andyborris
Mar 19, 2012 20:52:18 GMT
Need some advice on making brake pipes from a reel of Kunifer pipe please. www.rallydesign.co.uk/popup_image.php?pID=13935While I can form the ends (and even get them leak proof!), I can't seem to get the pipes straight! Because the pipe is curved into a reel, I always end up with a “slight wave” to the pipe. Any suggestions on how to get a wavy pipe straight? Have a Lola by way of thanks Andy
Mar 19, 2012 21:22:54 GMT
I've heard suggestions of rolling it between two (flat!) planks of wood (put it lengthways between the two and move one across the other).
That said, I've not tried this method; slight wobbles don't really bother me, as long as they fit - but I can see that you might want to make them immaculate if you're working on something special.
The other option is to buy steel pipe - it is available as straight lengths - but of course it will rust eventually.
CIH
Mar 19, 2012 21:32:43 GMT
You almost never get them as tidy as factory lines. So long as they're properly functional I wouldn't worry too much about it.
oxb1l
Mar 19, 2012 22:20:44 GMT
I've got a piece of string for measuring them and after I have the required length I use a small hand held bender (simple one ) After I have my bends in the required positions I straighten out any areas that need to be spot on by hand
Really it's a case of taking your time (your using the right stuff for a good finish)
Need a bigger garage !
scruff
Mar 20, 2012 10:53:17 GMT
Planks work OK but will never be 100% straight.
I spy a trend...
Mar 20, 2012 12:07:56 GMT
I can get copper pretty damn close to the originals, not tried copper-nickel as my local motorcactor never has it on the shelf. I tend to remove the originals in as close to the original shape as possible, then add a brake fitting to one end and bend the new pipe alongside the original, then cut to length and add the last fitting. all done by hand
Mar 20, 2012 13:27:08 GMT
Are there any other tools or materials to use when making a complete new brake line set up? thought i would post in here rather than make a new thread, sorry about the novice question just bugging me
Mar 20, 2012 13:32:24 GMT
just a flaring kit, brake pipe spanners, and mole grips.
oh and a bleed kit of some kind and a beautiful assistant.
Mar 20, 2012 13:44:42 GMT
and i can use my unions and previous fittings on the original set up i guess? cheers
andyborris
Mar 20, 2012 14:10:35 GMT
I'd get new fittings in Brass, then everything is anti-rust.
Mar 20, 2012 14:17:58 GMT
just a flaring kit, brake pipe spanners, and mole grips. oh and a bleed kit of some kind and a beautiful assistant. That can't be right, my assistant is certainly not beautiful, and it still works! ;D
Mar 20, 2012 14:18:27 GMT
and I can use my unions and previous fittings on the original set up I guess? cheers Assuming that they are in good condition and not horribly rusty (they may well be if you're having to replace the pipe itself), then yes.
Mar 20, 2012 14:19:21 GMT
and I can use my unions and previous fittings on the original set up I guess? cheers unions are cheaper than a cheaper thing, best to fit new
Mar 20, 2012 15:13:48 GMT
will get some new ones in that case cheers guys
scruff
Mar 20, 2012 16:04:25 GMT
Little blob of copperslip on the threads helps keep everything sweet forever. Just keep it away from the mating surfaces.
I spy a trend...
I got a piece of spare steel, it's about 100mm wide and 8mm thick, a couple of feet long (but o'course anything vaguely similar would do). Roll the pipe on the bench with that. Can be hard work, and it has to be fairly straight first or it just sits there... sort of work one end first, so there's less wobbly pipe to fight at one time, kind of thing.
'66 Amazon <-> '94 LS400 <-> '86 Suzuki 1135 EFE
