Hi, I know I haven't posted on here for a while but I have been clearing out the garage so I can crack on the with the Cortina I will be putting these bits on ebay but if anyone is interested just let me know.
1500 Precrossflow conrods, in good condition but I would get the balenced before fitting £20
1500 Precrossflow crank - I was told it needed a re grind but I can't remember how much it needs. the reason I did'nt fit it was because the other crank I had was in better condition - £20
I'm not sure if it is a radiator from a mk2 cortina or a mk2 escort - it came from a mk2 lotus cortina but it wasn't the standard big header tank rad. some of the fins are bent but it seems to be ok to use £10
An XP foam air filter that fits to a 28/36 DCD webber carb as fitted to the mk1 cortina GT's - its useable but has wear £5
A triumph herald 1200 steering wheel - has worn over the year but it could be easily be resprayed £10
2 Mk1 cortina GT exhaust manifolds - both need some welding but they are getting thin on the ground now -£15 each
1st one
the end on this one is in good condition which is rare!
2nd one
the end on this one has been welded but it is air tight
3 13 inch tyres (i will add the sizes later becuase I forgot to write them down!) they all have plenty of tread they came off various wheels I have had - free to a good home!
a set of E36 15" wheels which I took off mine because I got a set of m3 wheels - tyres have plenty of tread and they have new centre caps but the wheels have marks on them but they are good £50
3 mk2 golf gti wheel arches (drivers front is missing) I only needed one but I couldnt by it on its own - brand new and unused £10
A mk1 Cortina Handbrake £5
I think this is a flywheel from an essex v6 I got it with a 2000e gearbox that came from a mk1 escort super sport £10 but I need to warn you it weighs the same as a small moon!
A pair of M16 calipers hubs and pads from a mk1 escort which I bought for the cortina but I am looking at getting 4 pots instead they were rebuilt before I bought them they have pads too - £45
A voltage regulator from my mk1 - I wont need it because I am going to use an alternator it worked till I removed the engine £5
I do have more to add but I have forgotten what else I have to sell and I will get some pics sorted too
1st one
2nd one
