Starting a little cleanup of all my junk - more to be added, once I've dug them out (including compressor and generator!)
First, a lovely little bit of weird retro.. a 12v broiller!
I've used it a couple of times, and warms up poptarts fairly well! ;D £15 posted Provisionally sold
64mm jag v12 throttle body, originally comes with a weird linkage mechanism, mouted as part of the manifold. Easy enough to make a fitment that bolts striaght onto the shaft though
Should have a second one somewhere too, will be up in the next day or so if I find it!£12 posted, each x1 Provisionally sold
SIP airtools
Due to the condition of the tools £70. Can post if wanted, for an extra £10 SOLD!
A monstrous radiator, taken from a Citroen XM 1.9Td Width is around 31", height is around 16.5", and pipe connections are approx 1.5"
£10 - postage might be possible, but would easily be as much as I'm asking for it in the first place! Can take to Manchester for collection if closer than Norfolk
An equally monstrous intercooler, Apparently meant for a Toyota Corrolla. Was bought brand-new, and never been fitted to anything. Has the obvious storage marks that any intercooler has, but otherwise, as new
Overall length (including end tanks) :86cm / 34"
Overall height: 39cm / 15.5"
Pipe diameter: 2"
Looking for £30 for this,again, collection preffered, either from Norfolk, or Manchester, as I seriously wouldn't trust Royal mail to deliver it in one piece.... SOLD!
Got a few bits on fleabay too:
Small-ish oil cooler
cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=120769105714#ht_500wt_950
Large-ish oil cooler
cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=120769100208
IHI RH5 Turbo
cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=120769109517#ht_500wt_950
LARGE Box of SU carbs
cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=120769112826#ht_500wt_950
Metro Turbo ECU (electronic boost controoler...pretty much)
cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=120769116128#ht_500wt_950
Much more to come in the next few days!
SIP airtools
Pipe diameter: 2"
IHI RH5 Turbo
