Jul 10, 2011 12:49:19 GMT
My indicators have started to play up. When indicating left the lights work fine, however telltail lights up as if hazards are on. When turning right, lights go double speed and telltail lights up like hazards are on.
Been around car and checked all cluster earthing points, everything is still the same, where do i try next?
1977 datsun 810 180b estate
bl1300
Jul 10, 2011 13:20:11 GMT
Double check all your earths. It does sound like an earth problem. Clean all the contacts up with some wet and dry and see what its like then
Current fleet.
Jul 10, 2011 14:13:00 GMT
Took all lights out cleaned connectors, double checked for anymore earths and still the same.
Jul 10, 2011 16:50:53 GMT
could be a duff hazard switch... all the contacts meet there.
edit I'm assuming (and hoping) that the multipla isn't CANBUS.....
Jul 10, 2011 19:50:40 GMT
wow, a fiat with electrical problems...who would have thought, lol
have you checked the fuses? whether the correct wattage bulbs are in it?
Jul 10, 2011 20:13:50 GMT
wow, a fiat with electrical problems...who would have thought, lol have you checked the fuses? whether the correct wattage bulbs are in it? Yeah it seems inevitable, my google-fu is weak on this one as i cba to trawl through 4 pages of total electrical meltdown to find what the issue could be!! At least the weak gearbox issue is sorted for now! Hazard switches seem to be a constant supply of issues, but then so does the rest of anything with wires going into it on these motors. Think i'll admit defeat and purchase a haynes manual and go through the wiring etc to see what i should be getting and where, then take it from there.
Jul 10, 2011 22:13:06 GMT
do the indicators still indicate?
bortaf
Jul 10, 2011 22:40:46 GMT
Somone hasn't used an LED on one unit have they? they cause fast flash and faults to show up on the bulb out display ?
R.I.P photobucket
Both the hazards and indicators work, its just rh side goes too fast even though all 3 bulbs work. Also when indicating both telltales light on dash. I've had all bulbs out and cleaned so i probably would of noticed an led in the mix.
are you sure one of them isn't a lower wattage?
when i changed to bike indicators on my golf, they were 12W, and both flashed very quickly. when i changed them to 25W, they falshed as before
I've rechecked and i didn't notice that the RH rear bulb is a 12w not a 21w, doh.
bl1300
Jul 11, 2011 11:33:55 GMT
That would do the fast flash but cant see why it would light up both tell tales.
Did it fix it?
Current fleet.
Jul 11, 2011 12:06:51 GMT
No its still lighting up both tell tales, reading up on it looks as if it'll be fine for MOT and if so i'll leave it be as everything else now works fine!
EmDee
Committer of Autrocities.
Club RR Member Number: 108
indicator woes- fiat multipla!EmDee
@emdee
Club Retro Rides Member 108
Jul 11, 2011 12:48:12 GMT
Sadly there is no Haynes manual for the Multipla Out of interest what year is yours? Mine only has one indicator light on the dash (51 plate).
Jul 11, 2011 12:51:16 GMT
Mines a 2000 reg, does yours look like 2 seperate arrows but both illuminate off 1 bulb/led?
EmDee
@emdee
Jul 11, 2011 15:37:59 GMT
Mines a 2000 reg, does yours look like 2 seperate arrows but both illuminate off 1 bulb/led? yup I believe that's exactly how Enzo J Fiat intended it - even if it is a little err Italianey
Jul 11, 2011 16:27:07 GMT
Why can't they be like normal cars? i'm looking at a problem that isn't there. If it wasn't so practical it wouldn't be here long.
