I heard a rumour that Golf Mk2 lowering springs work fine on a B2 Passat. Is this truth or bunkum? Failing that or whatnot, best way to remove a couple of inches from the ride height...?
Last Edit: Jan 3, 2012 17:10:59 GMT by akku
mrj
they have coils; you could actually just chop them; i am not sure about Golf springs, they might fit, i never tested them , as we need TÃœV over here ..... you could also use Audi 80 B2/B3/B4 front springs, and cut the rear ones.... i might have a set of used H&Rs in the workshop, i need to check, if they are still here .... H&Rs are the best ones available for these cars; this is my Variant with H&Rs and standard shocks : H&R claim to lower about 40mms, but mostly they drop 60mms ....
- 1971 VW 1600 TL Fastback - 1978 Passat GLS Variant - 1980 Audi 100 5E - 1981 VW aircooled panel van (sold) - 1983 VW Jetta Mk.I - 1984 VW Polo Coupé - 1984 VW Passat hatchback - 1987 VW Passat Variant - 1987 VW Passat hatchback - 1988 VW T25
And I just scrapped one like that last week. Darnit.
opinion is divided as to whether cutting them is OK or if they are pigtailed/variable wound. chopping them is fine it they are good to go at that.
Last Edit: Jan 3, 2012 17:44:53 GMT by akku
Choppity chop chop!
Cutting the springs on these is no big deal. If you know what you're doing.
beany
Hmmmmm
I ran MK2 golf front springs, think u might have to fit them upside down, or I might've used golf top caps to suit
Maximum signature image height = 80 pixels
choppies are fine on my B3 ;D
wouldnt mk2 golf coilovers work?
Nobody dies a virgin, because lifes curse word us ALL
Lowering a B2 Passat....Dez
@dez
Club Retro Rides Member 34
no, they don't share the A platform like b3/4 passats and mk2/3 golfs did. they're the same platform as the same age audis i believe.
you can chop the springs, but from experience, itll ride like curse word unless youre just sat on the bumpstops. if mk2 springs fit, id go for them as the cheap and easy option, as you can get various weights and drops.
you could probably make some coilies fit, i dunno if mk2 ones would go though, its been a while since i played with one of these.
I ran MK2 golf front springs, think u might have to fit them upside down, or I might've used golf top caps to suit Now that looks awesome. I have some "Universal" coilovers I think. (I know I have them I just think they claim to be "universal") but TBH I CBA with anything which is like hard work on the thing.
^ this was on the 40mm H&R springs ( settled in ) on mk3 golf 14's Rode a damn sight better than the choppies fo sho.
I tried mk2 rear coilovers on the rear of the santana and it was riding on the bumpstops at this sort of ride height. So I went with standard mk3 springs for the rear and -40mm mk3 springs on the front. *edit( looking back at the pictures the struts were freakishly long! mk3 coilovers must be shorter than that lol
RobinJI
you could probably make some coilies fit, I dunno if mk2 ones would go though, its been a while since I played with one of these. They're a 1 piece hub and strut IIRC unfortunately. Edit, c71s, mk2/3 golfs do have freakishly long rear struts. Mk1's and Polo 6n are the same but shorter, so might be worth a look.
Last Edit: Jan 4, 2012 19:22:44 GMT by RobinJI
beany
Hmmmmm
www.ukpassats.co.uk/phpbb/viewtopic.php?f=6&t=22168I used Ibiza/6n polo rear shocks on the back of my old silver one, the spring cup is about 90-100mm lower than the passat ones so instant drop with normal ride, then fitted some corrado vr6 rear springs and it dropped about another 40mm and still rode well. Only down side was that the rear beam would hit the chassis when hit bumps
Last Edit: Jan 4, 2012 20:13:42 GMT by beany
cool, thanks for that info guys
It is possible to fit coilies on B2 if you don't mind a bit of fabrication, there's a few about like it, one on this site
oxb1l
Sept 26, 2022 7:05:48 GMT
Good morning Does the B2 passat run the same suspension set up as a B1 ?
Bill
Need a bigger garage !
