Sinky
Run Baby Run......Please!
Sept 30, 2011 20:40:46 GMT
Hi Help please Iv just bought a car that has been lying and not moved in 4.5 years. How do I empty the petrol tank. After 4.5 year do you think that fuel lines , pump and injectors will be gummed up. Stuck a battery on .It turns over but not start. whats the chances of the battery thats been in the car for ? charging up again
Last Edit: Sept 30, 2011 20:54:32 GMT by Sinky
2001 Volvo XC70 wagon
2003 Piaggio X9 Evo
mk2cossie
Club RR Member Number: 77
Sept 30, 2011 21:13:02 GMT
what vehicle? as some do have a drain bung on the fuel tank it wont hurt to see if the battery will take and hold a charge tho ;D
Sinky
Sept 30, 2011 21:44:53 GMT
Merc 200 ce 1994.
will try a charge tommoz once I get distilled water. cheers
2003 Piaggio X9 Evo
Sept 30, 2011 21:56:18 GMT
The Merc should have a drain bung - a big allen socket will be needed I'd think. However, depending on what conditions the car has been kept in, I'd be tempted to whack a new battery on it and crank it over! OK it won't pass any emissions tests but I dare say it'll fire and run. Maybe sling a gallon of fresh juice in there to freshen the fuel if it struggles.*Edit* just read your post properly...
Last Edit: Sept 30, 2011 21:58:47 GMT by BenzBoy
Sept 30, 2011 22:48:31 GMT
If its got injection just run the feed pipe into a jerry can and bridge the fuel pump relay.
R.S. Autotech. Servicing/Repairs/Diagnostics.
Ads 19
My old r19
200 ce has big hose going to pump and filter arangement, no point briding relay as if water in there will kill the pump. pull of the hose and let it drain out. then connect back up and put a jerrycan worth in it. it'll run, they always do.
