tome30
Oct 13, 2011 12:17:53 GMT
I'm confused. I want to lower the Golf. It's a driver, so I think it has lower suspension than standard Golfs anyway right? So if I use 40mm springs on a gti/driver will there be a noticable drop? And if I use 60mm will I need to also replace the shocks with shorter ones? I want to go low enough that there's an appearance change/stance but not so low that I'm going to have a bad ride.
Lowering help MK2 Golfstealthstylz
@stealthstylz
Club Retro Rides Member 174
Oct 13, 2011 14:11:54 GMT
Just get cheap ebay coilovers, why anybody would want lowering sprigs when coilovers are £150 new and a lot more tuneable. Even running them high you can swap springs around to get it to ride nicely.
tome30
Oct 13, 2011 14:18:30 GMT
I've been told to steer clear of cheap coilovers as they give a terrible ride/far to stiff etc?!
Oct 13, 2011 14:22:11 GMT
A driver / gti is only lower due to slightly lower springs as standard if i recall, so whatever springs / shocks you exchange on to it, your basically starting from scratch whatever model you put them on (if that makes sense). As above, either get some cheap coilies so you can set the height exactly as you want it, or get a decent quality -60mm kit for a good compromise between comfort, handling and looks. This was my mk2 GTI on a -60mm supersport kit that i bought nigh-on brand new for £70.00. Was fairly low, but never scraped on anything and handled very well.
@stealthstylz
Oct 13, 2011 15:48:14 GMT
I've been told to steer clear of cheap coilovers as they give a terrible ride/far to stiff etc?! The ride is usually curse word because people wind them all the way down and they have no travel left. You can get new springs very cheaply to make it ride or handle better.
Oct 13, 2011 16:13:01 GMT
got some used springs I was about to put in the classifieds depends on each brand and how much they lower it , mine are weitec and -40mm , sits like this idealy you want uprated dampers, but they will work on std ones
Last Edit: Oct 13, 2011 16:15:46 GMT by steveo3002
ade36
Oct 13, 2011 16:32:57 GMT
Had -60 springs on stock GTi(same as on the driver) shocks on mine with fresh bump stops. Looked great and stuck to the road like sh*t to a blanket. Coilover are obviously better but for an interim/cheaper option it worked for me
tome30
Oct 13, 2011 17:04:28 GMT
Thanks for the advice. 40mm looks low with those 15 sebrings fills the arches nicely however ill be keeping std 14 steelies so maybe 60mm would be Best?
Oct 13, 2011 17:45:31 GMT
14" should fill the arch the same as mine , you would have a taller sidewall so that the overall rolling size remains the same
Lopez
East Midlands
Oct 13, 2011 19:31:25 GMT
Ebay HotTuning coilovers - been on ours for 2 years or so now, they have transformed the car.
It's pretty stiff mind, so you do need to be aware.
tome30
Oct 13, 2011 19:52:02 GMT
GREAT...so verdict is neither 40mm, 60mm or coilovers will cause any particular problems, none will need shocks changing from the standard Gti/Driver ones, and I just need to stop umming and arring and stick it!
Oct 13, 2011 19:58:52 GMT
you don't need to do shcoks , idealy you should
they will soon ruin tired shocks , and they can tend to bounce on standard ones
tome30
Oct 13, 2011 20:03:43 GMT
I guess they're original shocks so I'll need to change them eventually anyway. ;D
Oct 13, 2011 21:38:47 GMT
Cant you just put thicker oil in the shocks? surely that would stiffen them up :S but yeah id personally go for the ebay coilies
Nobody dies a virgin, because lifes curse word us ALL
Oct 13, 2011 21:45:30 GMT
I'd vote for the cheap coilovers too. Have a set on our Jetta and they've been fine for the past two years. IMO, it doesn't ride too bad. If you were going to be properly blasting the B roads, I'd feel more confident with springs/shocks, but if your not going be driving too hard, the coilies should be fine.
Lopez
East Midlands
Oct 13, 2011 21:54:41 GMT
I drive our Mk2 GTI very, very hard. Even on pretty poor surfaces it feels planted to me, but then I'm used to a 205 GTI which makes a Golf feel like an oil tanker at the best of times to be honest.
tome30
Oct 13, 2011 21:58:27 GMT
Time to save up and buy me some coilovers !!! :-P
This info is basically the same for the B2 Passat, yeah?
Drivers aren't lower as standard. Just the GTI. I've been told to steer clear of cheap coilovers as they give a terrible ride/far to stiff etc?! So will running lowering springs with standard shocks, to get a decent set of springs you need adjustable damping shocks to match and then it comes into cheap coilover price region.
1989 Volkswagen Golf MK2 1300GT - Scrapyard rescue 1990 Nissan 200sx S13 - Drift toy 1992 Fiat Tipo Sedicivalvole - Low mileage project 1996 Vauxhall Corsa B - Winter daily 2001 Volkswagen Golf TDI PD130 - Mile muncher
WTB - Volvo 340 or 360
Take one Golf Driver and rip out the springs/shocks Purchase one set of Hot Tuning eBay coilovers and start to assemble Watch the lows take shape as each side is done Give yourself a big thumbs up when the work is complete Sup on a beer or two while helping the springs to settle Be proud of your new found lowness If time permits, have some late night fun with rattle cans and the trim rings DONE!
