mt2man
Feb 24, 2013 18:46:56 GMT
Not much of an update but ive moved and been moving cars around and sorting the house out etc But mocked up the spare engine gearbox so i could sort out engine mounts etc, will have to cut out some of the fibreglass to make room for the exhaust but will be okay Still along way off but its under cover now and out of the rain but i can start working properly now!
teaboy
Make tea, not war.
Excellent stuff, the Kitten has so much going for it.
Lightweight, rear wheel drive, reasonable power; what's not to like?
Are you going to fit a reverse gear?
Keep the updates coming plz! :-D
Koos
mt2man
Feb 25, 2013 14:14:11 GMT
I just realised you can see i lost my shoe under the gearbox as i was fitting it... haha, i managed to get my self stuck in the engine bay! And i cant wait till its finished! I will be leaving the body looking extremely tatty and sleeperish but will be taking the body off so i can treat the frame and paint it properly so it lasts, will be flipping the rear axle and fitting coilovers on the front so i can lower it alot But i probably wont be fitting a reverse gear, unless i can fabricate one when i build the 2 peice prop, but its such a light car a foot out the drivers door is all it needs really haha
teaboy
Make tea, not war.
Feb 25, 2013 21:37:13 GMT
will be flipping the rear axle and fitting coilovers on the front so I can lower it alot Do you mean putting the axle above the leaf springs? Are you doing anything with the brakes? I like the idea of sorting out the mechanicals and leaving the rest looking 'lived in'. I will probably take a similar route when I get round to doing something with mine.
mt2man
Feb 25, 2013 21:49:20 GMT
yes will be putting the axle above the leaf springs, and i will be fitting minifin drum brakes untill i can sort out a way of doing the disc conversion. I'm hoping it will be a wolf in sheeps clothing once its done have tons of 10" mini steels so will post probably run them for a while so it will look extremely stock haha They are awesome little cars, so quirky and different!
mt2man
Does anyone have any pictures of the rear axle once the cars been lowered? Looking at the axle the hand brake cable will be in the way, the only other idea i have is moving the leaf spring mounts.
mt2man
Or removing a leaf or 2 and instead of a damper run a coil over set up, so the leaf is pretty much used only for locating the axle, anyone experimented with this?
teaboy
Make tea, not war.
Or removing a leaf or 2 and instead of a damper run a coil over set up, so the leaf is pretty much used only for locating the axle, anyone experimented with this? Not mine, just some pics I saved for ideas. I can't vouch for its effectiveness. You don't want the radius arms too short or it can induce rear steering I have also heard that the reliant axle can be weak if it is not supported by the leaf springs. All in all, I think I have raised more questions than answers I think, sorry.
Lateral location looks a bit of an afterthought....
Koos
mt2man
That's cool thanks, but was more after something simpler and will be keeping the leaf springs. Has no one got any pics of lowered kitten?!
teaboy
Make tea, not war.
That's cool thanks, but was more after something simpler and will be keeping the leaf springs. Has no one got any pics of lowered kitten?! I think the late, new shape Robins used a single leaf rear spring, or you could have the leaf decambered?
froggy
Moving the springs mounts won't work as you can't lose that much height from the rear shackles . I put the axle on top if the springs and make a bracket to hold the handbrake quadrant . That lowers the rear by 2.5 " . The prop will need a split bearing in as a one piece prop will rip the nose of the diff off
mt2man
Oh okay ill have to just put the axle ontop and see what happens with the handbrake quadrant,2.5" is how low i was hoping to go so that will be great! Will source some uprated shortened dampers too, will be fitting coilovers on the front to lower about 2.5" too.
And i am planning a 2 piece prop, i have read somewhere about transit bearing carriers being used but its something i will have to research further into!
Frankenhealey
Club RR Member Number: 15
Update?
I'm guessing as I bought the kitten this project is no longer.
muttley racing ftmfwmf
120y
The Kitten is another seriously underated car, has so much going for it.
1996 Renault Clio MK1 1.4 RT Auto
bstardchild
Club RR Member Number: 71
I'm guessing as I bought the kitten this project is no longer. Have you started a thread on ehat you have planned for it?
Nope, not the kind of build too post on a public forum
Last Edit: Oct 4, 2013 9:56:46 GMT by hcanimal
bstardchild
Nope, not the kind of build too post on a public forum I'm sorry about that but I do understand
