tigran
In rust we trust. Amen.
Club RR Member Number: 142
One for BMW geeks out there.tigran
@tigran
Club Retro Rides Member 142
Dec 18, 2011 16:22:16 GMT
andyborris
Dec 18, 2011 16:37:53 GMT
Last Edit: Dec 18, 2011 16:38:22 GMT by andyborris
Dec 18, 2011 16:41:19 GMT
Id be more worried about the floor / rear subframe cracking to be honest
rob0r
East of England
Club RR Member Number: 104
One for BMW geeks out there.rob0r
@rob0r
Club Retro Rides Member 104
Dec 18, 2011 22:50:34 GMT
You could of had an E30 M20 flywheel and clutch (though the clutch has seen better days) when you visited me, not sure though what clutch/release bearing you would need in use with your box.
E30 320i 3.5 - E23 730 - E3 3.0si - E21 316 M42 - E32 750i ETC
Dec 18, 2011 23:14:33 GMT
A friend of mine has a zf with a single mass flywheel, the gearbox makes quite a bit of noise beacuse of this. They do hold up, but might scare of most not in-the-know buyers..
tigran
@tigran
Dec 19, 2011 13:16:24 GMT
Id be more worried about the floor / rear subframe cracking to be honest Why? If bushes are kept on top of in the subframe and not left to rot out then there is no reason for the subframes to crack. Rob I know I meant to ask about it but it fell out of my head whilst i was up there. Dude - between my poly gearbox mounts and engine mounts i don't think i'll be able to hear any extra noise. Cheers for the link andy.
Dec 19, 2011 20:55:48 GMT
Id be more worried about the floor / rear subframe cracking to be honest Why? If bushes are kept on top of in the subframe and not left to rot out then there is no reason for the subframes to crack. Built in flaw that BMW over looked, earlier car's didnt have some foam in the subframe mouting points, which seems to cause them to crack. BMW didnt like to admit they were at fault though but in some case's will repair them. www.vrperformance.com/mt/2008/11/cracking_up_e46_subframe_issue.html
Last Edit: Dec 19, 2011 20:58:18 GMT by joem83
tigran
@tigran
Dec 19, 2011 20:59:42 GMT
But from what I understood the extra stress to crack the subframe came from the bushes being vamoosed hence allowing play in the subframe under acceleration/braking. Anyhoo...
Dec 19, 2011 21:04:14 GMT
But from what I understood the extra stress to crack the subframe came from the bushes being vamoosed hence allowing play in the subframe under acceleration/braking. Anyhoo... Not 100% on that, doesnt stop me from wanting another E46 though OT, don't ECP do non DM fly's for the E36?
One for BMW geeks out there.Robinxr4i
@robinxr4i
Club Retro Rides Member 143
Dec 20, 2011 16:17:09 GMT
Don't the very easy non-vanos E36 325's come with a solid flywheel? OT, don't ECP do non DM fly's for the E36? I work at a Motorfactor (not ECP lol!) and on my system Valeo do list a solid flywheel conversion for the E46 328, the part no. is 835038, although I'd expect it to cost around £430 inc vat. Although I am aware that ECP do have a supplier that offers a cheaper range of solid flywheel kits.
