Sept 14, 2011 20:49:28 GMT
Sept 14, 2011 21:00:00 GMT
i then started playing with some coilover front struts, started out by see how low it would sit ont the bump stops ( o yea and i will say I'm trying not to spend any money on it so I'm doing everything as cheaply as possible). which is low enough but obviously need some suspension travel so i started looking at ways of getting more travel. i then had a play with some of my other wheels 15" borbet c`s which look good then my show wheels for the mk3 astra, 17" tsw big deeps which look even better but I'm not using them back to the coilovers started by looking at modifying the bottom mounts something like this the black holes are the standard holes, the red holes are the new ones turns out i cant get it much lower but never mind
Sept 14, 2011 21:03:08 GMT
today i had the idea of redoing the top mount, by getting rid of the big rubber top mount new top plate as you can see much smaller then the standard, should give me about 30mm more travel on the shock
Sept 28, 2011 19:10:29 GMT
well afder spending last week sorting the astra out for its mot, iv been able to do a bit more to the nova today. being skint and not being able to find the right size spring mount lock rings for my coilover, i made my own started with this big lump of 66 nylon this is the coilover all built up with mk3 astra top mount i had to make the hole in the strut top mount bigger to fit the astra strut top this is how its sitting at the minute it looks like its got around 3 and a half inch`s of travel which i think is plenty i couldn`t be arsed to do the other side but i did sort out the hole in the backbox, i fitted the powerflow silencer that used to be on the astra. it sounds great, i did do a video but the sound quality is curse word on my camera, so theres not much point putting it on here.
Sept 28, 2011 22:00:30 GMT
You're using plastic to hold your springs in?
Baggsy never getting a lift in that car.
nova saloon low and slowDez
@dez
Club Retro Rides Member 34
Sept 28, 2011 23:17:01 GMT
this has got to be a joke. surely no one is stupid enough to believe thats adequate?
some coilovers do have plastic collars (weitec for example) but they're that funny fibrous hard black plastic, not soft white nylon, and they're full rings that are threaded properly, not split with a pinch bolt and shaped with a chainsaw.
looks like they're FK coilovers- you do know they sell replacement rings for them?
Last Edit: Sept 28, 2011 23:20:35 GMT by Dez
col
wut
Sept 29, 2011 0:20:28 GMT
you de realising the whole weight of your car (and more over a big bump) is resting on the friction between the threads and the nylon right? and nylon is a pretty low friction plastic.
Sept 29, 2011 5:41:26 GMT
i understand all off your concerne`s and to be honest i don't know if its going to work, but thats what i do, i like to try my ideas out and if they don't work then i`ll try something else. and yes they do sell these fk lock rings on the fk website but they are $33 each which is about £21, so for a set of 4 you looking at over £80, which is far to expensive. and as for nylon not being strong, this 66 grade nylon which is very strong stuff, it took me bloody age`s to drill the hole out of the middle. as i have already said if it works then i`ll be more surprised then the lot of you, i`ll let you know when i take it out for a drive.
Sept 29, 2011 6:01:48 GMT
Whereabouts do you live? I want to make sure I'm no where near when you take it out on the road. I'm all for improvisation, but I'm sorry-that looks just plain dangerous. (IMO only of course)
Rob
Sept 29, 2011 8:33:56 GMT
your joking right? also is there an actual bearing in that strut top or is it metal to metal? as for paying £80 for the correct parts, when its something that may stop you from killing yourself or an innocent roaduser on a suspension or brake component the cost is irrelevant. if you cant afford something save for it, don't bodge it. apart from that it actually looks ok. its good to see a 4dr being looked after. oh and tell luke sloth says hi. lol
Last Edit: Sept 29, 2011 8:34:33 GMT by Rob
@dez
Sept 29, 2011 9:39:47 GMT
I understand all off your concerne`s and to be honest I don't know if its going to work, but thats what I do, I like to try my ideas out and if they don't work then i`ll try something else. and yes they do sell these fk lock rings on the fk website but they are $33 each which is about £21, so for a set of 4 you looking at over £80, which is far to expensive. and as for nylon not being strong, this 66 grade nylon which is very strong stuff, it took me bloody age`s to drill the hole out of the middle. as I have already said if it works then i`ll be more surprised then the lot of you, i`ll let you know when I take it out for a drive. its not about 'strength', its about the properties of the material being totally wrong for the task in hand. if they were even remotely right, the coilover manufacturers would use plastic for the collars, are its miles cheaper than the alloy they're made from usually and would stop them seizing and breaking. I'm suprised youve even got em to hold the cars weight, given nylon really shouldnt be threaded like that, and your pinch bolt isnt long enough. they need to be steel or alloy. personally i think if you cant afford something, you cant have it- so if you cant afford some collars, you cant have the coilovers on your car. even just buying two with the spring seats on and locking them off some other way would be preferrable and only cost half as much. or get a local engineering place to make you a couple as a lunchtime job. would only take half an hour to knock up two threaded collars on the lathe in ally or steel. the thread size for an FK is M54x1.5 if that helps. just don't use those nylon ones on the road.....
