Feb 26, 2012 18:41:48 GMT
Hi! In the beginning I want to warn you: I write pretty good finnish rally-English. ;D But if you can't understand: take a look at the pictures! I bought my first project in 2007. I worked on it about four years. Last summer I drove about 1000 kilometres with it. There are some upgrades to do next summer: the engine is so loose that it burns oil just as much as gasoline. Here are some pictures: This is how I bought it Engine lifted out Almost everything was stripped out This wasn't fun at all Bottom painted and protected from stones. Here you can see the "garage" where I did almost all of the work. Not too much space and there was quite cold sometimes. I think the coldest was -20 c. Rebuilding front fenders First time out after painting. I painted it myself in that "garage" of mine. That painting was my first and it isn´t bad at all. Had to try polishing Rebuilted front brake calipers. I painted them and bought new seals. My father lathed stainless steel pistons to calipers Exhaust made Bought cheap gutman rims and painted them. Poor quality in this pic. Interior is almost original And finally ready to rock and roll ;D I lowered it a "little bit". In the front you can find Vw caddy shock absorbers and shorter springs. And the rear has shorter shock absorbers and aluminium bars between rear axis and leaf springs. More pictures of the engine project coming soon.
Feb 26, 2012 18:45:59 GMT
Brilliant work! do you have any pics of the Gutmann wheels on the car before they got painted black? Machining the stainless caliper pistons is one of the coolest things I've read today.
tenman
m00000000000
Feb 26, 2012 19:02:36 GMT
sweet....
RWD Fanatic...
2003 BMW 320d Wagon (getting old and boring) 1996 Mini Kensington (SWMBO's)
Feb 26, 2012 19:53:02 GMT
It looked almost like my Volvo 164... Damn it was hard to clean everything up... but in the end looked awesome... Always good to see some KE20 love...
Feb 26, 2012 20:12:25 GMT
looks great. nice job
goldnrust
West Midlands
Minimalist
Feb 26, 2012 20:18:48 GMT
Looks awesome, love these early Corollas Fair play for getting on with it at -20c! I look forward to seeing your future plans for it
Feb 26, 2012 20:31:49 GMT
Brilliant work! do you have any pics of the Gutmann wheels on the car before they got painted black? Machining the stainless caliper pistons is one of the coolest things I've read today. I only have that picture of gutmann rims before painting I should had take more pictures during work. I must take more pictures in the future. Before I could paint rims black I had to remove old lacquer. Rims had many corrosion spots too. I wanted to polish perimeters (if you know what part I mean) ;D but there were too much corrosion spots. So I had to sandblast the perimeters.
Feb 26, 2012 20:33:30 GMT
Thanks for the comments!
Feb 26, 2012 20:50:58 GMT
I was looking for one of these but for the same price tag I bought a volvo 164 which was a loooooot of engine...a 3.0 straight 6 ... but they are awesome neederless...
MaDSeB
Big things in small packages
Feb 27, 2012 17:47:35 GMT
kool build, love the old j tin. keep this updated
Feb 28, 2012 11:43:23 GMT
Thats a real nice example! Having just stripped an re painted the bottom of my Rx4, i know what a headache this can be be! Nice colour combo underneath though! Mines the same except with red floor and black prop/axle
Feb 28, 2012 13:49:04 GMT
Okay, I found a cure for loose engine. I think there is coming some more power too. Couple months ago found a pile(almost whole engine) of parts in low prise. (Whole project is done low budjet if you hadn't noticed) Parts I found: -4K block with +0,05mm bore -Oversize pistons -3K cylinder head with bigger intake ports -280 degree camsaft -A little bit bigger dellorto carburetor -Self made exhaust manifold. Looks like Martelius and welded quite well I bought later two sets of full seal sets and crane cams electronic ignition system. I disassembled the engine and checked all parts. I think that engine is rebuilt recently. I have to disassemble the cylinder head too and atleast change valve stem seals. Block and oil pan cleaned out I found cheap and cool paint ;D This is test because some say that normal paint doesn't stick on the block and some say it sticks very well. Sylinder head Seals Some kind of sound system: Chinese usb radio and Blaupunkt ballspeakers. Those orange ones are earplugs, these are needed in longer trips Ke 20 is sleeping in the "good" chinese tarpaulin garage. Some salt in the colander. This far no mold
bullyboy
Let's humppa!
Feb 28, 2012 13:52:55 GMT
Hyvältä näyttää Missäpäin suomea Rolla asustaa?
Till rust do us apart.
Feb 28, 2012 14:10:29 GMT
Parkanossa, Treeltä pohjoseenpäin..
Feb 28, 2012 14:19:13 GMT
Hienosti remontoitu, kivaa että näistä tehdään muuta kuin vaan sprintti- ja jokkisautoja. Kaverilta ostettiin ke27 mistä kuulema piti teettää sprinttiauto... Ei ole näkynny sen jälkeen.
Sorry for the finnish! ;D
Last Edit: Feb 28, 2012 14:22:17 GMT by dude
Feb 28, 2012 15:56:55 GMT
Yep, let's try to write English. As you said too many corollas and other rare old cars are in racing use.
bullyboy
Let's humppa!
Feb 28, 2012 16:05:28 GMT
Very comfortable working position by the looks of it ;D
Feb 28, 2012 16:17:21 GMT
I done half of the bottom like that and other half when the car was on its other side. Actually that wasn't bad at all. ;D
bullyboy
Let's humppa!
Feb 28, 2012 16:24:52 GMT
Well yeah, beats lying on the ground under the car and swinging brush ;D
