Link, now fixed
cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=250821974745&ssPageName=STRK:MESELX:IT
Thanks for looking
Offered for auction is a 1300cc high compression crossflow engine, as fitted to Mk1 / Mk2 Ford Escorts and Cortinas. This particular engine came from my father's Mk2 Cortina Estate, and has been dry stored for the past 25yrs since the car was broken.
The engine is complete with inlet and exhaust manifolds, flywheel, clutch and dynamo; the carburettor is included but is in pieces and a bit of a sorry state. The distributor and plug leads are not present. Since liberating it from the stores I have removed the plugs and squirted some oil down the bores; the engine turns freely by hand.
Aside from the few missing bits and some damage to the dynamo pulley I have no reason to doubt that this engine is in fine working order. The old chap thinks the engine was partially rebuilt in his ownership; having the crank reground and appropriate undersize bearings fitted.
Due to its size and weight this item is being offered for collection only.
Thanks for looking
