Sept 12, 2011 18:59:01 GMT
I'm converting a Mercedes W202 to manual transmission and need various parts in order to achieve this! If anyone is breaking a manual W202 C-Class, please get in touch. Willing to travel and strip bits off myself if it's easier. PM me or reply on this thread. *EDITED* as I'm now just looking for W202 parts, to make the swap more straightforward!
Last Edit: Sept 23, 2011 19:05:56 GMT by BenzBoy
p1RATE
Sept 12, 2011 19:04:04 GMT
I'm about to rip my w201 engine out with manual gear box (1.8) anything of any use to you?
• 13 BMW 320d
• 92 Pink/Purple Mercedes 190e (Project)
• 97 Rover VI 1.8 (track car)
Sept 12, 2011 19:20:26 GMT
Ideal! I could do with the flywheel, gear lever, linkage and selector rods, clutch slave and (maybe) master cylinder, clutch release bearing lever / fork. Oh and maybe the propshaft... If your car is staying manual then you'll probably need some of those bits though! Let me know which of those bits are available, and an idea of price please. Happy to come and take the bits off if needed as you're not far from me.
Last Edit: Sept 12, 2011 19:22:04 GMT by BenzBoy
p1RATE
Sept 15, 2011 12:35:32 GMT
hi, i though i would give you a pm about the w201 manual box i have. I have not yet completly sorted out which direction I'm going in with my engine transplant so therefore not sure when ill be able to take the parts off. having thought about it I'm working quite a lot at the moment so its probably going to be a while before i get cracking on it. however when i eventualy do i will try and let u know.
Kind Regards, Rob
• 13 BMW 320d
Sept 18, 2011 20:16:29 GMT
Hi, i broke a manual w202 c180 recently, i know the flywheel is still on the engine which is out the car, but I'm not sure about the other parts. If you want my number let me know and i can look in the workshop, jim
1997 BMW E36 328i Touring 2000 Renault Clio 172 ph1 2006 Discovery 3 1996 VW Corrado 16V 2002 BMW E39 530i Sport 1995 Subaru Legacy GT twin turbo 1992 Rover 216 GTi 2002 BMW 330Ci Clubsport SMG E46 2007 Ford Transit 6 seater Jumbo
Sept 23, 2011 19:07:29 GMT
P1RATE - I've sent you a PM. ynnejcantbe - You're a fair distance from me... what sort of price are you after for the 'box?
