LowStandards
Sept 25, 2006 8:36:53 GMT
The diff is very noisy on my '69 commer PB, now i know these use the same axle as the humber Hawk and i've been offered a complete Hawk axle, but its from an overdrive model.
Couple of questions:
Will the ratios be the same?
If not, if i bought the gearbox and overdrive unit, is it a simple fix or would it be a nightmare? propshaft length, wiring etc
Help cause the noise is driving me mad!
Sept 25, 2006 9:04:51 GMT
I think the ratios should be OK?
The O/D units used by rootes were the Laycock type which doesn't affect the ratio's of anything else..... but don't take this as gospel necessarily...
If you do need to change the box, be aware that the box is essentially the same as used in loads of other hillman/humber/singer 1725 type cars... but the commer has a unique tail-housing. The propshaft is also unique to the vehicle.
Hope this is of some help?
LowStandards
Sept 25, 2006 9:07:54 GMT
Yup, as long as the ratio of the diff is the same or very similar it should be fine??? Though i do fancy overdrive, its something i can do without!
Just looking round t'web and all i seem to find is a ratio of 4.22 whichever vehicle i stick in, so it seems there all the same...
Oh, one more question, an autobox? How feasable is this? I'm reegt lazy ya see
Sept 25, 2006 9:15:01 GMT
Quite a few Commer's came with auto-boxes.
I haven't seen one 'in real life' but I assume they use the BW35, as this was used again in the 'superminx' type cars with the same engine. Again, you'll have issues with that tail-housing, but it is perfectly feasable.
Really don't know how the shfter works though.... Musta had a column shift, as otherwise you'd have the world's oddest shaped floor shifter.
Also, those autoboxes eat all your power. that's bad enough in a sleek, lightweight superminx... in a Commer brick on wheels it must be really grim!!
LowStandards
Sept 25, 2006 9:18:20 GMT
Was thinking in the long run a nice chunky diesel or maybe a subtle Merc V8 FTW. I mean mpg aint really an issuie as its pretty bad already and she don't come out to often, should be able to keep up with traffic then!
Still its a pipe dream and something that wont happen for many years i guess!
Cheers, for your help mind!
Sept 25, 2006 9:36:31 GMT
get a lovely montego diesel in there! great engines those. Bosh one in and set off to N. Africa, fantastic.
1972 Fiat 130 1985 Talbot Alpine 1974 Lancia Beta Saloon 1975 + 1986 Mazda 929 Koop + Wagon 1982 Fiat Argenta 2.0 iniezione elettronica 1977 Toyota Carina TA14 BEST CAR EVER!!!!!!!! 1979 Datsun B310 Sunny 4-dr 1984 Audi 200 Quattro Turbo 1983 Honda Accord 1.6 DX GONE1989 Alfa 75 2.0 TS Mr T says: TREAT YO MOTHER RIGHT!
Sept 25, 2006 9:53:03 GMT
A modern-ish TD in a commer would indeed be A Very Good Thing. Must be enough space... it's really only height which is a significant issue.
Weren't some of them fitted with the Perkins P3? Officially the worst engine evAr....
LowStandards
Sept 25, 2006 10:31:06 GMT
They did a diesel version, and i think it was a perkins! My Dad tells me everytime he see's the Commer how he spent his youth sat upon the engine lid of a diesel one, smoke filling the cab and how awful it was!
I reckon a nice 2.5TD with a 5speed would go a treat, even better an auto, do they do auto transits?
Sept 25, 2006 10:45:32 GMT
Some of the Transit Tourneo minibuses came with an autobox for the hire-drive market
Sept 25, 2006 11:39:23 GMT
Will the ratios be the same? If not, if i bought the gearbox and overdrive unit, is it a simple fix or would it be a nightmare? propshaft length, wiring etc I know sweet FA about the technical side of Rootes Group vehicles but the following generally applies to most '60s cars.... The overdrive axle will probably be lower geared - ie 4th with the non o/d axle will give greater mph / 1000rpm than 4th with the o/d axle (but obviously, o/d 4th will be tallest). If you can, I'd fit the o/d too, as the complete setup will give a closer range of ratios (as well as a taller top gear once up to crusing speed), that will be more suited to the heavier weight / drag of the van.
Last Edit: Sept 25, 2006 11:42:15 GMT by Paul H
Sept 25, 2006 16:10:40 GMT
for deisal auto,s check out a motorhome breakers, although the mojority will be fwd
"quote hairnet"
I'm not paying nine pound for a pi$$!
[/quote]
Sept 25, 2006 20:17:05 GMT
I agree with Paul H's generalisation. Certainly GT6's came with different ratio rear ends depending on wether they had OD or not. From a Roots point of view I can give you the folowing info which may or may not be helpful - from my Sunbeam Rapier/Alpine Singer Gazelle/Vogue manual. Gazelle 2a,3 & 3a 4.78:1 Gazelle 3b & 3c 4.44:1 Gazele 5 3.89:1 Vogue 1 & early 2 4.22:1 Vogue 1 with O/D 4.44:1 Vogue 2 late & 3 3.89:1 Rapier 1 5.22 :1 Rapier 2 4.55:1 Alpine 1 & 2 3.89:1 Rapier 3 early 4.55:1 Rapeir 3 late & 3A 4.22:1 Rapier 4, Alpine 3 & 4 3.89:1 OK, so I realise this might not be directly relevant as I'm not sure the axle is the same (Hawk/Commer might be bigger for bgger car/commercial use?) but hopefully it suggests the ratios they were playing with.
LowStandards
Sept 26, 2006 7:45:29 GMT
Cheers, it seems only a slight difference in ratio with an overdrive fitted.
I was reading up the specs from my Manual last night, but it confused me a little, all this mention of final drive was up there at like 5.33 and things like that, does this include the gearbox in the calcuation? Prob best if i post the page up here really, though you'll just have to wait till tomorrow!
Unless anyone can recommend a good diff rebuilder? all the bearings and pinions are fine, the only prob is when i took it apart some chewed up shims fell out so the pinion is not close enough to the CROWN wheel. And i don't have a clue about doing it myself...
LowStandards
Sept 27, 2006 8:47:55 GMT
K, here's the page from the Commer manual, I've highlighted my axle and i'm running 15inch wheels The only diffs i can find are 4.22 ratio, will these work, i cant decide wether the ratios quoted in the manual include the wheels etc, is there a way of working it out???
