Nov 20, 2011 23:33:53 GMT
not an easy car to strip down. the internal panels at the front all need to be unrivited to allow the suspension and steering rack to be removed these cars really were poorly put together. thing is now that it'll be wrong to improve it so it'll be put back together with the same poor welds and the same poor finish. just neet to make it reliable and not overheat as it will get used quite a bit. no point doing all this work for it to just sit around ;D rear is now deflared and one side mould made. more pics soon
dw1603
Such a simple structure, almost makes you believe you could build one yourself.
Such a simple structure, almost makes you believe you could build one yourself. Someone should take that idea, and put it into production. Like a kit version ;D
1989 Peugeot 205. You know, the one that was parked in a ditch on the campsite at RRG'17... the glass is always full. but the ratio of air to water may vary.
Absolutely brilliant thread, can't wait for another update. Good work
Nov 21, 2011 18:12:22 GMT
Nov 21, 2011 18:24:04 GMT
Its fascinating watching this progress The kind of info, images and experience you just don't get via a magazine. not an easy car to strip down. the internal panels at the front all need to be unrivited to allow the suspension and steering rack to be removed Would that be the same as on the race cars? It seems strange to me that it would be difficult to repair/replace components that could get damaged on track during, say, a 24hour race.
Nov 21, 2011 18:41:00 GMT
the MK3's were made slightly different. the race cars have huge ducts under the front for the brakes which this road car doesn't have. they were filled in with panels i suppose to make it useable as a sort of boot. otherwise the only storage area is the box in the back which meant that the tail needed to be eight inches longer than the previous GT40. the headlights were raised for the American market, so these changed looks are for a purpose more than just to make it look a little different. Mayhem in Manhatten is a little write up about the GT40 MK3 back in '67
Nov 21, 2011 18:50:27 GMT
Great article, thanks
CIH
Nov 21, 2011 22:28:43 GMT
Wow, mega snazzy workshop too. I like how the rear suspension is mounted direct to the gearbox, proper race car tech.
Nov 21, 2011 23:19:11 GMT
the rear suspension is actually mounted to the chassis very close to the gearbox. the drive shafts are mounted to a rubber doughnut on the gearbox to act as torque damper and allow articulation. on the MK3 suspension arms the inner joints are rubber and the outer ones rose jointed where as the race cars are rose jointed both ends. link to all the GT40 chassis numbers and history
dw1603
Nov 21, 2011 23:32:02 GMT
Such a simple structure, almost makes you believe you could build one yourself. Someone should take that idea, and put it into production. Like a kit version ;D I was talking about the monocoque
Nov 21, 2011 23:45:16 GMT
if you look at the front suspension you will see that the forward most anchor points are further in towards the centre of the car. a lot of kit cars have them parallel. the point of having them angled in like that is so they work as an anti-dive under heavy braking.
restoring an old Ford GT40ChasR
@chasr
Club Retro Rides Member 170
What a wonderful project, and what a car it is and will be too! Some good articles here to keep me from boredom too . I shall be keeping an eye on this one.
Awesome! Just awesome.
I know your pain with drilling out rivets! Helped restore a WW2 swordfish, started seeing rivet heads in my sleep.
Jan 10, 2012 23:46:42 GMT
To make it cool properly, check out the Pantera community PIM.net etc etc. They are very similar in essence and drivetrain.
'83 GTM Coupe. 4A-GE Powered '00 GTM Libra Auto. Ick. '71 Detomaso Pantera. Current Resto '89 GMC Safari Tow/Kip bus '05 SAAB 9-3 Daily '71 Siva Moonbug. Not even contemplating resto yet.
Mar 31, 2012 17:59:12 GMT
it's coming together quite nicely. for now though i can only show a teaser picture but more will be forth coming in the near future. believe me it looks stunning in its original colour with the wire wheels
mk14dr
Yorkshire and The Humber
Club RR Member Number: 85
restoring an old Ford GT40mk14dr
@mk14dr
Club Retro Rides Member 85
Mar 31, 2012 18:35:19 GMT
Tease ;D
I can't wait to see some more shots of the finished product.
simes
Mar 31, 2012 18:46:54 GMT
Magnesium bodied MK7. the size of a small bus yet fairly light. an absolute hoot to drive Is this Rowan Atkinson's car? Either way I've seen him and I think Stirling Moss race it.
Simes
205Mi16 - 262 cams, Jenvey Throttle Bodies, Emerald managment blah blah...... E91 320D MSport Honda NC30 Vespa 300GTS
Mar 31, 2012 19:44:54 GMT
quote] OH MY GOD!!!! i thought the work shop at etype uk was nice THAT IS IMMENCE
