I've always done tracking with a tape measure :-) Might not be acurate to a thousandth of an inch but I've never suffered excess tyre wear etc. Quick Google finds this -
paul h
dgo
I've had one for about a year and used it a number of times on different cars. If you're careful it produces repeatable results (to what seems to me to be pretty good accuracy). Had my tracking double checked by a garage after first time of use and the measurements were very close.
Obviously doesn't do 4 wheel tracking if you need that
looks good...spose you need the fancy turntables too
dgo
Gunsons laser trackerDez
@dez
Club Retro Rides Member 34
as paul says, it isnt really anything you cant do with a tape measure. ive got one of these- the long bar with the red bit on the end at the front left. its low-tech, from the 50s, but less to go wrong or break, and more than accurate enough for any street driven car with normal rubber bushed suspension. they're was a DIY one somewhere on the HAMB that you could home-make from scrap in an afternoon if you can weld.
