Apr 18, 2011 19:51:30 GMT
...Actually its for a Wolseley 18/85, made by Girling. The part number is 64674336 Are there any out there?
I could also be interested in any other landcrab parts that may be knocking about!
Apr 18, 2011 19:57:21 GMT
Hi, can you get a picture up of it?
I have 2 working spare girling slave cylinders from the same era, one off a dolomite, one off an 1800 marina? All BL, so may fit?
Tillio Race Prep and Spares Ltd
Oval racing Rollcage fabrication from £250.....Track car builds, engine conversions etc...
Apr 18, 2011 20:10:09 GMT
Ill have a go- from what i've read the 1800 crab only shares its slave cylinder with some type of Morgan.
Apr 18, 2011 20:21:37 GMT
Tadaa, pictured with 10p for comparison
Apr 18, 2011 22:06:04 GMT
have the following 1800 bits
clutch hose(x3) £1 each brake hose, £1 cv joint outer end (cup),£10 handbrake cables (x4 pieces), £10 the lot oil filter, £1 air filter (x7)£10 the lot frt wheel bearing (x3),£5 each water pump,£10 throttle cable.£1
or £50 the lot
theres more to life than mpg & to much power is just enough.
Apr 18, 2011 22:09:41 GMT
Ta, I don't think I need any of those bits ATM but i'll bear them in mind when I do!
Apr 19, 2011 21:12:48 GMT
Ive buggered the thread for the bleed nipple in the one in the pic, does anyone know if they can be refurbed?