RA40tony
Rollin' rollin' rollin'
Sept 29, 2011 10:08:39 GMT
Nylon is used for bushes, cos its got nice self-polishing properties... it'll take no time at all for the "threads" in the nylon to wear away... not worth risking it Do as Dez says and get some machine shop to make some for you out of steel or alloy.
1979 Toyota Celica GT. Currently Gone.
1975 Toyota Celica ST. 13x7 Allycats, "the stick" applied. 100kW 4AGE... Sold
1963 Karmann Ghia - Lo & Slo, Sold.
1965 VW Fastback - cruising
1953 Oval Ragtop, work in progress...
zircon
Sept 29, 2011 11:21:55 GMT
It isn't fair to test your theories out on public roads. Imagine everything seems fine and you are driving past a bus stop when suddenly your suspension falls to pieces instanty causing you to plough into 20 people innocently waiting for a bus.
If that still doesn't scare you, imagine if your wife / children etc were in the queue!!!
Don't do it man......
MrSpeedy
East Midlands
www.vintagediesels.co.uk
Sept 29, 2011 11:57:17 GMT
I understand all off your concerne`s and to be honest I don't know if its going to work, but thats what I do, I like to try my ideas out and if they don't work then i`ll try something else. and yes they do sell these fk lock rings on the fk website but they are $33 each which is about £21, so for a set of 4 you looking at over £80, which is far to expensive. and as for nylon not being strong, this 66 grade nylon which is very strong stuff, it took me bloody age`s to drill the hole out of the middle. as I have already said if it works then i`ll be more surprised then the lot of you, i`ll let you know when I take it out for a drive. Firstly, you clearly don't understand everyones concerns, otherwise you wouldn't persist. You clearly don't understand/know what you're doing and it is extrememly irrisponsible of you you 'test your theory' on public roads. I truely hope nothing gives whilst you're driving and causes you to lose control, injuring anyone. Please, do it properly, with proper parts, or leave it the fcuk alone !!
Last Edit: Sept 29, 2011 11:57:54 GMT by MrSpeedy
wiggle
Sept 29, 2011 12:12:23 GMT
woodenspatulas
Retro in ways you can't imagine
Sept 29, 2011 12:20:25 GMT
just pray to the automotive gods before you drive that about.
Or do it off road and SLOWLY
do you enjoy hospital food?
1999 Vectra Estate + 1995 Saab Engine = Good Times
Sept 29, 2011 12:46:06 GMT
Whereabouts do you live? I want to make sure I'm no where near when you take it out on the road. +1
andyf
South West
Sept 29, 2011 13:14:03 GMT
Mate, fair play for trying things out, but just think about what you are doing for a moment. That is nylon and no way will it stand the stresses you are about to put on it. I`m amazed it hasn`t collapsed already.
Best bet is put it back as standard until you can afford to buy proper bits to do the job. You will look less of a dick driving around on normal suspension than you will on a lowered car whose suspension has collapsed at the side of the road / in a ditch / through a shopfront.
1980 Triumph TR7.
Sept 29, 2011 15:01:16 GMT
1973 MK1 2600 Capri - Located in Texas 1976 3.0S Capri - X-Pack long term Project 1978 2.0S Capri 1984 Transit County MK2 4x4 LWB 2.5DI 1985 2.8i Special Capri (v8 5.0L) 1986 2.8i Special Capri 1987 280 Turbo Technics Capri 1993 1.8TD P100 - Beater, parts collector 2008 BMW 320i Touring - Daily
