For those who are wondering, the seats are comfy for about an hour, then you start feeling a little numb LOL
The seat frames were finished in the anthracite colour we used throughout the car.
Here they are in the car with the SCHROTH Racing 4 point harnesses.
Carbon MirrorsTo continue the Carbon theme outside the car, I wanted some sort of small carbon mirrors. I considered bike or single seater mirrors, but none of them would have looked right. Then i stumbled across these that were designed for mini race cars and knew we could make them work.
Once we'd had a look at them the questions was asked about the mounting and that there was no way that we'd be screwing them through the door as per the picture. So after a bit of cutting, some new internal hidden fixings and a new panel welded onto the door we ended up with these.
This left the fixings exposed on the inside of the door, so Rich knocked up some Carbon panels as any modern car would have which covered these up.
Power SteeringWith 8x13 wheels & slammed stance, we knew that the steering was going to be heavy, so from the start we needed a solution. A quick scan across a few forums showed us that people were using a few different power steering options from other vehicles. With the engine being a Vauxhall item we seemed it only right to use the Corsa power steering option, of which we found even then there were a few options. Being Vauxhall boys by trade we knew a little about what was available. Early Corsa B's had pump driven power steering, where as later Corsa B's and all Corsa C's had electric power steering. So after trying both a Corsa B & C item, we opted for the Corsa B as it was lightly shorter which suited our set up better.
We then made a bracket to hold the column that bolted through the bulkhead and onto the standard crossbrace.
We then had the Corsa end welded onto the mini end that connects to the steering rack.
We then added in an adjuster on the back of the gear lever surround to allow us to lighten up the steering for when we were parking.
DoorsThe doors were new sourced from Minispares. We cut off the upper door card holder on the inside due to the door cards we planned to use, and we had welded in the plates for the mirror mounting, apart from that they were pretty standard.
Once the doors were painted Rich fitted them up at his house away from the madness of the main build, plus he could do them in his own time, or when he came home from helping on the mini!
We decided we wanted minimalistic doors, so no internal door handle or lock, no visible fixings on the door cards, and the window winder and door opener were modified to sit at the same angle (Rich being anal again) and then painted the same anthracite colour as used elsewhere.
New handles, locks, rubbers and chromework were used, the mechanisms are all original but were fully refurbed.
Heater ModsWe knew that the standard heater was never the best. So we worked out if we needed one, and if so how did we want to use it. The conclusion was that yes we wanted one, and a newer 2 speed one at that, we wanted it to be hidden under the dash rather than hanging out the bottom as they are as standard, and it would only ever have to be used to demist the windscreen on a cold morning on the way to a show, or as it turned out in the torrential rain on the way back from L2B!
So we modified the heater so that it only had the blower towards the screen, it was permanently on hot and so that it was either in the 'off' position or 'setting 2'. We also swapped the standard corrugated pipes for a more modern, better sealed system using plumbing pipe, agreed its not the prettiest or most conventional but it allowed us to route the pipes where we wanted, it makes the most of the air available with no leaks, and its all going to be hidden under the dash anyway. This is all controlled from one of the switches on the dash and it works really well.
RollcageI wanted a rollcage. It would be 6 a point cage with a small amount of safety considered, but really I wanted it for aesthetics. So I knew of MPS from when a friend had a 1/2 cage made for his Nova back in the day. Normally they would make it out of 1.5" tubing, but I wanted it even chunkier so asked if they could do it out of 2" tube, which they could. It’s not a 5minute job to fit it, but once it was in it looks the business. It was also colour coded to bring some of the exterior colour into the car.
WheelsWhen I first owned the car I had 6x10 revolutions on, and if it was solely up to me I'd have had another 6x10 this time round, but Rich & Chris insisted we went for a more modern size giving the car a better stance and allowing a little more ground clearance. So I opted for 8x13 Revolution Split Rims wrapped in Yoko's finest A048 road legal cut slicks. When I bought them they had black centres, but these were soon colour coded.
