LowStandards
Aug 30, 2006 12:28:47 GMT
Does anyone know how to remove the halfshafts from a Commer PB rear axel? Its the same as a Humber hawk/snipe apparently.
The diff bearing is whining and i need to get her fixed before i drive 300 miles this friday to Padstow. Any help greatly apprechiated
Phil
Aug 30, 2006 18:36:49 GMT
Honestly no idea. I am guessing there will be a retaining collar behind the flange of the halfshaft that will need unbolting and then a slide hammer to remove the half shaft. That is a generalisation of most live axles.
Sorry I cant be of any more help
Aug 30, 2006 19:12:14 GMT
watch those half shalfs mate, they are as rare as poor quality wobbly children's play ponyshit!
LowStandards
Aug 31, 2006 10:35:41 GMT
Done it, did'nt look hard enough did I! I thought the bolts behind the flange were just to hold the backplate on but no, they hold the halfshafts in! Thought the bearings were dead, but now i've got it apart everything seems fine and it appears the pinion shaft wasn't torqued up enough. Just hope when she goes back together thats the end of the whining!
LowStandards
Aug 31, 2006 11:35:49 GMT
I've had a quick search round the ode t'internet and it appears my whine was due to bearing pre-load. Now the nut you tighten to adjust this was loose which gave me the play in the bearings. Now the 'web' mentions many ways of adjusting this preload using many tools that i don't have, but the Commer manual just says bosh the nut upto 183Nm whcih i've done. There's no movement now and a slight drag when turning the shaft which seems normal. What are peoples thoughts? I've never rebuilt a live axle before and i don't want it overheating if its to tight or the whine to continue. Plus i don't want to take it out again as it took ages!
Sorry about the essay, but as I said before i'm going a long way this weekend!
