Aug 18, 2011 10:29:56 GMT
***GARAGE CURRENTLY EMPTY***
stefan
If it isn't broken fix it till it is
Aug 18, 2011 10:43:33 GMT
I love them and have thought about buying one many times to go with the E23 I have, I know they can rust alot and front wings are expensive but the runnung gear should be fine as alot is from other models.
I say go for it
POWER IS EVERYTHING WITHOUT CONTROL
1985 Honda jazz 1997 Saab 93 convertible 2010 transit 280
EmDee
Committer of Autrocities.
Club RR Member Number: 108
Aug 18, 2011 10:56:39 GMT
Yes.
You Should.
For:
awesome car rwd motoring bliss future classic, can only increase in value the laydees your member will increase in size get away with wearing a medallion in public
Against:
errr... spensive front wings?
Aug 18, 2011 11:25:15 GMT
There's only one answer to that question. This argument trumps any possible objection anyone might have ;D : For:...get away with wearing a medallion in public How can you not love that profile?
" East bound and down, loaded up and truckin' "
Aug 18, 2011 11:29:29 GMT
Aug 18, 2011 12:22:11 GMT
How can you not love that profile? easy, it's got US bumpers have a euro-spec There is no downsides as far as I'm concerned.
Jowey
Aug 18, 2011 14:04:05 GMT
only downside is fuel economy and the standard wheels have metric sized tires.
530TDS in one of these and you have the perfect car IMO
2000 Mercedes E55 //AMG 1998 Alfa Reomeo GTV 24v 1997 Alfa Romeo Spider 16v 1996 Alfa Romeo Spider 16v 1996 Suzki Swift 1.0 GLS
Aug 18, 2011 16:13:15 GMT
How can you not love that profile? easy, it's got US bumpers Thats a Highline, the last of the line E24 with all the trimmings. This is a Federal-spec E24: A quick guide: The 6er started life in 1976. Earliest examples were built by Karmann and like with most Karmann-built cars, rot like a c#nt. In '78 BMW bought production in-house to the Dingolfing plant (which incidentally, they inherited from the takeover of Glas), fitted the better 7 series front suspension and nylon flex discs on driveshafts. In '82 the running gear from the E28 5-series was fitted; better suspension, less weight, better electronics, new intake manifold, nicer dash, ABS,etc. Mid'87- The 'Highline' facelift. More modern looking bumpers, some detail changes, top mounting oil filter, ellipsoid headlamps. The last car were made in February '89, about 80,000 were made overall. Sixes are very well made cars but even the youngest is now 21 years old. They rust, but it's not fatal. The biggest problem is the front wings. They have no inner splash gaurd except at the back (20 quid each and I'll bet yours need replacing) and this causes both the inner and outer wings to rust. They cost about £450 each but the trick is to order a wing from a pre-'82 6er which is £100 cheaper and only lacks turn indicator holes! The inner wing can just be welded up. The rear shock towers are a common weak spot in old BMWs but the Six isn't as bad as the 2002, worth a check though. If the door drains clog the bottom of the door will rust out. Rust can also start behind the trim strips on the door where the metal is perforated but this can be stopped if caught. If the sill drains clog the sill will rust, they start at the back. A partial sill costs about £300+VAT. Check the four sunroof drains aren't rusty as they are very difficult to fix if they leak. If they become clogged you'll get water in the footwells. A bad windscreen seal can also cause this, as well as flooding the glovebox in the process.
Last Edit: Aug 18, 2011 16:17:03 GMT by e21meister
Aug 18, 2011 17:46:34 GMT
My mates got a white 635csi, think its a "79.
Goes like stink and all the milfs love it!
Aug 18, 2011 18:17:46 GMT
A good friend mentioned that a certain geezer in a certain London based British soap opera drove a 6-series... Here is what I found... Now does that make me want it more or less...?!?!?! I actually think more...
Aug 18, 2011 18:52:22 GMT
Aug 18, 2011 19:17:29 GMT
Do it, I had an 1983 628i and it was one of the best cars that I have ever owned. ;D
1955 Austin A30 1981 Jawa Mustang 1990 Trabant 601 (Tommy) 1989 Trabant 601 2009 Jaguar XF 2012 Toyota AYGO 2018 Scomadi TL
MonzaPhil
Aug 18, 2011 19:23:55 GMT
I have always lusted after one of these for the fleet. I would always go for a late model one though. Yes the 70s kick ass but as with all these things (500SEC, Monza GSE, SD1) the later you get the more bits you get and the less time it's had to rot. Yes you should get one* * I make no guarantee that my advice is good advice.
This is now a clicky linky!
Aug 18, 2011 21:42:13 GMT
Oh yes. I only got rid of mine because I was a bit skint, and it was thirsty. Fors: Looks the business Fast Sideways Comfortable Sounds the business Against Economy (lack of) Rusty front wings. This was mine. Went to Luxembourg to be stripped of it's leather Recaros
I think I've found the deal breaker... That (almost) just about seals the deal for me...!!!
THE_Liam
Yorkshire and The Humber
Aug 19, 2011 12:39:47 GMT
LOVE these, have for years! For: Looks Comfort Power Surprisingly nimble as aircraft carriers go Quality Reliability Exclusivity, except for my mates 635CSI Shadowline I have NEVER seen one on the road Against: Rust Parts prices (won't need much though) MPG I suppose, but if you want economy buy a 106 diesel or a bike, not a grand tourer.... DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT DO IT.... Convinced?
Aug 20, 2011 11:57:33 GMT
Well I really do think I am going to go for a 6-series...!!! Save for a few insurance headaches I think it's going to be ok (damn, cursed it)... However, I'm not going to be lending my 6-er to my good mate Bruce Willis...!!! I don't think he likes them...
Aug 20, 2011 12:52:21 GMT
Matt Jones one looked pretty hot on those alloys i thought.
Aug 20, 2011 21:37:57 GMT
I know, I already posted this in the thread about the one where you were asking about the insurance. I'm sure I've helped out there already. Here are some of the other photos of my old one. I sold it because I'd owned it for a few years and as I said in the other thread it used to give me a bit of back ache. Mine was a highline so had lots of extras including LSD, sports leather, tinted windscreen top, heated electric seats, air conditioning, cruise control. People used to pull along side and ask if they could buy it. I loved the way the big six used to sing as you got up to the red line. It made a lovely sort of mechanical sound like a real engine. I got 135 out of it once but it took ages to get there. I put it on the rolling road as well. It's an auto so difficult to get a proper figure off the rolling road but on the power stroke it was well over 200hp. These days that's not much to me but at the time having that beast strapped to the rollers singing it's song was nothing short of awesome. I learned how to kick the back out going round corners in a sort of non fishtailing really cool sort of way. It is an iconic design and actually featured in numerous 'art' books as an example of a beautiful car. If I'm ever really rich at any point in the future I'd love a red M6 with a cream interior. Here's one Munich Legends were selling a few years ago.
