Apr 27, 2011 20:56:46 GMT
Sooo.. with the brillient weather we have been having recently, I naturally reached for the BBQ. Damn!! The gas bottle was empty. Oh well I thought, I will give the BBQ a service and pick up a new bottle. Out came the racks and lava rock. Hmm.. I thought, the flame holder looks pretty rusty. Best get the wire brush out and clean that up.... Poo! A new gas bottle refil was £30, but I can get £30 back if I give the bottle back and cancel the contract (or keep it and make a wood burner ) so I decided that it was time to create a mega BBQ oven cooking centre. A friend had recently given me a load of high density concrete blocks and a load of bricks left over from a job he did. He also gave me a massive slab of slate. So... to work. I nominated a corner of the patio Laid out some blocks to get an idea of what would fit without taking up too much space It looked good, so I drew up a few plans and idea and then set to work. The plan is to make a corner unit with a central brick lined oven area. Above that will be a metal grill or a slab of slate cut to fit in its place. The concrete blocks will from the outer shell with a brick lined combustion area. I can either use the oven area as an oven (with the slate closing the top off) or the grill to BBQ over a wood fire. This gives me the option to do many many things with this BBQ oven like putting a concrete slab in there to cook pizza, an rotisery rack, normal oven racks etc. I am also going to make a pan that will sit into the top opening to so that I can burn charcoal with the grill on top like a normal BBQ. So here are some pics. I staggered the bricks making the inner combustion area so that racks or slabs can be placed within the oven. I cut one of the big concrete slabs in half to make the two side table esk areas Oven lined with bricks This evening I mocked up the base of the chimney. Needs some work but the idea is there. Here is a pic of the slate that I will use for parts of the top etc The top of the BBQ oven at the front will be closed off to form the grill area. So some more progress pics soon Lewis
Last Edit: Jan 12, 2012 20:27:24 GMT by lewist123
hamps
www.medwayrscentre.co.uk
Apr 27, 2011 21:16:00 GMT
cool love it good job
Apr 28, 2011 17:27:11 GMT
awesome, thats a proper manly bbq
1969 massey ferguson 135- running, with a minor fuel leak 1989 vw polo squareback- scrapped 1988 toyota hilux with rollcage, landrover running gear and soon to be v8 1997 peugeot 306 dturbo -for sale- pm me 2007 toyota hilux invincible - fast and modern!!!
Apr 28, 2011 20:29:50 GMT
Well I was having a poke around work today for stuff. I work at a company that deals in timber consultancy and testing (of many and various sorts). We have a 'scraps' bin at work. Any off cuts of timber of scrap stuff gets chopped up into bit and stored so that employees can take it for fire wood. The scaps bit in huge, and the following stuff is a small fraction. SCORE So I got a load of softwood 2x4 for firing the oven. Well enough for a burn or two.. I also have a load of logs as well that can be chopped up, but these bits are a great size. I also got a load of different type of hardwood. When using it as an oven, hardwood burns more slowly to give a more gente burn. I snagged some chunks of oak for smoking Some (I think) beach and all sorts of various other stuff, like Iroko, Ipe and some other stuff. As I was walking back into the office, I noticed a pile of scrap bits of ductwork that had been removed from the roof of one of the test labs. I asked the boss man, and snagged a few bits. Lo-and-behold, it fits perfectly. I will level off and fill the tapered bits to make the charcoal tray and an oven tray or some such. I will also use one of the other bits in the chimney intake bit. More over the weekend (hopefully). Lewis
Apr 28, 2011 21:30:57 GMT
That ducting looks galvanised. I'd do checks on it as the heat could damage it and taint your food.
Apr 28, 2011 21:44:01 GMT
True, and a good point that I hadn't considered.
Thanks
Taking shape nicely!
it might be worth filling the voids with Micalite too (granular stuff used for cavity fill in chimneys, aga's and other hot things!). It keeps the outside temps down - giving you a more stable surface for rendering over and less burnt children - and inside temps up!
Joe
Joe
That was generally the plan, although I had planned to fill it with gravel, rubble and other stuff that I have knocking about. The brick lining should keep the temps of the concrete structure right down. I need to figure out how to insulate the door. That will get much much hotter. It will probably be double skinned and insulated.
