aar0sc
It's my first car; Flamenco Red; with black interior and the original hood etc. It's been "restored" (80s style) a few times; but not for about 15 years now; so it's in need of a bit of TLC. Currently have the engine; interior; gearbox and bonnet off/out; as I'm having to swap my old engine (drank oil quicker than petrol) for a new one This afternoon I'm off to get it in fact! Aaron
Nice looking spitfire from the photo's prefer chrome bumper spitfires, even with the big overirders! over the mg rubber bumpers.
aar0sc
Cheers! Apparently Triumph had the right friends in the US government; so they only gave US cars plastic bumpers; and only right at the end As it is now:
ian65
that's a familiar sight..... I've owned and restored loads of Spitfires over the years.... great British roadster and easy classic to own.... are you dropping another 1500 engine into it? here's my last one... ians-spit.blogspot.com/
aar0sc
Yep; another 1500 - I'm going to rebuild it over winter Edit: I'm going to rebuild my old engine over winter; the one I'm dropping in is a temporary thing; ex Dolomite
Last Edit: Aug 8, 2011 18:08:39 GMT by aar0sc
aar0sc
Aug 10, 2011 22:31:11 GMT
Aug 11, 2011 12:28:14 GMT
Aaron, I hope you've found out how much that's going to put your insurance up first... Though when I fitted the mods to mine, it went down. No, I don't know either.
aar0sc
Aug 11, 2011 22:12:55 GMT
I'll check; if it makes a difference then I'll stick with steelies and hold onto the Slots for a year or two It's already got K&N filters; Pheonix Twin S/S exhaust; MkIV seats; Mountney Steering wheel; and of course an aftermarket radio. And having told the insurance company all of that (and probably some other stuff I've forgotten!); they put filters and 'zorst on the mods section :?
They probably weren't all that fussed about the seats, seeing as they're from another Spit. Wheel and radio is a surprise though. Anyway, good luck with it, I've been keeping an eye on progress on the TDC forum too...
aar0sc
Ooo I'm being stalked for once! It's normally me stalking Howard
aar0sc
Aug 14, 2011 21:51:53 GMT
Just to keep you up to date with were I wam now. Oh; and you'll love this; I was explaining to mum that the battery's a tad curse word and that I plan to replace it with a better one - mum: "So maybe this car wasn't a good buy then? Maybe you should sell it and buy a better on?" :roll: Anyway; rad on (harder than normal (oo eer!) as the bar that holds it has twisted in due to the weight of the last engine sitting on it before we got it out :? Probably putting the jack there tomorrow will help; but I've pulled it back enough to get three of the four bolts in); plumbed and filled with water; tightened up everything and fitted the clutch slave cylinder - needs bleeding. Gave it a little extra oil (the stuff it had in is disgusting but I'll change that and the filter as soon as it runs (it's encouragement, right? Like a reward?...) ). Popped the LHS carb on and tightened it up; (new gaskets); then put on the throttle and choke shafts - bit of twiddling about as neither Haynes nor Leyland say which way they go round; so after a bit of guesswork I got them both on (then I put on the other carb). So now I gave everything one last check; tightened up all of the fuel and water lines; and hooked up the battery to give it a whirl. Nowt. Took off the fuel line at the carbs to see if there was any fuel there - none... odd! Check the pipes - fine; so took off the top of the fuel pump - dry... weird; it sprayed everywhere yesterday! Lowered the cap slightly whilst looking at the innards of the pump; and fuel began coming out again! Filled the cap; so tipped that into the body of the pump; assuming this might prime it...? No; it didn't. So I switched to my old pump; bit of hammering to get the linkage back in (fell out when I removed the last engine); and a quick change meant no lost fuel - turned it over and petrol sprays up at the carbs - hook them back up again; hold the choke open and went for it! Not a cough. :cry: So I got the HT testers that we bought for the Austin; and hooked them up - each one lit up in turn; 1-3-4-2. Hmm. Played around with it abit. Went to a car show. Came back. Played a bit more. Still nowt :? A bit later; I swapped the HT leads round; incase it was 180 deg out - a bit of a cough. Then came back inside Aaron
aar0sc
Sept 9, 2011 19:42:05 GMT
IT RUNS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1 Just gotta refit the bonnet and interior and it'll be pootling about Haslemere this weekend!
Sept 9, 2011 21:17:05 GMT
Excellent, well done
Sept 13, 2011 7:45:48 GMT
Nice - These cars are well underated
aar0sc
Sept 13, 2011 21:27:44 GMT
My Spit will be at the Goodwood Revival, Car Park C - and I'll be in the marshall's tent if you want to give me parts for it (as if (But if you want to, I mean; I'd be happy to ).
aar0sc
Sept 16, 2011 21:20:02 GMT
My Spit will be at the Goodwood Revival, Car Park C - and I'll be in the marshall's tent if you want to give me parts for it (as if (But if you want to, I mean; I'd be happy to ). *cry* no it won't 'cos dad won't let me drive it there! Will have to hitch a lift with someone
aar0sc
So; if you're interested, here are a few photos of the Spit, between my getting the engine started and going for it's first drive: Bonnet on Headlamps working Grille; splitter etc Aerodynamic numberplate...! Interior in (GOD that center panel's a female dog!) And it's first drive... to the petrol station And as it is now because I stupidly decided to change a brake line as a "simple" job...
Last Edit: Oct 1, 2011 19:52:46 GMT by aar0sc
aar0sc
Hmmm... me neither! Other forums let me link them off facebook, is this retrorides thing?
aar0sc
Ok; I've had a play around and it's a retrorides thing... how do I get round this?
