Time for some appreciation of an overlooked rally retro - the good ole' Lada! Ive not been able to dig up much about it but this is what I could find:
Also known as the Zhiguli, this Russian car, based on the Fiat 124, started production in 1970 with the 2101. It remained a Russian best seller for decades afterwards. In Vilnius (Lithuania) a firm called VFTS constructed modified racing versions of the old Lada. The Lada 2105 VFTS was created by the legendary Soviet racer Stasys Brundza, who won the 1974 Tour d' Europe in a Moskvitch-412 and placed 6th in 1976 Acropolys Rally in a Lada 1600.
Specifications:
Lada VFTS (Zhiguli 2105)
Homologation: 01.10.1982 (B222)
Weight: 920kg (lbs)(Evo 1)
Weight: 820kg (lbs) with aluminum components (Evo 2)
Engine Specifications:
Engine: 1569cc Inline 4 cylinder
Bore: 79.5mm
Stroke: 80mm
Compression: 11.5:1
Induction: Two Weber 40 DCOE Carburetors
Power: 160hp @ 7000rpm
Torque: 164.8 Nm @ 5500rpm
I was also sent some info on a 1.8L turbo VFTS 2105 Engine
Engine: 1.8L (Evo) Inline 4 cylinder
Induction: Forced Turbo
Head: DOHC 16v
Power: 240hp
( from www.groupbrally.com/lada.shtml )
Specifications:
Bore: 79.5mm
Stroke: 80mm
Compression: 11.5:1
Head: DOHC 16v
Power: 240hp
