Sinky
Run Baby Run......Please!
Aug 23, 2011 12:19:14 GMT
Ok My Mk2 Granada 2.8i When I'm stationary,rev it up to 4000rpm. It comes down ok quite quickly to about 1500rpm then takes awhile from 1500 to 900rpm maybe about 10secs Any ideas whats wrong and how to cure Thanks
2001 Volvo XC70 wagon
2003 Piaggio X9 Evo
Aug 23, 2011 12:25:49 GMT
sounds like your throttle cable is possibly frayed near the end causing it to stick when its trying to return - try checking the pedal with the engine off (this is just a guess though)
2001 Micra 998 - Daily
1986 Mini Mayfair 998 - Former Daily - Garaged
mk2cossie
Club RR Member Number: 77
RPM mk2cossie
@mk2cossie
Club Retro Rides Member 77
Aug 23, 2011 12:47:17 GMT
sounds about normal to me, as the idle valve will try to prevent it from going straight back to 7-800rpm idle which would normally cause it to stall ;D may be worth checking that the throttle butterfly and the idle valve arent gummed up with curse word though
Tim
Aug 23, 2011 12:54:43 GMT
Carb Cleaner :-)
RPM scaryoldcortina
@scaryoldcortina
Aug 23, 2011 13:33:41 GMT
Sounds like a sticky idle air valve to me...
Sinky
Aug 23, 2011 14:06:24 GMT
Eh... where would I find the idle air valve on v6 2.8i 1981 Iv looked at my Haynes but cant find.
2003 Piaggio X9 Evo
bortaf
Aug 23, 2011 14:29:24 GMT
R.I.P photobucket
Sinky
Aug 23, 2011 15:29:02 GMT
Thanks. Where would that be ? Can i get to it?
2003 Piaggio X9 Evo
RPM Robinxr4i
@robinxr4i
Club Retro Rides Member 143
Aug 23, 2011 18:42:16 GMT
I haz made you a picture ;D ............. Edit: Providing it's in the same place as the Sierra one (same engine) Looks like this close up.......
Last Edit: Aug 23, 2011 18:44:50 GMT by Robinxr4i
Sinky
Aug 23, 2011 18:47:21 GMT
Perfic info lads. Thanks for the pic.
2003 Piaggio X9 Evo
Sinky
Aug 28, 2011 18:43:34 GMT
Ok guys Cleaned the Aux valve with carb cleaner. No joy. Could it just be knackerd all together?
2003 Piaggio X9 Evo
