A full kit of used parts to convert a fixed rear bench seat on a W126 into an electric reclining set up.
There is the motor, frames, brackets (weld on), wiring loom, switches and the correct base and backrest to fit on to the set up.
All you need is your original covers to swap onto the new frames.
Photos to follow when I get all the bits out.
£100 for the lot.
£100 for the lot.
