I'm thinking about tail lights...
I'm thinking of buying a car which is missing its rear lights. I can get the correct lights but they will cost me a fair sum. So I thought I could do something "custom".
I'm looking for inspiration for rear lights which are a full set of brake/tail/indicator in one rectangular unit. Ideally a couple of inches tall, 6 or 8 inches wide? Have to be flat mounting and not go around the corners of the car (ie Viva HC rear lights are no good)
Obvious thoughts were Mk1 Escort / Capri (pre facelift)
Also thought about VW T2 but the early ones are too early looking and the later bay ones probably too ugly.
Also thought about Mk1 / Mk2 transit lights mounted at 90 degrees...
Who has some inspiration?
What about MK1 Golf?
1989 Volkswagen Golf MK2 1300GT - Scrapyard rescue 1990 Nissan 200sx S13 - Drift toy 1992 Fiat Tipo Sedicivalvole - Low mileage project 1996 Vauxhall Corsa B - Winter daily 2001 Volkswagen Golf TDI PD130 - Mile muncher
WTB - Volvo 340 or 360
crazymonkey
ummm....what was I doing again???
I was thinking mk1 golf as well.
whoever said dogs were man's best friend....obviously never heard of cable ties
do they mount "flat"? I thought the Golf Mk1 panel was angled? Also might be too tall. 'bout 4" tall arn't they?
Tail lights...Deleted
@Deleted
Datsun Violet Datsun 240Z Lada Riva Triumph Dolomite Skoda Estelle Volvo 140 estate (slight curve to the backs, but might be fixable) Hope that's of use.
markbognor
Club RR Member Number: 56
Tail lights...markbognor
@markbognor
Club Retro Rides Member 56
^ A fair few of those are made of unobtainium! Dolly looks like a winner though. What about a badly cut out peice of chequer plate with a brace of generic lucas lamps in place
Scimitar rear lights?
EmDee
Committer of Autrocities.
Club RR Member Number: 108
Tail lights...EmDee
@emdee
Club Retro Rides Member 108
Last Edit: Oct 14, 2011 10:40:04 GMT by EmDee
Oct 14, 2011 10:02:25 GMT
The Lada and later model Skoda lights are too tall. I'd thought of Triumph Stag, 2000, Dolly. They'd be going on this: If I buy it.
Oct 14, 2011 10:15:15 GMT
what about putting the lights inside the boot behind the rear panel? if you use big square lights you can cut the holes in the panel whatever shape you like.
Oct 14, 2011 10:21:41 GMT
lol, as soon as i saw you asking about rear lights, i knew it must be the Dodge ;D
Oct 14, 2011 10:27:15 GMT
Landies have lights like that but without the chrome... dirt cheap in pattern form. Or the pattern Lucas lights of that type as per Moggie Minor and loads of others. I'm using that type on my Minx. These kind of things-
'66 Amazon <-> '94 LS400 <-> '86 Suzuki 1135 EFE
Oct 14, 2011 11:05:00 GMT
Landies have lights like that but without the chrome... dirt cheap in pattern form. Was about to say exactly that... one of my friends has used them on her Mini as front indicators and also as modified rear lights and it was the first thing I thought of when I saw the pic.
Oct 14, 2011 11:58:18 GMT
Datsun Violet 1200 Coupe I could probably muster a pair of new ones of these from my shed.
stueyt
Saving cars from the scrapyard.
Oct 14, 2011 12:01:11 GMT
I've got a set of scimitar lights here if you are interested.
Cheers,
Stu.
Always looking for the next project!
Tail lights...e21meister
@GUEST
Oct 14, 2011 12:31:02 GMT
Was going to suggest these: from this: as the curvature of the rear panel on the Dodge looks similar. Would look nice with three on either side, but the cost would no doubt be prohibitive.
Oct 14, 2011 12:40:47 GMT
Landies have lights like that but without the chrome... dirt cheap in pattern form. Or the pattern Lucas lights of that type as per Moggie Minor and loads of others. I'm using that type on my Minx. These kind of things- They french quite well too, tube used is a chopped up disposable welding gas bottle. If other car lights aren't your thing try here: www.cbsonline.co.uk/category/Lighting/Rear_Light_Clusters,b.html
1977 datsun 810 180b estate
Oct 14, 2011 13:26:56 GMT
It already has round lights and they don't suit the shape of the car.
The Datsun 1200 lights look ace, but is that rear panel not slightly V-shaped?
@Deleted
Oct 14, 2011 13:37:03 GMT
I was moderately sure the Datsun panel while curved is flat where the lights actually sit so you should be able to just cut a suitable hole. Having seen the proposed car they'd go on, the vertical curve would compliment the destination panel nicely too. Ratdat will know better, of course.
Oct 14, 2011 13:54:33 GMT
rover SD1?
