stueyt
Saving cars from the scrapyard.
Mar 26, 2011 19:38:44 GMT
Hi Guys, This is my latest project, I decided to make a start on it whilst I am awaiting the money to get the exhaust for the Cortina. At 10 this morning this is what she lookd like. After about an hour remoing stubborn bolts with the angle grinder, she was looking like a gasser But she needed to be higher at the front, so up she went After a couple more hours messing around she looked like this. The chassis is a bit worse for wear but a day cutting and welding should get it sorted. These are the worst areas. I will get the Cortina out of the garage and get the chassis in at some point, just need to decide what body I am going to use, I would like a Model A coupe but that will depend on finances and what is about at the time. Cheers, Stu.
Last Edit: Mar 28, 2011 7:00:09 GMT by stueyt
Always looking for the next project!
stefan
If it isn't broken fix it till it is
Mar 26, 2011 21:41:28 GMT
Nice, I wish the chassis I am using was that solid. Mine is alot worse than that.
POWER IS EVERYTHING WITHOUT CONTROL
1985 Honda jazz 1997 Saab 93 convertible 2010 transit 280
skinnylew
Club RR Member Number: 11
1974 Scimitar Hot Rod projectskinnylew
@skinnylew
Club Retro Rides Member 11
Mar 26, 2011 22:10:33 GMT
[] thinking Thinking outside the box (^ see what i did there ;D) what about doing something a bit off the wall, modern take on the hot rod idea. take something like this: and break it down into 4 sections. chassis/engine/body/front end now apply that to a retro car. like the Golf ^ but better proportioned (the rear on the Golf is too low/squat, the front tyres to tall. I reckon it could work, its definitely different and should (maybe?) be ok points wise for the BIVA or whatever it's called this week!! Maybe even use the Scimitar body but narrowed by an inch or two with the front end off completely?
Gonna watch this with interest dude, I'm after building a rod at some stage
good luck stuey.
stefan
That last one now has a gasser style front end I think.
I am using mine for a classic modified racer but i will build a hot rod on one soon ish.
Corbs
Mar 27, 2011 13:11:23 GMT
Are you going to be binning the body? Looks really clean!
Hilarious signature
Mar 27, 2011 17:13:28 GMT
it's being sold off
stefan
Mar 27, 2011 17:30:08 GMT
Being fiberglass most of them look clean
Corbs
Mar 27, 2011 20:54:55 GMT
ORLY? I never knew that!
Hilarious signature
stueyt
Guys, Thanks for the positive reponses, I'm not too sure on the golf idea it doesn't really float my boat The gold A sedan is my mates car and you are correct it is bnow built gasser style. I have driven that actual car car and it goes really well even with the standard eseex engine in it. As for thinking outside the box, I know of a Reliant Kitten fibreglass Funny car body that could be made to fit I have more photos to upload but my internet at home as packed in so I will get them up as and when I can. I did consider getting a 100E or 105E body and grafting that on, I may have to start getting some measurements Cheers, Stu.
Last Edit: Mar 28, 2011 10:45:26 GMT by stueyt
