Sept 23, 2011 12:16:15 GMT
My spray gun (via compressor) isn't doing it's job anymore. Instead of creating a solid consistent stream of paint, it spits out in an on-off thing, with paint/air/paint/air, etc. This ruins anything, and I can't seem to remedy it at all. The gun isn't blocked (I disassemble and clean the whole thing out everytime I finish). The compressor is also doing it's job, I presume. There's a healthy and constant supply of air. I only fill the paint bowl thing (it's the 'underslung' suck type of gun) with about a 1/4 but the suction tube is always submerged. It's annoying as it's producing a really blobby finish in places (that needs to be rubbed down), and it's starting to hurt my bank balance - 2-pack ain't cheap! It's acceptable, but I'm at a stage/skill-level where I could just spray on and it's done. It's taking an extra day or so just to re-prep the surface.
Sept 23, 2011 12:17:35 GMT
Also, I'm thinning the paint to a good level to make it nice enough to spray as I have done for a couple of years (and it's been fine in the past!).
will930
Decked K11 Micra - RetroRunner Mk2 Golf
Sept 23, 2011 12:50:38 GMT
in the nozzle on the guns theres a set of tiny weeny little holes! we use mig wire on ours as they often get blocked! and blobbing like that ive only had with primer when its too thick!
Sept 23, 2011 13:34:30 GMT
Is that for the air or paint - there's one in the middle, and there's one on the outside from the compressor which (I think) directs the paint. Thanks!
Sept 23, 2011 13:50:01 GMT
Check there isn't water in the airline. Its been really humid and I've been having problems with my airtools getting wet because of condensation overcoming the moisture trap on the airline
Check your moisture trap
pepe
Sept 23, 2011 15:48:04 GMT
Water in airline (no moisture trap or full moisture trap) Paint to thick Obstruction in the gun (take apart remove any rubber parts and then soak all bits except rubber seals etc in thiners, ive used 2k thinners before as it seems to clean better than standard thinners/gun wash) Compressor pressure too low? Leak in pipes, conections or tanks?
Last Edit: Sept 23, 2011 15:48:48 GMT by pepe
da6t
Dec 22, 2011 21:49:31 GMT
Have you had it apart to clean it lately?? its usually not much, either the pin is dirty, nozzle is blocked or for some reason its losing pressure somewhere at some of the joins, make sure its all together tight!!
Dec 22, 2011 21:53:28 GMT
What type of gun is it,it may be the seal around the fluid tip as I've had something like that in the past,also check the vent hole on the pot
Well you will mess with these cars....
Mk4 golf gttdi highline. Mk2 golf 1.8T
david
Dec 27, 2011 12:23:45 GMT
if its a suction type gun... look for the breather hole for the paint cup. if that's blocked, it might cause troubles.
Dec 27, 2011 18:18:54 GMT
It will defo be the seal that has been disturbed when you stripped it down I ve had the same propblem in the past.
Prc
rodney
Dec 27, 2011 19:06:29 GMT
get yourself a gravity gun , thats what i have and prefer, also don't need to mix as much paint,.