Lewis
Apr 30, 2011 18:41:59 GMT
Apr 30, 2011 18:52:55 GMT
So onto today.. I will mainly let the pics to the talking... Bricks at the front had dried Render getting there As i was cutting the flue hole in one of the slabs it cracked on me SO I had to do that one over again Sucess!! I then started to add the other tops into place. I then cut and test fitted the slate black (used when being used as an oven only). Then the start of the chimney Nice and level (was a quite a suprise tbh) I then made a small fire to check that the chimney draws Rack in place I then knocked a charcoal tray up out of a bit of old steel sheet Needs the whole welded up I also made a divider so I don't have to use the whole charcoal bit (big) And a parting shot. I just need to make a door now as well as a rotisery rack and BBQ grill grid with hieght adjusters Bread next!!! Lewis
Apr 30, 2011 19:21:36 GMT
Looks good ...
You gonna do a winning video like this when its up and running?
Apr 30, 2011 21:13:19 GMT
Bum.... the internet just ate my post. So here it is again (hopefully i can remember what I wrote first time).. I decided to fire the oven tonight to have a little test burn and cook some bread. Here is the dough And here is my loaf tin Now some of you (well maybe not) might be thinking, hey, he made his own bread dough. Well, to tell the truth I let the bread maker do the work. It has a great dough cycle that mixes, needs and gives first prooving to the dough. So after it did its work, i poped it in the tin, covered it in foil and popped it in a warm spot to rise again (not like the undead or anything like that). So into the oven where my ribs were nicely warmed though. After lots and lots of pacing like an expectant father, it was looking goood...... It came out after one hour looking OK. The sides were quite dark, but not actually burnt. Slice BUTTER It was a fairly good loaf! They are fairly variable at the best of times, but this one is good! I will be toasting it for breakfast tomorrow and thinking about what to do next. Lewis
Awesome stuff Lewis, I was going to post the other day, and then typically the PC crashed when I hit the post button.
Learning from you as I go along.
Thanks mate, I am learning too!! This afternoon we had a family BBQ. I didn't have time to make the grill racking so just 'freesyled' it with some bricks and a small rack. I also decided to fire the oven on some big chucks of log. Last night I was firing it on softwood 2x4 (untreated obviously), and had issues in maintaining the temp. The wood burned too hot too fast to maintain a consistent heat. The logs worked much better, burning more slowly and not smoking as much (tannins and tar in the softwood). Here it is set up with the charcoal pan Bits of wood to burn Baked potatoes in the oven (corn went in as well later on) Chicken marinading in BBQ sauce Firing up the charcoal getting ready to cook YUM So, all in all it worked really well. Oven got really nice and hot. Backed spuds and corn were excellent. Charcoal pan worked well as well, and will be better with a bigger rack and some height adjustment. After the food was oven, I took the oven door away, and threw on some more wood to keep warm Thanks Lewis
TS
God I'm hungry now. Great work.
Inspiring pic.
Colonelk
Club RR Member Number: 83
like it
^ I'll cook you some dinner on it later if you want Grizz - thanks mate. Was yummy I tried to cook a puff pastry pizza the other day. I cut a slab os slate, popped into the lowest rack, and set a nice fire. I think I did too much fire, becuase the base burnt before the cheese was fully browned, but its all a learning curve. Thanks Lewis
Last Edit: May 5, 2011 18:20:30 GMT by lewist123
i really like that buddy excellent idea i really want to make one now, but the parents wouldnt agree :L
Nobody dies a virgin, because lifes curse word us ALL
Well, we had a big BBQ today for the family, ColonelK, Myke and his better half Collette. I was a bit more ambitious today and cooked a small belly of pork in the oven on the slate slab (as well as the usual BBQ faire). No shots of the pork in the BBQ oven I am afraid, but got the oven good and hot on a mix of lumpwood charcoal and big logs to get a big hot ash bed going. I then roasted it uncovered for 2 hours (lots of salt and pepper on the skin). The slate got really really hot and caused the bottom of the belly to crisp up as well as the crackling, but it was really nice, and the pork flesh was moist and juicy. ColonelK liked it very much and then proceeded to pic all the scraps off the chopping board. That went quick
Last Edit: May 8, 2011 20:19:54 GMT by lewist123
