Sept 10, 2011 11:26:17 GMT
simple we want to see all your projects (cars) that wont be ready for 2012 and tell us abit about it and what needs to be done just the big ends/ lights / inside and exhaust i cant do due to time i1115.photobucket.com/albums/k551/RATCADDY/Photo0202.jpg[/IMG] cluthc / engine /gearbox /floor pan/ exhaust/ sills all the inside/ there's mine
Last Edit: Sept 10, 2011 11:43:55 GMT by vwratcaddy
qwerty
Club RR Member Number: 52
Sept 10, 2011 11:30:18 GMT
It might be ready! We'll see. Not much needs to be done really I just need a kick up the . Rear Wheel arch, Patch of Chassis leg Rear Quarter Corners Get the back Polybushed Current Engine and box pulling out and new Engine and box fitting. Front Brakes rebuilding (calipers, discs and pads) Windscreen putting in. Roller Painting Building up Buying a Bucket seat and steering wheel and a Bubble/Dildo Gearknob. ........... ;D Oh yeah and I have to re furb the wheels I have for it and try and shoe horn them under the arches!
Last Edit: Sept 10, 2011 14:42:38 GMT by qwerty
Sept 10, 2011 11:39:20 GMT
Sept 10, 2011 13:22:43 GMT
Ooo! Another f-body! Got a build thread yet? Looks hard! This won't be done for 012 It needs a turbo, new rear end, t56 and a paintjob among other things ;D Neither will this It need everything, including a saab turbo engine ;D Although i'm hoping for getting me thumb out and getting hold of a cheap m30b35 donor for this It's been sitting around long enough to start putting ideas in my head again! ;D
kee
Sept 10, 2011 13:40:02 GMT
My mk1 fiesta *just* road legal hillclimb/sprint car won't be ready till 2013 at absolute best. The list includes: new wings, front panel, sill (maybe both), 1 rear arch, patches in kick panel/floor, bulkhead and boot floor. Seam weld entire car Custom welded in roll cage full respray engine build is at the very beginning, still need a custom spec Vulcan Engines head, work doing on the crank/rods to make them rev to 10k safely, rebore to suit pistons I havent got, aand those pistons probably need skimming to fit. lightweight flywheel, new clutch, gearbox needs diff bearings, New race spec cam, custom inlet manifold designing and making to suit the bike bodies I have. Which means I also need a full injection ECU and the appropriate lines/swirl pot/pumps to upgrade from carb fuel pressure to injection pressure. Custom lightweight dashboard needs making. Lightweight but good bucket seat, fibreglass boot/bonnet. Tiny rad to fit down the side of the throttle bodies/infront of the gearbox and brackets making to suit. Need 2 sets of wheels, one with slicks, one with road legal tyres. theres probably more, so i'll be looking at 2013 if i'm lucky. then i've gotta ave up for a BDH
Sept 10, 2011 13:58:31 GMT
Bolt on the front wings/front panel, replace the bonnet, weld up the rear NS inner wheel arch, fit electronic ignition, finish radiator conversion, leccy fan, finish sorting out the 1300fwd steering rack, make a side exit exhaust, sandblast and powdercoat compomotives, weld the passenger sill (again, not happy with the first go), swap the OD box I got in, re-wire for more than 2 fuses, relays for the halogen headlamps, weld up trim holes, bit of welding on the chassis rail, fit the front arb, TR6 rear plate lamp and poly bush it. Oh and paint it all one colour. Not much then... Oops. EDIT; picture won't show, though I'm looking at it in t'bucket. Argh. Edit edited; Fixed.
Sept 10, 2011 14:32:11 GMT
bump
Sept 10, 2011 16:02:33 GMT
bump
Sept 10, 2011 16:06:37 GMT
Last Edit: Sept 10, 2011 16:09:12 GMT by 1430MK1
Sept 10, 2011 16:25:04 GMT
do you wanna sell the wheels
Sept 10, 2011 16:32:29 GMT
click any of the car links in my signature for a car which won't be finished any time soon or possibly ever in my lifetime...
Love your Trans Am BTW
Last Edit: Sept 10, 2011 16:32:59 GMT by akku
Sept 10, 2011 16:49:47 GMT
Sept 10, 2011 16:50:52 GMT
thanks for those mate
spacekadett
F*cking take that Hans Brrix!!
Sept 10, 2011 20:14:24 GMT
I've been threatening to finish this 'next year' for at least the last 3 lol To be fair it is a touch further ahead now than in that pic; most of the filler work is done with I think just the front panel, sills and back panel to sort along with tidying under the bonnet. But then there's paint, wiring and refitting, well, just about everything! Then there's the Kadett coupe and Mini pickup I haven't started yet...
Mechanic's rule #1... If the car works, anything left on the floor after you finished wasn't needed in the first place
Sept 10, 2011 20:27:01 GMT
Sept 10, 2011 20:55:52 GMT
Seeing all these unfinished projects is making me feel MUCH better about mine. Cheers guys! :-)
Sept 10, 2011 21:15:33 GMT
mine
mirafioriman
My next project.......
Sept 10, 2011 21:25:11 GMT
1) My Fiat 130 that is on here. Needs more welding, a paint job, mechanical work, a re trim and putting back together (nightmare) Pictures in the readers rides section! 2) Fiat 131 Supermirafiori 1600T/C. Needs a full body resto and repaint. Mechanics and inside ok (I hope!) 3) Fiat 132 2000. Needs full body resto and paint! 4) Fiat Argenta 2000. Needs full body resto and paint. 5) Fiat 1312 Panorama estate. Needs full body resto, paint and some mechanics. 6) Mercedes 300 SEL 6.3. Needs body resto completed, paint, (expensive!) mechanics. 7) Mercedes 450 SEL 6.9. Needs extensive body resto, (expensive!) mechanics, retrim etc. Notice anything these all have in common ;D
welder
Sept 10, 2011 21:52:17 GMT
1988 Manta. Still trying to get to the bottom of "refusal to start" issues 1974 Ascona estate. Needs full resto.
I'm not completely useless, I can be used as a bad example.
Sept 11, 2011 0:13:42 GMT
bump
